Author Topic: How many Sanders do you have & why  (Read 2461 times)
Offline ScotF
Re: How many Sanders do you have & why
« Reply #30 on: May 16, 2020, 01:27 PM »
I forgot the Fein MM with the profile set!
Offline deepcreek
    • TimberFire Studio
« Reply #31 on: May 16, 2020, 06:21 PM »
I prefer not to answer.  (Fourteen)
Joe Adams
TimberFire Studio
Houston, Texas
Offline leakyroof
« Reply #32 on: May 18, 2020, 12:51 PM »
Festoholics!!!
Is your wife named Sandy/Sandra or if I do start a Router thread is her name Rowdy!?
BTW, I’ll buy any/all tools for what you told your wives you paid for this stuff!!
I can’t imagine what your shops look like.
I should only have a Jr membership or Read-only privileges
I can’t honestly imagine what I would need them all for?
  Some of them are bought for a particular project ,and then other uses for found for them later on.
Offline yetihunter
« Reply #33 on: May 19, 2020, 03:53 AM »
Used to have heaps of sanders:
Elu 1/3 sheet & Festo RS3E & RS1C 1/3 & 1/2 sheet Orbitals, plus an old 1/3 sheet B&D "linear action" sander that wasn't really.  Plus a Festo RS4 & Bosch GSS16A Palm sanders.
Couple of Bobbie Bosch(small) Deltas & a Festo Deltex
Couple of Festool LS130 Duplex Linear sanders, plus a swag of custom & OEM profiled bases.
Bobbie Bosch PBS 75AE, Kango Wolf 2424 & Festool BS105E kit belt sanders.
Mafell/Kress UX150 & Festo RO 150E 150mm dual action ROT(ary)/EX(zenter) gear driven sanders
Mirka DEROS ROS in 2.5, 5.0 & 8.0 diameters.
Mirka DEOS Orbitals in small, large & delta configurations.
Metabo SXE400 detail RO Sanders (70mm dia.) - no less than FOUR!!
Triton Random Orbital Sander attachment (for an Angle Grinder).  Super fast, super messy!
Fein FSC 500 QSL sanding attachments.  Absolutely useless as a sander!
As to what you want, need or (dare I say it) should get, well that all depends....  Time will tell.
I've refined my own collection down from the rather ridiculous 2 dozen odd to a much more rational 10 for my own SPECIFIC NEEDS.
The old Festo orbitals were good, but also fairly slow: a common characteristic of all orbitals.  The Elu eventually wore out.  Orbitals are useful for fine flattening, & especially good at fine denibbing between paint & lacquer coats.
My small Mirka DEOS serves this purpose well, & takes the same size paper as the Festool Duplex & RS400 & the Bosch GSS16.  My only orbitals are now the small DEOS 80x133 & Delta.  Probably the Delta only would suffice at a pinch. The Mirkas are simply a better sander, having a larger (faster) 3mm orbit, lighter weight & superior balance to all others.  The larger DEOS with a plasterer's shaped & sized pad eventually just became surplus to requirements.
Detail work is undertaken by the 2 Bosch Deltas (PDA240 & GDA280), which I prefer due to their system of extra sanding fingers, custom profiles that I've made & louvre extensions, which is why I still use 2.  The tiny Metabo SXe400s are gems, allowing fairly fine concavities & complex mouldings to be smoothed & polished (i.e car headlights etc) in places any other sander can't.  Which is why I keep one only spare.  These were also ideal tools for the tiny hands of my young children, which is why I only retain a couple now.
The Festool Duplex LS130s proved utterly hopeless.  Worst tools (with the possible exception of Festo/ol's execrable cordless drills) that I've ever owned.  Despite dual counter-rotating counterweights, they're simply too vibratory for extended use, clog papers like a mo-fo, & their profiled bases literally crumble into uselessness with alarming & expensive rapidity.  Just....don't.  A hand block is actually faster!
