Author Topic: Kapex Question  (Read 4276 times)
Offline Medickep
Kapex Question
« on: May 11, 2020, 06:22 PM »
Hello!  New to the site.
After years of dealing with a huge mess with my Rigid miter saw, I finally bit the bullet and bought a Kapex miter saw!  I'm sick of everything being covered in dust and bringing it into my house.
I'm still waiting on my saw, but was wondering if it was worth the price to buy the larger 36mm Festool suction hose.  I have a 27mm hose, which came with my CT36, but the saw will be mounted to a work station and I thought it could be convenient to have a separate hose "preplumbed" so I can just wheel my CT over when using it.
They want a lot for these hoses, so if anyone knows a cheaper alternative, that would be nice, but I imagine the fittings are expensive too!😂
I have a dust deputy lying around from my old system, which I thought did nothing until I looked in the bucket and saw it was half full.  I thought about using this with my Kapex as the Kapex would most likely fill the bags in my CT faster than my sanders!
Thanks in advance!
Offline Birdhunter
Re: Kapex Question
« Reply #1 on: May 11, 2020, 06:25 PM »
I switched to the large diameter short hose and got significantly better collection. I have a Kapex Mini dedicated to the Kapex. Seems to get a lot of use before needing a new bag.
Birdhunter
Offline ChuckM
Re: Kapex Question
« Reply #2 on: May 11, 2020, 06:35 PM »
The larger dia. hose is a must. I cut a section of a pool hose bought from Lowes (.ca), like this on the .com site:
- https://www.lowes.com/pd/EASTMAN-1-1-2-in-Inner-Diameter-x-1-ft-Polyethylene-Pool-and-Spa-Vacuum-Hose/1000180595
or
- https://www.lowes.com/pd/Kokido-1-5-in-9-ft-Filter-Connector-Hose/1002637314
I enlarged the inner tube a bit with a Dremel sanding drum.
Cost-wise, it was a fraction of the Festool Anti-static hose. A shorter hose is preferred.
Edit: Auto switch used (Cdn site shown), and powered 15amp each for the saw and for the vac: https://www.leevalley.com/en-ca/shop/tools/workshop/dust-collection/parts-and-accessories/63013-ivac-automatic-vacuum-switch
« Last Edit: May 11, 2020, 07:04 PM by ChuckM »
Offline ear3
Re: Kapex Question
« Reply #3 on: May 11, 2020, 06:54 PM »
Welcome to the FOG!
As has already been remarked, the larger diameter hose makes a huge difference on the Kapex. I run DC for my saw off a 6.5hp Ridgid shop vac, and use a 1 and 7/8 orange Home Depot hose, whichh is hooked it into the kapex with an adapter.  I find that the combination of the larger hose and more powerful vac actually makes for better dust extraction than the Festool hook up (though no auto start unless you build your own system). Though the ct+36mm still works really well when I'm working with the saw outside my shop.
« Last Edit: May 11, 2020, 06:58 PM by ear3 »
Offline Thompmd
Re: Kapex Question
« Reply #4 on: May 11, 2020, 08:36 PM »
Welcome to the FOG.
I’m also new and recently purchased a new a Kapex a couple months ago using a CT36. I used a 5’ section of 36mm and it works well.
To be fair I never tried a 27mm. Everything I read suggested a 36mm hose cautioning about keeping it as short as possible.
Sawstop Industrial Saw, TS75,2 1400 rails, CT36, Rotex RO 150 FEQ, CT-VA-20, Carvex PS 420 EBQ, Carvex acc. ZH-SYS-PS 400, Kapex KS 120, CT Cyclone Dust Collection Pre-Separator CT VA 20, DF 500 Q Set, Domino 1,060pc Tenon Assortment, UG-KA-SET Portable Imperial Stand & Extensions,OF1400 EQ-F-Plus, MFT/3, MFT-SP, FS-HZ 160
Offline Mrcurlik
Re: Kapex Question
« Reply #5 on: May 11, 2020, 09:57 PM »
My first post as a hobbyist.
I have purchase a Kapex saw and one of the main reasons I chose Festool was their claim of superior dust extraction. You could use it in the job site living room - dust extraction was so good was their claim. Well my shop dust extraction with their HEPA vac was so poor I called to Festool service to complain. Their solution was my 27 mm hose was inadequate for dust extraction so I purchased the next largest hose 36mm. Well to my disappointment nothing improved.
