Author Topic: How many Routers do you have and why?  (Read 2274 times)
Offline Thompmd
« on: May 16, 2020, 01:03 PM »
I have a buddy that had 9 at one time when he built cabinets for a living dedicating each to a profile /task.
I am going to purchase an OF1400 soon?
Sawstop Industrial Saw, TS75,2 1400 rails, CT36, Rotex RO 150 FEQ, CT-VA-20, Carvex PS 420 EBQ, Carvex acc. ZH-SYS-PS 400, Kapex KS 120, CT Cyclone Dust Collection Pre-Separator CT VA 20, DF 500 Q Set, Domino 1,060pc Tenon Assortment, UG-KA-SET Portable Imperial Stand & Extensions,
Offline Peter Halle
Re: How many Routers do you have and why?
« Reply #1 on: May 16, 2020, 01:43 PM »
I have three routers but only one is a Festool.  Besides my 1400 - the one I regularly use - I have  Porter Cable 760 and a Porter Cable trim router.  Since I bought the 1400 the others have collected dust.
Online elm
« Reply #2 on: May 16, 2020, 01:51 PM »
I have four that I use.  I use the 1010 for shelf pins, and some general easy routing, the 1400 for more 'heavy duty' routing with my 1/2 in bits, a porter cable that is mounted in my router table at all times and a Rigid palm router for trim and quick roundovers.
Offline Alex
« Reply #3 on: May 16, 2020, 02:21 PM »
Just the one, a 23 year old DeWalt/Elu router for 8 mm bits that's still going strong.
I would love to add a 1400 but it's just too expensive for the limited use I have for it. Though I use my router pretty often it's mostly just bits up to 25 mm wide but not bigger.
Offline Roseland
« Reply #4 on: May 16, 2020, 03:20 PM »
A total of five.  I started with a DeWalt DW621, which is great for some hand held work as the base is asymmetrical. The only downside is that the dust port is so high it tends to tip the router.
Then I wanted a 1/2" for a table and got a Triton MOF001, which I think is one of the best routers at any price for use upside down, with automatic spindle lock and through the table adjustment as standard.
The third purchase was an OF1400, because I wanted to be able to use 1/2" bits without taking the Triton out of the table each time.  I love the height adjustment system.
Then followed an OF1010 with edging accessories; these really add to its versatility.
Finally I inherited my father in law's Bosch POF 500, which I rarely use.
I like all of them, but they are so very different in their uses.
Andrew
TS55, MFT/3, OF1400, OF1010, CT26, RS100, ETS125, CXS, MFS400, DF-500, Zobos.
Offline mrFinpgh
« Reply #5 on: May 16, 2020, 03:22 PM »
I have four: OF1010, OF1400, Dewalt611, and a Milwaukee 5625.
The Milwaukee is basically dedicated to my router table, while the festools are used for anything involving plunge routing or edge trimming.
The dewalt is great for things where the edge is narrow or the profile is just a roundover or chamfer.  I have also used it for things like very shallow mortises on doors for pulls.
Offline gunnyr
    • Compass Custom Creations
« Reply #6 on: May 16, 2020, 04:05 PM »
N - 1 [big grin]
I have five currently. A Triton dedicated to my router table, anOF 1400, an MFK 700, a Ridgid trim router and a trusty Rusty Porter-Cable 690.
I can always use one more!  I keep thinking about the cordless Dewalt router because Festool doesn't have a cordless router! I also keep looking at the OF 1010, no particular reason
Semper Fi,
Jeff
TS 55 REQ|HKC 55|PSB 420|DF 500|ETS EC 125/3 EQ|ETS 150/3|DTSC 400|RO 90|RO 150|OF 1400|MFK 700|LR 32|MFS 400/700|CXS (2)|PDC 18|DWC 18-4500|CT MIDI|CT 26|CT 48|MFT/3 (2)|VAC SYS-SET|DUO-SET|SYSLITE KAL II
Offline bkharman
« Reply #7 on: May 16, 2020, 04:15 PM »
I had three (only blue and green is my 1400, which I love) but now am down to two. 1400 is the workhorse and a trim router for minor round overs etc.