Belt sanders have been reduced to the one big Festool BS105E.  With its fine belts & its fabulous sanding frame fitted, it's uncharacteristically smooth & fine, or as aggressive & rapid abrading in coarser grits as anything other than a dedicated floor sander.  I'd probably still have the small Bosch too, but for the fact that it was nicked.  A belt sander will do everything & more that any Rotex sander can do, but much smoother, easier & faster.  Provided the sanding frame is fitted.
As you've undoubtedly noticed the Rotex tools can become a bit of a handful at times, & must be firmly gripped & carefully guided.  A belt sander doesn't:  its own mass & inertia does the work, requiring the lightest restraint but no pressure, but its speed & power means that it, too, must be kept in perpetual smooth motion over the substrate.
As far as random orbitals are concerned, I've found that the Mafell/Kress & Festool Rotexes are just a bit too big, heavy & rough for my ageing hands.  As you've already noted, they're a bit too rough to provide a fine finish.  The Mafell was rubbish (too much power for the relatively weak geartrain), & when I "found" the Mirka sanders, everything else simply pales in comparison.  Less than HALF the weight of the Festool (maybe 1/3 of the Mafell!), smoother running and far superior results to any other I've tried.  So good, in fact that I've personally found the 2.5mm diameter DEROS to be redundant.
I think the difference is in the papers:  Mirka's Abranet mesh abrasives are just fantastic.  To be fair, though, maybe a but too susceptible to tearing on sharp or hard edges.  But so are paper-backed abrasives too.  The Abranet ACE & HD abrasives are super long lasting & (incomparison to Festool's range) fairly inexpensive.  Dust extraction through Abranet abrasives is in my opinion unequalled.  Plus the huge number of holes in Mirka's sanding pads means that just about any other rogue abrasive will work & extract well too.
Don't think that I'm unneccessarily down on Festo'ol's sanders here.  They're all (with the exception of those stupid LS130s) good tools, but the world has moved on a bit in the past 40-50 odd years since they were originally designed.  Whilst Festools are good, Mirkas are great.  Where Festool's products often prevent anybody else's pads & papers being used, most others use common mountings, hole patterns & readily available sizes.  If Mirka's sanders seem a bit too expensive, then one of their licensed clones (Indasa, Rupes, Carsystem, Metabo, Delmeq or Sumaki) which use the same hardware will possibly save you a bit.
My single remaining Festool sander is the BS105E, mainly by virtue of its sanding frame & commonly available belt sizes (for which I actually had to shorten the distance between the rollers).  It even takes Abranet Ace belts.  Since Festool Australia sacked my 2 preferred local agents & repairman & gutted the retail network, it's near impossible to access regular consumables, spares & parts in a timely fashion.  The last straw for me was an over 3 month wait-time for a basic delivery of some abrasives & a replacement pad for one of my Duplexes.  My nearest Festo "retailer" doesn't even stock the flamin' products: thety just order 'em in as required/prepaid.  Blow that for a joke!
So the 4 Mirkas, 2 Bosch Deltas, a brace of Metabo detail randoms & the big Festo/Holz Her belt sander now comprehensively serve just about each & every one of my (unique) sanding needs.
You will undoubtedly require a different suite of abrasive tools.
P.S.  Just remembered that I also (shortly) owned a RO90 DX kit from Festool too.  This ridiculous excuse for a sander probably ties with Metabo's Porsche Multihammer as one of the worst designed power tools of all time.  It was just terrible, & more than any other has probably turned me away from "modern" Festool designs for life.
