Author Topic: Is the HL850 Planeer what I need?  (Read 1634 times)
Offline JeremyH.
« on: February 14, 2021, 12:23 PM »
I have a perhaps long term project coming up where I'm going to need to cut down 2" round wood that pokes through the surface of other milled wood. It'll be at an angle so some of it will be higher and some of it will be lower. I'm not sure if the HL850 will work.
Basically I'm trying to flush cut something that is only partially proud. Sure I could use a flush cut little saw but they seems to wonder off once you get near the area that isn't so proud. Would i use it then the planer?
This surface will never be seen. But for laminating purposes it must be flat.
The Virutex edge lipper also makes some sense, as I believe it allows you to cut down stuff that is pretty tall. It's also barely wide enough to get it all. I'm not sure how much of the machine will be on the surface for the first pass of 4 (they're legs).
CXS;RO150;ETS EC 125/3 EQ;CT26e  KSS400;MT55cc;DDF 40
Offline JD2720
Re: Is the HL850 Planeer what I need?
« Reply #1 on: February 14, 2021, 12:34 PM »
My experience with planing is that it does not plane well. The lipping planer would be a better choice that the HL850. The lipping planer would give some depth of cut control.
I believe the best option would be a router with a skid shoe base. Or cut it close with a saw & finish it with a sander.
Offline jobsworth
  • Festool Baby.....
« Reply #2 on: February 14, 2021, 12:35 PM »
it will work not sure if its the best way.
 Need photos,
 you'll prolly need the accessory fence with it to
Offline ScotF
« Reply #3 on: February 14, 2021, 12:44 PM »
I would try and use a router and sled. A hand plane could work too, not powered. Even a sander like the Rotex could work.
Offline JeremyH.
« Reply #4 on: February 14, 2021, 12:55 PM »
Another member posted this. This is about the same thing on the top except I'd probably have one side of the proud part be flush-ish with the top.
Offline JeremyH.
« Reply #5 on: February 14, 2021, 12:56 PM »
A router may work alright but I'm sure I would have to plane it a little afterward. It must be flat with the surface for lamination.
Offline Joelm
« Reply #6 on: February 14, 2021, 01:04 PM »
What about getting a block plane? It would be just a bit extra effort but you get a lot of control. Way cheaper than HL850.
Offline JeremyH.
« Reply #7 on: February 14, 2021, 01:06 PM »
Sure. I'd probably want to take it down a little bit with something else first but to finish with one would probably be good.
Offline Joelm
« Reply #8 on: February 14, 2021, 01:11 PM »
On my last table I had flipped the legs upside down and glued blocks as a support for the table top. I thought they would be flush but t they ended up being about 1/8" too high.  I grabbed a scrub plane and got it flush with just a few minutes of work. If it was to be visible and not under the table I would have then used a block plane or smoothing plane to clean it up.
Offline Alex
« Reply #9 on: February 14, 2021, 01:20 PM »
+1 This.
Then finish with a sander.
The 850 is no good here.
Offline Svar
« Reply #10 on: February 14, 2021, 01:35 PM »
Flush cut saw / chisel, sanding. It's faster than setting up router, unless you need to do hundreds of those.
Besides, trimming through tenons by hand is so satisfying, and no earplugs or dust collection is a bonus.
« Last Edit: February 14, 2021, 02:02 PM by Svar »
Offline Frank-Jan
« Reply #11 on: February 14, 2021, 01:58 PM »
I think this would work:
« Reply #12 on: February 14, 2021, 01:58 PM »
Agree with Svar.
I like the Lee Valley flush cut saw.
“Sure I could use a flush cut little saw but they seems to wonder off once you get near the area that isn't so proud.”
Just keep a couple fingertips resting on the blade as you saw and it won’t climb. Besides, what little wood left behind if it did climb (because there was less than a kerf thickness of wood to keep the blade from climbing) is quickly chiseled or sanded off.