Can anybody give me some advise as to how to improve my dust extraction?
314221-0
Offline ChuckM
Re: Kapex Question
« Reply #6 on: May 11, 2020, 10:31 PM »
1) Hose too long. 3 to 4 feet or so.
2) When cutting, pull the saw head all the way out (towards your body), lower the saw down and push to cut. Don't use it like a chop saw.
3) Buy a spare rubber dust shroud/hood and add stache to it. Available from Fastcap etc. https://www.rokhardware.com/fastcap-2-saw-stache.html
(Previous thread: https://festoolownersgroup.com/index.php?pretty;board=other-tools-accessories;topic=fastcap-saw-stache.0)
« Last Edit: May 11, 2020, 10:58 PM by ChuckM »
Offline aloysius
Re: Kapex Question
« Reply #7 on: May 11, 2020, 10:39 PM »
It's a Mitre Saw.  The geometry & physical characteristics of the saw will always be "compromised".  It's just the innate nature of how a x-cut saw operates.
If you think the Kapex extraction is disappointing, then don't try any other!  Simply put, for all its faults, the Kapex's dust extraction is pretty well unrivalled.  In most cutting situations, a Kapex fitted with a larger diameter & foreshortened vac hose when fitted to a good quality vac extractor will be far superior to any other alternative that I've ever seen or used.
Nevertheless, it will never be anything even approaching dust-free in operation.  The clown who suggested that it's suitable to use in a client's living room is basically lying!
FOG-wit since '95:  Some say since birth...
Offline SRSemenza
Re: Kapex Question
« Reply #8 on: May 11, 2020, 11:04 PM »
      I am not sure what "clown" at Festool may have said this. But it is possible that you read here on FOG posted by this clown, me. The simple true fact is that  I  have used it in my customers lived in furnished homes (living rooms, bedrooms, kitchens) on many occasions.  It is not dust free. But the clean up around, under and behind the saw has been very minimal in my own use in those situations.   There will be dust.   In my use it has stayed right near the saw. I have at times tossed drop cloth over a piece of furniture behind the saw.
     Guesstimates of percentage collection are just that, guesstimates. 90%, 75% whatever. It may not work out as well for everyone in every situation. It depends on the cuts, the quantity of cuts, etc.
     I have never had a complaint about the dust or my site cleanliness. And I have nearly 100% repeat business (including those where I used the Kapex in the house).
Offline Mario Turcot
Re: Kapex Question
« Reply #9 on: May 12, 2020, 02:10 AM »
@Mrcurlik Make sure your CT 36 is set to max suction.
Mario
Offline Birdhunter
Re: Kapex Question
« Reply #10 on: May 12, 2020, 05:29 AM »
On some cuts, like shaving the end of a board, dust collection is poor just as it is on my monster SawStop table saw.
Most of my Kapex cuts are 90 or 45 degree. I find letting the Festool Mini Vac get a 10 second head start before the blade hits the wood improves collection. I also find “pacing” the cut so that the vac can keep up with the dust coming off the blade helps with collection and doing so babies the motor and the blade.
The short fat non-static hose greatly improved collection.
After heavy use, I do have to clean up behind the Kapex. There is a light dusting back there.
All said, it’s better than having to drag my prior saw outside before using it.
Birdhunter
Offline Thompmd
Re: Kapex Question
« Reply #11 on: May 12, 2020, 07:21 AM »
I agree w/others. Of the tools I use the Kapex is by far the lease effective tool in regards to DC.
I’m still amazed how well it works when Sanding, Domino etc.🙌
Offline Medickep
Re: Kapex Question
« Reply #12 on: May 12, 2020, 08:37 AM »
Thank you for all of the replies!! I didn’t realize there were responses! Apparently “notify” on a post doesn’t send you an email!!😂
Offline Medickep
Re: Kapex Question
« Reply #13 on: May 12, 2020, 08:52 AM »
As the original poster, I appreciate all of the replies.   I think I will try some of the cheaper options first, but know the fittings can cost a lot!
