Author Topic: I have an extra 1400 rail, worth it to cut it down?  (Read 496 times)
Offline Grits
« on: November 15, 2022, 04:39 PM »
I have an FS 800/1080/1400x2/1900. Has anyone here cut a track down to a smaller useful length than 800? I can’t think of any applications I would want something that small so I’m thinking of selling it. My only thought where it could be beneficial is for a router track when working on very small stock.
Offline GoingMyWay
Re: I have an extra 1400 rail, worth it to cut it down?
« Reply #1 on: November 15, 2022, 05:21 PM »
TSO sells a GRE-13 Guide Rail Extension that's 346mm long to be used with a 1400 rail as an alternative to having a 1900 rail.  Since you already have a 1900 rail that wouldn't really be helpful.  It appears that Tom Silva cut a rail to size in order to fix an uneven floor joint, but that was a very specific use case:
I can't think of a generic application where it would be beneficial to have a rail shorter than 800mm.
Inquiring Minds Want to Know
Offline squall_line
« Reply #2 on: November 15, 2022, 06:02 PM »
I want to say that one of our Aussie friends has shrunk their rails to a few "optimal" lengths, but it may have been a non-Aussie.
I have the GRE-13 from TSO and used it for the first time this past week to rip a shelf board that was 1360 mm long.  Rather than unpack my 1900 rail, I grabbed one of my 1400s, unboxed the GRE-13, connected it (I purchased it with a set of connectors) and went to town.
Biggest lesson from that came when the outer splinter guard (the green one) on the TS55 caught on the clear splinter guard on the rails because I hadn't previously trimmed all the way to the end of my 1400.  It was my first time using the -13, and it finally found its way snugly into the TS55's systainer when I was done.
Offline Crazyraceguy
« Reply #3 on: November 15, 2022, 06:08 PM »
I think that @mino is the one you are referring to. Czech?
He has an entire explanation of the optimal cut up sections.
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT26E + Workshop cleaning set
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
MFT clamps set
Installers set
Centrotech organizer set
Socket/Ratchet set
Offline squall_line
« Reply #4 on: November 15, 2022, 06:22 PM »
As I hit "post", mino came immediately to mind.  I think you're right, and I may have gotten him mixed up with Mini Me. :)
Offline 4nthony
    • Slack for Recon Tools
« Reply #5 on: November 16, 2022, 06:57 PM »
Check my post:
https://www.festoolownersgroup.com/festool-jigs-tool-enhancements/track-sawguide-rail-bevel-jig/
I wonder if a rail cut down to 400-500 would be a useful length for the rail jig in the video?
Recon Tool Notifications
Anthony
