Sure, why not use the Kapex MFT/3 as an alternative.
It is exactly the same table as MFT/3. You may use it as a cutting station, with the same accessories as with the MFT/3 kit.
You may also make a trolley/cart underneath to be able to move it around, and still keep it lower than it’s larger brother.
Recently I saw Ron Paulk made his carts for his workbenches. Just as I’m about to make for my Kapex MFT. Only, I’m being tall, so I’ll match the height of the MFT/3 - so that for me I can use it as a rolling table in conjunction with the other accessories and as a widening table and an outfeed table.
It is as sturdy as MFT/3 no less, but by using the same dimensions for the legs, frame and top the smaller size makes it feel a bit more stable and chunky. And it is very portable in comparison.
I’m having mine collapsed to grab and quickly extend outside for rough cutting, jigsaw use, small sanding tasks and so forth.
