Good question, had t considered that. What are your impressions of the CT15 and what are you using it for?
I’m considering getting one for dedicated use for the Kapex.
This new extractor is intended for use with the DF500, PRO95 sanders and any other general dust collection duties (cleaning the workbench, say). Previously, they shared the use of a shop vac/Dust Deputy with the Kapex, which means I had to switch hoses all the time (36mm for the miter saw). My Kapex produces a lot of saw dust as I use it often, so the DD approach is a better approach in my case.
If you don't use the saw on a weekly basis or make lots and lots of cuts each time, the CT15 is a great-value choice. I did buy an extra pack of 5 bags ($48 Cdn?), and that should last for many years.
I find the CT15 comparable to the CT26 I previously owned in operation. Compared to the old CT26, the CT15 stores the cord in a lidded holder. Its dust bag collection design looks good, as explained here:
I took the opportunity to measure the noise levels, using a cheap sound level meter:
- Room sound pressure level: 45ish
- Max suction: 84ish
- Min suction: 75ish
- Fan box filtration (cfm: 2500; Merv 11 filter): 72ish