Offline SRSemenza
« Reply #13 on: February 14, 2021, 02:30 PM »
Since it won't be seen just cut them close and sand the rest. I have used Multi tool to cut things like this. Just cut slightly high by eye (1/32 to a 1/16) to avoid any real gouging. Takes seconds. Then finish with a sander. Do you have a Rotex?
Offline FestitaMakool
« Reply #14 on: February 14, 2021, 02:52 PM »
I wouldn’t stop you buying a HL 850, but a genuine Japanese flush cut saw and sanding is all you need. If you don’t own any Japanese saws yet, it’s high time for it [big grin].
Offline usernumber1
« Reply #15 on: February 14, 2021, 03:23 PM »
hl 850 is more construction less furniture making
Offline Bertotti
« Reply #16 on: February 14, 2021, 03:27 PM »
flush-cut saw
« Last Edit: February 14, 2021, 08:04 PM by Bertotti »
I want to populate SD with trees because I miss the forests of the river bottoms.
Offline JeremyH.
« Reply #17 on: February 14, 2021, 04:16 PM »
If I get a Rotex what size? Would I regret going either way?
Flush cut or router will probably need sanding.
Athough this might work perfect following the flush cut saw.
https://www.woodcraft.com/products/woodriver-small-chisel-plane?gclid=CjwKCAiAsaOBBhA4EiwAo0_AnGBBr4rZHtQzQD79SQVQwN-MlsjHpxlzrtH-3Eyg4Ymh6DXJgvQMFhoCtc8QAvD_BwE#
Offline Birdhunter
« Reply #18 on: February 14, 2021, 05:45 PM »
When it’s necessary to get a flush cut perfectly flush, I hold the blade down right next the the wood being cut while applying a bit of twisting on the saw handle. I also, start the cut from both sides then go all the way through. If necessary, I sand with the sandpaper on a block of wood. I got my Japanese saws from Bridge City. The blades are super sharp and flexible and replaceable.
Birdhunter
Offline ScotF
« Reply #19 on: February 14, 2021, 07:02 PM »
I think the 150 is a good all around size. If you can hold them or try them at your local dealer that will help you determine what size suites you. I have both sizes and they each excel in their respective areas. For bigger flat area, I would opt for the Rotex 150. If you sand mostly smaller areas, then the Rotex 125 might be better. The handles of the 125 are smaller than the 150 and it is less powerful. I like them both.
Offline Don T
  • Phoenix, Az
« Reply #20 on: February 14, 2021, 07:21 PM »
I would use a router then hit it with a sander.
Offline contendernut
« Reply #21 on: February 14, 2021, 08:36 PM »
When I first handled the 125 and 150 in the store years ago, the 125 felt more comfortable. After buying and using the ro125, I never really liked it and always used something else. Not long ago, I switched to the ro 150 and it is like day and night. I don’t know if something was wrong with the 125 but the 150s extra size and weight seem to really calm it down with the way that I use it
Offline mino
« Reply #22 on: February 15, 2021, 06:36 AM »
You want to first cut it, either manually or with a router.
Then for the sanding step the Rotex would work well and as mentioned 150 is the preferred size. But you still need to flush-cut or almost-flush-cut the material before sanding.
The Machine does not have a brain. Use Yours!
Protool: AGP 125, VCP 260
My Precious: 376, 376, 376 holy, 632, 1016 holy, 1400 holy, 2400, GECKO, GRS 16 PE, GRS 16 PE
Offline JeremyH.
« Reply #23 on: February 15, 2021, 06:00 PM »
As mentioned in my other thread, picked up onsale Rotex 150 today! And a good recommendation on a baby router for initial clean up.
Thank you for all the thoughts and suggestions.
Offline jarbroen
« Reply #24 on: February 16, 2021, 05:16 PM »
Veritas makes a really good flush cutting saw.  More geared towards cutting off plugs, but might work for you. One size of the blade the teeth are smooth, not likely you will scratch your surface material. Less final sanding needed.