Are people who are using the dust deputy with a CT liking the results? Mine is on a 5 gallon bucket already.  I plan on leaving it under my bench and maybe sizing up on the container if it works well!   I do have a Jet DC nearby with 4” hose.  I suppose I could use that too!😂
Offline HiCal
Re: Kapex Question
« Reply #14 on: May 12, 2020, 09:25 AM »
Hello. Has anyone tried using the 50 mm hose with the Kapex? Too big?
Offline ChuckM
Re: Kapex Question
« Reply #15 on: May 12, 2020, 09:58 AM »
As long as the connection on the port is air tight, the hose is not too long or rigid/heavy, and the suction is good, I don't see it an issue at all.
Re: Kapex Question
« Reply #16 on: May 12, 2020, 10:02 AM »
There are some on this forum that have used a 50 mm hose with good results.
Offline SRSemenza
Re: Kapex Question
« Reply #17 on: May 12, 2020, 10:02 AM »
A couple notes on my living room use above. These are 10 - 20 cut situations. I am not trying to frame a house from a living room.
You can also see the dust on the Kapex MFT around the back of the saw. There would also be some on the floor behind it. But that's about it.
Offline ChuckM
Re: Kapex Question
« Reply #18 on: May 12, 2020, 10:02 AM »
The benefits of a DD (cutting the need to change filters/frequency of emptying the tank) outweighs the reduction of the suction.
Offline HiCal
Re: Kapex Question
« Reply #19 on: May 12, 2020, 10:06 AM »
Thanks Chuck. That was my thought as well just wondering if anyone has actually tried it to see if it is too big or stiff. I just picked up the 2" Fastcap Stache and will be installing that soon but am in need of a larger hose for the new CT MIDI that is dedicated to the Kapex. Just trying to deside which size to get.
Thanks!
Offline ChuckM
Re: Kapex Question
« Reply #20 on: May 12, 2020, 10:16 AM »
You're welcome.
The reason I got an extra rubber hood to install the stache is that when you cut very thick stock, you want to fold the hood back so it doesn't get in the way when you do the cuts. With the stache added, you can't do that. I don't remember the exact cost, but a spare hood shouldn't be too expensive.
« Last Edit: May 12, 2020, 10:18 AM by ChuckM »
Offline FestitaMakool
Re: Kapex Question
« Reply #21 on: May 12, 2020, 11:05 AM »
In case you’re going for a 50mm hose. Don’t choose the Festool antistatic, it’s heavy and rigid.
The standard 50mm Festool or similar would be a lot lighter and more flexible.
I bought an extra AS 50mm 2m hose as a part of a deal on a pre-owned boom arm, with intention to use it with the Kapex. But no, unless you find a way to support it and make it follow the saws movement. That would quickly equal stationary use. Just an observation.
Offline Medickep
Re: Kapex Question
« Reply #22 on: May 12, 2020, 03:44 PM »
Chuck-
Thanks for the links.  I think I will try the larger hose diameter and eventually use my DD since i have it.  I'll probably keep the hose as short as possible.  Does Festool charge a lot for the fittings on the tool end as well as the CT connection?
Offline Medickep
Re: Kapex Question
« Reply #23 on: May 12, 2020, 04:18 PM »
Anyone try this hose?  I'm going to most likely cut my up for my DD, so I hate to drop both legs and arms on the Festool one!
https://www.amazon.com/Bosch-16-4-Foot-Vacuum-VAC005/dp/B0000AV78B/ref=sr_1_6?dchild=1&keywords=36mm+suction+hose&qid=1589314590&sr=8-6
Offline lawhoo
Re: Kapex Question
« Reply #24 on: May 12, 2020, 08:52 PM »
I bought that hose and cut it in half. Works great.
Offline Medickep
Re: Kapex Question
« Reply #25 on: May 12, 2020, 09:39 PM »
Thank you for the response!!  I was just winding if that has had fittings that could come off!  My plan was to cut it off and use the ends for the Kapex and DD.  Wasn't sure if I should order two or if they sold the fittings separately too!
Offline ChuckM
Re: Kapex Question
« Reply #26 on: May 12, 2020, 09:57 PM »
Chuck-
I don't know anything about the Festool fittings. When I hook up tools to DD or a shop vac, I make connectors out of whatever I can find in the shop such as tubes, old shop vac hoes, etc. Too large an opening, i use electrical tape or plumber tape to make the fit; too small? Sand it larger, etc.