I really want a 2200 but might end up getting a spindle molder which would negate the need for me. We shall see.
Cheers. Bryan.
People, I just want to say, you know, can we all get along? Can we get along?
Offline ear3
« Reply #8 on: May 16, 2020, 04:18 PM »
I think the bare minimum if you're looking to cover most of your bases is 3.  A dedicated table unit (Triton is a great option for the above the table adjustability), a heavy duty handheld one like the 1400 or 2200, and then more of a grab and go lighter duty router like the 1010.  Anything over 3 is good to have, but not absolutely necessary.  I prefer the 2200 to the 1400, but there are situations where I need the smaller footprint of the 1400 while running a 1/2" bit.   I don't use the MFK 700 all that much, though there are some people on the FOG who use it all the time and swear by it.  It has saved my bacon a couple of times set up with the vertical base and planing bit to level some surfaces.  The only regular use it gets now is when I'm edge banding.
I recently picked up a cordless Dewalt because I had to do some edge work in the field without access to power -- I really like the unit, and have recently taken to having it set up with a dedicated roundover bit when I'm using other routers.  I did get the plunge base accessory, though have yet to experiment with it in plunge mode, or even hooking it up to dust extraction for that matter.
Offline rst
« Reply #9 on: May 16, 2020, 04:44 PM »
Hello, my name is Steve and I am an addict.  I have six PCs, three Bosch and five Festool.  I'm afraid to count my sanders and saws.
Offline pettyconstruction
« Reply #10 on: May 16, 2020, 04:52 PM »
I have 4
Porter-Cable 690
3- makita compact routers two are cordless and one corded.
I have a different round over bit in the cordless and a upcut in the corded.
I’m looking hard at a 1400 and another cordless makita.
Hate changing bits lol
Cheers Charlie
Sent from my iPhone using Tapatalk Pro
Offline Kevin D.
« Reply #11 on: May 16, 2020, 05:04 PM »
Hi, my name is Kevin and I'm a tool junkie.  I have at least a dozen routers.  Close to 30 drills.  I'm just a hobbiest/DIYer.  Just love tools.
Best router is the 1400.  I also have the MFK 700.  Always wanted the 1010 just for my 32mm Festool stuff. One day.
Kapex, CT-SYS, SYS-Cart, Pro 5 Sander, CT36AC, TS75, MFT 1080, MF-SYS/2, PS300 EQ-Plus, Parallel Guides Set, LR32 SYS, RO 150FEQ-Plus, OF1400 EQ Plus, DOMINO 500 Q-Plus,  Domino XL, MFK 700 EQ-Set, FS-SYS/2, CT22 w/hose storage, D36HW-RS-Plus, FS 1900/2, FS 3000/2, FS 1080/2-LR32, FS 1400/2-LR32, Gecko, Festool Floor Mat, Festool Stein, Multi-Tool, tape measure, large and small Festool floor mats (foam rubber).
Offline deepcreek
    • TimberFire Studio
« Reply #12 on: May 16, 2020, 05:46 PM »
I have eight and they all serve different roles depending on bit and material size.
Two OF1010's, OF1400, OF2200, two Dewalt 611 trim routers (one is dedicated to inlaying our signature coins), Hitachi M12V (router table), and a Porter Cable laminate trimmer.
I'm not counting the Rotozip or Dremel even though they both have router base attachments.
Actually, two more if you include the ones inside the Porter Cable (Castle) benchtop pocket hole cutter.
My friend, Gary Katz, recommends having one more router than you have router bits!
Joe Adams
TimberFire Studio
Houston, Texas
Offline ScotF
« Reply #13 on: May 16, 2020, 05:52 PM »
I have 6 so far:
1010
1400
2200
MFK200
Bosch Colt Trim router
Milwaukee 5625 for table
Offline Mario Turcot
« Reply #14 on: May 16, 2020, 06:25 PM »
@rst you need help ROFL
1) I have the Ridgid R29303 2HP for the Jessem Router Table coming next week  [big grin],
2) Ridgid R24012 corded trim router,
3) Milwaukee cordless trim router,
4) Makita RT0701C on the CNC,
5) Dewalt DW616 as a spare for the CNC,
6) OF 1400 for handheld router other then trimming.