The OP is from Indiana.  The Holz-Herr belt made it here under some names (including AEG), but that was a long time ago.  Black and Decker brought over an Elu router towards the end of the 80’s that I owned, but I don’t think much else (the miter saw?) other than the lesser Dewalt versions.  Metabo has only offered the SXE 400 and the SXE 450.  It’s a running joke at a local store because their dead stock from ages ago is still up to date. Rupes is only known to upscale car detailers.  Flex is mostly only known to upscale car detailers.  I know of Kress, but I’m not aware of anything making it here without someone else’s name on it.  If I want Mirka locally, it’s going to be sandpaper that says Festool on it. Fein only offers one sander that you can get through boat building supply houses.  Bosch discontinued all of their detail sanders.  The delta Mirka just started showing up on one or two websites, but I haven’t confirmed if they actually have the stock.  Said Mirka is only going to be available in yellow.  Realistically, his options are going to be Festool or Mirka.  If there’s a Festool dealer near him, it’s going to be Festool. I just noticed that my 150mm pads are toast.  In about six hours, I’m going to drive 20 minutes east to pick up some replacements.  Any other brand and I’ll be flipping through exploded diagrams while preparing to place a parts order and then sitting around from anywhere between 3 days and six weeks. Not to mention Bosch and Makita having a different size hose port on every tool....if you’re so lucky that said hose port isn’t a separate accessory that can only be ordered from the parts department.   It’s a sad scene out here.  Festool made it a lot better.
« Last Edit: May 19, 2020, 03:58 AM by yetihunter »
Offline yetihunter
« Reply #34 on: May 19, 2020, 04:09 AM »
I have a RO150 only and was curious what some of the smaller or even another unit would benefit me? I’m new and curious if I’m missing something ?
I was thinking about having to stock all the necessary grits, extra space, cost etc and was just wondering if they do a better job?
I’m mostly happy with my current unit(other than some swirl marks at the extremely low end of grits get a lot of swirl marks I have to work at removing, btw: I have the suction set low and don’t adjust through rough-finish) and realize I’m kind of answering my own question just wondering?
I’d recommend some sort of delta or iron sander and a 5” finish sander.  Personally, I wouldn’t want to do anything but the rough stuff with the Rotex, and so I use a separate 6” random orbital where size dictates it.
Offline xedos
« Reply #35 on: May 19, 2020, 04:29 PM »
Quote
.  Bosch discontinued all of their detail sanders.   Not to mention Bosch and Makita having a different size hose port on every tool....if you’re so lucky that said hose port isn’t a separate accessory that can only be ordered from the parts department.
For future searches - this isn't entirely accurate.
Bosch, like Festool, have discontinued their purpose built triangle detail sander.  They have transferred that duty to their multi-tools that have dust fittings as part of setup.  Nowhere near what Festool's, Fein solution is , but hey .
They also have a new group of palm sanders to compete with Festool's ETS lineup , including a pointed pad model.   While not as refined or good at dust collection, there is a strong value proposition in that Bosch's version costs half AND has the ability to quick change the pads for three sanders in one.
Sadly   NAINA.   Yet.
Also, Bosch sanders may all have different catch containers - some borrowed from Rupes - but underneath they are one of two flavors.  Either a standard round port that fits Bosch and Festool rubber tool ends - or - an oval which requires a rs006  adapter which again has a standard round port for vac attachment.  That fitting has been around for decades and while frustrating that it's rarely stocked locally , it is available from the usual suspects via the internet.  I believe they ship with the sanders that use them these days too.   The trend clearly seems to be they come with a round port buried in the catch container.
Makita is a sad story though. Their ports seem consistent to me, but they don't work worth a flip.  Besides being too small a diameter to fit any vacuum hoses from the major players (including their own) , adapters are pretty difficult to source too.
« Last Edit: May 19, 2020, 04:35 PM by xedos »
Offline yetihunter
« Reply #36 on: May 21, 2020, 10:44 PM »
@xedos
Yes, I mangled some things there whilst typing past my bedtime.  Not only are you correct about the ports,  Bosch’s respective dust collection accessories are hanging right over their tools at my local shop (the routers, jigsaws and hammers, primarily).
Offline Vondawg
« Reply #37 on: May 22, 2020, 07:43 AM »
How about this palm sander
 [https://www.instagram.com/p/B2Wlc-Wg__k/?utm_source=ig_web_button_share_sheet
« Last Edit: May 22, 2020, 07:46 AM by Vondawg »