Offline Bohdan
Re: Kapex Question
« Reply #27 on: May 12, 2020, 10:33 PM »
I am using an old shortened shopvac 50 mm hose. The shopvac fitting goes on the DD and on the other end I adapted a PVC plumbing fitting onto the kapex and the shopvac hose now fits the kapex.
Offline Medickep
Re: Kapex Question
« Reply #28 on: May 12, 2020, 10:53 PM »
Chuck-
Solid copy on that! Thanks.  I was attempting to over think it, which is what I do!!😂
Offline Medickep
Re: Kapex Question
« Reply #29 on: May 12, 2020, 10:56 PM »
Bohdan-
Thanks for the response!  May just be easier for me to wait until I actually get the saw! Was just trying to be proactive while I wait for it!
Offline CeeJay
Re: Kapex Question
« Reply #30 on: May 13, 2020, 04:20 AM »
Cheers all. Been pondering better extraction on my (Makita) mitre saw. Just ordered that Bosch 36mm hose. A sweet $200 less than the Festool one.
Offline HiCal
Re: Kapex Question
« Reply #31 on: May 14, 2020, 09:35 AM »
Thanks FestitaMakool! That is a very useful bit of info.
Offline Medickep
Re: Kapex Question
« Reply #32 on: May 16, 2020, 09:14 PM »
Thanks for all of the help.  I wanted to follow up with what I ended up doing in case someone else runs into the same thing.
I ended up buying this 35mm hose:
https://www.amazon.com/gp/product/B0000AV78B/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
The smaller end fits into the Kapex and the larger end fits right into my CT36.  I bought an adaptor that threaded right onto the hose for $15 dollars and had some other adaptors lying around that I used, so I could shorten up the hose.
Offline CeeJay
Re: Kapex Question
« Reply #33 on: May 16, 2020, 09:17 PM »
Great thanks for following up. I ordered the same hose. Should get it next week.
Offline Medickep
Re: Kapex Question
« Reply #34 on: May 16, 2020, 09:27 PM »
I had a more detailed follow up with pictures, but after do the post three times, I gave up.  Unless I have different rules because I'm new, this site seems to have a lot of quirks!
Online Rick Herrick
Re: Kapex Question
« Reply #35 on: May 16, 2020, 10:21 PM »
I bought the same hose 2 months ago.  Its a great hose.
Offline ChuckM
Re: Kapex Question
« Reply #36 on: May 16, 2020, 11:23 PM »
You need to compress the size of the images. Make them each smaller than 1MB....Mine are usually 350k or so.
« Last Edit: May 16, 2020, 11:38 PM by ChuckM »
Offline CeeJay
Kapex Question
« Reply #37 on: May 19, 2020, 12:27 AM »
Received the Bosch 35mm hose today.  Came from Bosch in Kentucky to Brisbane Australia via Amazon in 6 days. Great service.
What a difference it makes! Cut the hose down to about 1300mm and the fittings are a perfect fit into the CT Midi and the Makita at the other end.
Dust collection is probably twice as good now. Happy days!
« Last Edit: May 19, 2020, 12:31 AM by CeeJay »
Offline Medickep
Re: Kapex Question
« Reply #38 on: October 06, 2020, 03:09 PM »
So I’m at the disadvantage of not using my kapex much without the dust deputy or a fence attached much.  I noticed the saw was shooting little pieces of wood across my garage like rockets, so I added the fence to prevent that.  I’ve noticed the dust collection has diminished and was looking for ways to prevent that! The easier option I suppose is to remove the dust deputy, but I would think that’s causing much restriction!
Thanks!
Re: Kapex Question
« Reply #39 on: October 07, 2020, 10:46 AM »
The first thing I'd do is to shim the zero clearance insert in the table to be flush with the table top. Insert some thin washers and shim it up flush but do not go higher than flush. That alone should make a difference in the amount of projectiles. It should look similar to this.
Then make sure the blade is adequately recessed in the ZCI. There should be no space between the blade and the back of the vertical fence.