I will probably get a 3.5HP if the Ridgid do not hold for the tasks. The OF 1010 is also on my list.
« Last Edit: May 16, 2020, 06:47 PM by Mario Turcot »
Mario
« Reply #15 on: May 16, 2020, 06:27 PM »
How do you like the Castle pocket machine? I’m in the market for one but the Kreg is about 1/3 the price
Offline FestitaMakool
« Reply #16 on: May 16, 2020, 06:53 PM »
.. You should probably not count them! [big grin]
Again, I have a lot of collectible RC cars that I don’t count. Not insane amounts, but too many.
As a more of a newbie to routers, I have an old Makita 800W left from my father, my only experience with routers since investing in more..
A OF 1400 for the router table
A OF 1010 for handheld (unless need for the OF 1400)
A Makita 18V LXT handheld with all the bases. A fantastic and handy tool.
So that makes 4 already. Who knows..
Offline rmhinden
« Reply #17 on: May 16, 2020, 07:00 PM »
I have three routers, two that I use frequently and one not so much.
I started with a (now old) Ryobi 3hp plunge router and mostly used it in a home built router table.
I upgraded to router table to a Kreg table/fence/router lift and put a Porter-Cable 7518 in the table.  A great combination.
About 18 months ago I added a OF1010.   That works well for me for general purpose hand held routing and is very capable with 8mm shank bits.
The Ryobi hasn't been used since.
Occasionally I look at the OF1400, I have had a project yet that the justified the cost.   At some point I might add a small trim router.
Offline ChuckM
« Reply #18 on: May 16, 2020, 07:21 PM »
4 & why:
Bosch 2HP 1613AEVS -- Hand-held med. to large work (e.g. circle cutting) or Router table top (1/2" shanks)
Bosch Colt -- Hand-held small to med. work
Craftsman Sears (image) -- Router table top (1/4" shanks), small to med. work
Craftsman Super Router (1.5HP?) (image) -- Bought in a garage sale (in the 90s), rarely used, now collecting dust (with the Craftsman finish sander form the same garage sale) on the shelf...will be selling it after the pandemic
5, if the Dremel is counted as a router for grooving (image) and recess work (e.g. butterfly inlays, hinges, etc.).
« Last Edit: May 16, 2020, 07:45 PM by ChuckM »
Offline gunnyr
« Reply #19 on: May 16, 2020, 07:54 PM »
Sorry to go far off topic.....
Wait on the new Castle 110 Pocket Cutter.  They will be coming out with a new one shortly (COVID is delaying release).  The new version, Model 110, has an improved router and MUCH improved clamping mechanism.  I just bought a Kreg Foreman, I will add the Castle machine when the new one is released.  The biggest advantage of the Castle is that it has a 6 degree angle vs the 15 degree of the Kreg.  With the Castle the problem of joint shift is nearly eliminated.  You can easily assemble the joints without clamping.
To be sure the Kreg is faster but the Castle is MUCH more accurate.  Do not get put off by the two step process of routing the pocket and then drilling the pilot hole.  I saw the original Castle 100 at IWF 2018 in Atlanta and thought the two step process was a deal breaker.  I saw the Model 110 early this year at The Woodworking Show in Indianapolis and came to understand the advantage of reduced screw angle and the new clamping mechanism.
Semper Fi,
Jeff
Offline Thompmd
« Reply #20 on: May 16, 2020, 07:55 PM »
Those of you that mentioned the 1400.... what makes it your favorite?
Offline SoonerFan
« Reply #21 on: May 16, 2020, 08:30 PM »
Currently I have an OF1400 and an MFK700.  Will soon be three as I am planning to get a router table and will get a dedicated router for the table.
I got the OF1400 first.  I choose this because at the time I only wanted one and felt it was the best over all option.  I added the MFK700 when I had a project to make a bunch of charcuterie trays.  The MFK700 was the prefect round over solution for me on that project.
« Last Edit: May 16, 2020, 08:33 PM by SoonerFan »
Offline Holzhacker
    • www.aic-chicago.com
« Reply #22 on: May 16, 2020, 08:34 PM »
Porter Cable trim router from when I used to do a lot of laminate work
Old Skil / Craftsman I've had forever that I can't get rid of but never use
OF1010 main go to router
Big old 1/2" Bosch for the heavy stuff on the rare occasions I need it
In terms of guys who have 5 or 10. I had a friend years ago who was a cabinet maker. Can't even say how many routers he had. His point though was that he would set up each / as many routers as he needed for a particular cabinet job that use them throughout that job. No switching bits between routers, no new adjustments, etc. For him having to change bits or re-adjust depth was just dumb and inefficient. So if a guy tells me he's got 10 routers my first question would be how long have you been a cabinet maker.
Offline deepcreek
    • TimberFire Studio
« Reply #23 on: May 16, 2020, 08:40 PM »
I have the original Porter Cable version and prefer it to Kreg because of the lower angle holes.  Far less creep during assembly.
Joe Adams
TimberFire Studio
Houston, Texas
Offline CeeJay
« Reply #24 on: May 16, 2020, 08:54 PM »
I have three.
An OF1400 which I’ve only had 6 months. Love it so far.
A Makita trim router which I also love. So easy to use.
A Makita RP2301 which is going into the router table I’m building.
I sold my old Makita 3601B which I’d had for 10 years when I got the OF1400.
Not sure about the RP2301 for the table but bought it new in box as a bundle from a guy who had bought router/lift/fence etc but never started his table build so it was pretty cheap.
Just waiting on an NVR switch and I’ll get started on the router table conversation to my PM2000 extension table.
« Last Edit: May 16, 2020, 09:51 PM by CeeJay »
Offline Jim_in_PA
« Reply #25 on: May 16, 2020, 09:01 PM »
PC7518 in my cast iron table. OF1400 and OF1010 from Festool. Dewalt DW618 kit with three bases. I used to also have a PC 7529 plunge router, but I gave it to a friend. Hand-held, I mostly use the OF1400 and DW618 with the fixed base. Sometimes that fixed base is the better choice for stability and micro adjustment. Today, the OF1400 got the nod for cutting out a window opening in thick faux door skins for a home improvement project.
ETS 150/3, Rotex 150, OF1010, OF1400, Trion PS 300, TDK-12, CT-22, MFT 1080, TS55, Domino XL DF 700, 8' track, (2) 55" tracks
SCM MiniMax S315WS, FS350, MM16, Camaster Stinger II SR-44 CNC
Offline cpw
« Reply #26 on: May 16, 2020, 10:24 PM »
I have six.  I was at 5 until I started getting into the Festool routers; but gave away a 2 1/4 Craftsman plunge/fixed/d-base set after I added the Festools.
(1) A 3hp Porter Cable in the Table
(2) A small Dewalt trimmer (611) which is great for small chamfers and roundovers
(3 & 4) Two Dewalt 618s.  One is generally setup for the dovetail jig.  Not having to change the dovetail setup if you are doing a bunch of drawers saves a ton of time, but also having two routers for different profiles even if not a dovetail is useful.  Having the extra router be identical to the first is convenient because you can share extras like the guide rail attachment.
(5) I got a OF1010 for the LR32 system, but have also used it for a bit of edge profiling as well.  There is a fancy version of the Fastcap Little Lipper that makes flush trimming solid edge banding pretty easy and provides good dust collection/guarding while doing it.
(6) I managed to snag an OF2200 from the recon sale.  This is now my favorite handheld router, and the DW618s are gathering dust - except for the occasional dovetail setup.
Offline xedos
« Reply #27 on: May 16, 2020, 10:50 PM »
dammit, I just get out of the sanders anonymous meeting yesterday.
Now I've got to sign up for routers anonymous.
Craftsman small 1hp    - still has the best ergonomics, switch and depth adjustment of any small router I've used. Too bad it's not variable speed
Craftsman 2hp - with the internal dust blower contraption.  Bought on a lark before vacuum attachments were a thing.  Pretty much useless.