Here a straightedge is placed against the fence and the blade is lowered and pushed completely rearward to the fence. This is how I received the Kapex. This produces a lot of little projectiles.
Here the blade has been lowered so that it's completely inside the ZCI and there is no daylight between the blade and the fence.
Online Rick Herrick
Re: Kapex Question
« Reply #40 on: October 07, 2020, 11:00 AM »
Is this meant to 'make sure you push the blade all the way down before finishing the cut', or are you suggesting some calibration to get to this point?  I am still on the fence about ordering my Kapex so this information is very helpful to me.
Re: Kapex Question
« Reply #41 on: October 07, 2020, 11:48 AM »
Rick, there's a blade height adjustment on the Kapex. The photo of the blade being above the ZCI is how the Kapex was delivered with the saw head fully depressed and moved fully rearwards to the fence. Because of that, I was experiencing a lot of small projectiles being bounced around the shop. I've owned several miter saws but never experienced the projectile issue before.
Once the blade height was adjusted the issue went away. A combination of the "prop wash" moving the off cut around while the teeth on the blade are still exposed and they can catch an edge.
Online Rick Herrick
Re: Kapex Question
« Reply #42 on: October 07, 2020, 11:55 AM »
Thanks Cheese, very good info for us Kapex rookies. Going to check my Bosch now to see if I have that issue.
Offline ChuckM
Re: Kapex Question
« Reply #43 on: October 07, 2020, 11:59 AM »
The blade height adjustment is set by a human, the one who assembles the saw or QC it before it leaves the factory. My Kapex didn't have the problem illustrated by Cheese when received. Simply follow Cheese's good advice and check on the height adjustment knob (i.e. lower the blade if it isn't already set to the bottom in the factory). Remember to reset it if you have changed it, say, to make some dado (trench) cuts.
Also, wait for the blade coasting to stop because lifting up the sawhead/blade.
« Last Edit: October 07, 2020, 12:02 PM by ChuckM »
Offline Medickep
Re: Kapex Question
« Reply #44 on: October 13, 2020, 11:26 PM »
(Attachment Link)
(Attachment Link)
(Attachment Link)
Thank you for the tips!! I will take a look at this ASAP!!  For the money, I would have hope it came setup right!  As far as the dust collection is concerned, I realized I had inserted the hoses wrong after I redid my work bench when I got the saw!!😂😂
I will also do the shim suggestion! Get reaquated to the metric system😂
Online Rick Herrick
Re: Kapex Question
« Reply #45 on: October 14, 2020, 09:16 AM »
My Kapex is still not here, even though I was told it was in stock... I sold my Bosch is 2 days so I hope the Kapex gets here soon.
Concerning electrical.  My garage still only has 1-15a circuit.  I have had many issues with this.  On my Bosch, I had a smaller 4hp Ridgid and and IVac.  I never tripped the breaker.  But wondering now about the Kapex.  I am assuming that the Kapex with the CT26 will trip the 15a?  I may get another smaller Ridgid (I sold the one with the Bosch) and see if that will work until I can figure out adding some circuits.
Offline Medickep
Re: Kapex Question
« Reply #46 on: October 14, 2020, 01:08 PM »
Cheese-
I pulled the lever forward and lowered the blade as much as possible and than raised it back up. The following image shows how it looks now. Does this look right?
Re: Kapex Question
« Reply #47 on: October 14, 2020, 03:05 PM »
Cheese-
Ya it looks good...don't forget to shim up your ZCI. Cut up some scrap and compare the before & after.
Offline Medickep
Re: Kapex Question
« Reply #48 on: October 15, 2020, 08:26 PM »
Thank you sir!  Will be raising the throat plate soon!
Offline Bugsysiegals
Re: Kapex Question
« Reply #49 on: October 15, 2020, 10:52 PM »
Is it better to buy a ZCI or make your own?
Re: Kapex Question
« Reply #50 on: October 15, 2020, 11:49 PM »
It depends upon how much time you have to ignore other items that are on your list of things to do.
Offline ChuckM
Re: Kapex Question
« Reply #51 on: October 16, 2020, 01:09 AM »
Buy. A ZCI is a consumable. Fastcap's is about $1 a piece. I'm using my second one and my saw is 5 years old.
Aluminum ones use replaceable inserts, but are more pricey.