Bosch 1450  - was the first good plunge router I got.
Bosch GFK12- interesting little 12v palm router. Makes a mess though.
Porter Cable 890 x2 -  one in a router table , and one handheld with fixed& plunge bases
Porter Cable 7529 - mostly for circles. Dust collection rivals Festool.
DeWalt 618 - three base kit.  Mostly use the D-handle.
DeWalt 611 - sweet little plunge router.
Rotozip - strictly not a router , but I've got one setup with a spiral bit and their clear dust shroud base for cutting outlet boxes in cabinets.  Dust collection is far superior to any Festool router.
Festool 1010 - this gets used a lot.
Festool 1400- didn't like it and sold it on.
Dremel with the micro plunge base for tiny inlay work.
« Reply #28 on: May 16, 2020, 10:52 PM »
Sweet old Stanley 1/4” with a nice wide base
Big old Hitachi plunge router with just a single scary speed
Classic Porter Cable trim router, short and squat
Three Bosch trim routers with multiple bases (pre Colt) but two have bad bearings
Two Ridgid trim routers one better than the other
Makita single speed similar to the Stanley but all plastic
Makita cordless trim router
Small Milwaukee 1/2”
Medium size Milwaukee 1/2” plunge kit
Two medium size Bosch 1/2” one in a portable table and the other plunges
PC7518 in lift in cast iron table and a spare backup 7518 in a carton
Three OF1000
OF2200
Craftsman and B&D routers given away don’t count
Offline HarveyWildes
« Reply #29 on: May 17, 2020, 02:27 AM »
12
Started with with a 2hp Makita which I moved back and forth between router table and handheld use.  That lasted a couple of years until I got a router lift and put it in my shop-made router table.  I didn't want to take the Makita in and out of the lift, so I got a Bosch 2 1/4Hp router.  I got tired of switching that between the fixed and plunge bases, so got another, and then found yet another one with a D handle (used) which I like for dovetail jigs.  (that's 4)
Then I got a Bosch Colt because they are so easy to handle with smaller bits doing more detailed work.  I liked it so well, and got so tired of switching bits and setups, and then having to try to re-create setups, that I got a second Bosch Colt, and then a Rigid trim router.  So that set of routers served me well for maybe 10 years.  (up to 7)
Then my router lift started getting a bit weird to adjust, so I got a newer one, improved the dust collection, and put a PC beast in the new lift.  Around the same time I got a new DeWalt trim router because I thought the plunge base would be nice.  (now at 9)
In the last couple of years, enamored with Festool dust extraction capabilities, I added a 2200 to the arsenal, and the dust extraction is phenominal.  Based on that experience, I also added a 1400 and an MFK 700.  (now at 12)
Finally, this year I got the Milwaukee M18 cordless.  As I looked how to consolidate accessories to give me flexible setup, I managed to winnow out the Rigid.  (still at 12)
For router table use, I'll keep the PC and Makita routers, as I can now field 2 router tables if the need arises, and if I use rail and style bits or other bit sets that require the two setups to be coordinated, I would want to be able to do that.  The PC will get the bulk of the work, but the Makita is there when I need it.
For large handheld use, the 2200 is brilliant for clean routing, but the 1400 is easier to handle.  Between the two of them, they can do everything that my Bosch 2 1/4 routers can do, and they do it with less mess and with silky smooth operation.  Plus the supported Festool accessories add a lot of flexibility which I either have cobbled together, or would have to, for the Bosch routers.  I may offload the Bosch routers in the next year, but I do have a Micro Fence custom base on one of the Bosch routers that gets a fair amount of use, so I'll need to get adapters for the 2200 and 1400.  Micro Fence is a big deal for me.  The Micro Fence circle jig supports large diameter circle cutting - I've done one piece that had nearly a 2' radius.  The Micro Fence fence is the best fence that I've ever used.
For trim routing, I'll probably keep all of them, but right now I am super impressed by the utility of the Milwaukee cordless router.  Being free of a cord means that I can easily use it outdoors, which I like to do in good weather.  The Bosch Colt, DeWalt, and MFK 700 routers will get used for extra setups on projects that require them.  The DeWalt stays because of the plunge base.  The MFK 700 has some specialized uses that the other routers don't, so I'll probably save it primarily for those uses.
If you haven't seen it in operation, the Milwaukee M18 cordless router is awesome.  Things I particularly like:
  • The adjustments are positive and precise.
  • The motor break is awesome.  In theory it does not stop instantly, but in practice it might as well.
  • Dust collection is very good.
  • Other features are comparable to other trim routers on the market.
  • Runtime is suitable for more trim routing tasks, as long as you are not running it for long periods on end.  I'm using 5 Ah batteries and did not run out the battery while chamfering a project.
  • The only real disappointment is that there is no plunge base (yet).
« Last Edit: May 17, 2020, 02:34 AM by HarveyWildes »
Online thudchkr
« Reply #30 on: May 17, 2020, 06:06 AM »
Am looking real hard at picking up that M18 cordless. While looking at it, they also showed me the plunge base.
https://www.acmetools.com/shop/tools/milwaukee-48-10-5601
They also now have separate kis that come with the different bases, (offset and/or plunge).
I currently have the big PC beast in my router table, in a lift, and have a PC 690 that gets used with a dovetail jig. A Dewalt 617 that also pretty much lives with the dovetail jig, while a Makita 1100 resides with the Leigh MFT. A Bosch Colt with plunge base used to handle all the smaller handheld tasks, but got usurped when I started getting the Festool offerings.
My first Festool was the 1400, then picked up the MFK 700, the 2200 and finally the 1010. The Festools pretty much took over all the non-dedicated tasks which means I get to leave the others set up for specific purposes.
Pretty sure I’ll be acquiring that M18 though. The appeal of having a cordless router, and huge investment already in the Milwaukee M18, (and M12), lineup make for a good addition to the stable.
Clint
TSC 55, TS 75, HKC 55, DF 500, DF 700, Kapex 120, UG Ext. Wings, MFK 700, OF 1010, OF 1400, OF 2200, CT 22, CT 26, ETS 150/3, ETS EQ 150/5, PRO 5, DTS 400, RO 90, RO 150, RAS 115, CXS, DWC 18-4500, MFT Kapex, MFT 3 (2), MFT 800, MFT 1080
Offline Bert Vanderveen
« Reply #31 on: May 17, 2020, 09:06 AM »
As evident from my signature I am not ashamed to admit that I own every model of the current Festool router line up, except the 1400. And that one may be in the shop soon. Collections need to be complete, right?
Why I own two MFK 700’s? I happened upon a bare and barely used second hand machine that was very cheap, but discovered that buying the accessories separately was as expensive as buying a Set. So I bought a Set & to even things out I bought the lone MFK 700 its own Systainer and insert AND a guide of its own.
Cheers, Bert Vanderveen
TS55 · TS55R · OF1010 · DF500 Mk2 · MFT/3 + TSB1-MW 1000 + VL + CMS TS55 + CMS PS300 + LA-CS 70/CMS · CTL Midi · RTS400 EQ · 2 x CXS Li 1,5 · T15+3 Li 4,2 · TI15 Impact Li 4,2 · Centrotec Sets 2008 + 2015 · PSB300 · LR32-SYS · RO150 · Kapex KS120 · 2 x MFK700 · RO90 · OFK700 · BS75 · OFK500 · OF2200 · CMS-GE · Vecturo 18 Li · TID 18 · TKS 80 EBS-Set (next June!) … | Mirka 1230L P&C | Hammer A3 31 Silent Power · Hammer N4400 · Hammer HS950 | TaigaTools VacPods Pro Set
Offline blaszcsj
« Reply #32 on: May 17, 2020, 09:55 AM »
I have the 1010, 1400, 2200, and two cordless Dewalt trim routers.
I have one Dewalt set up with a white side round over and the other is left for flex setups. I would like to buy 2-3 more of these for other setups. Cheap as chips and really good router.
For corded activities I reach for the 2200. It is flat out a joy to use and I find it the most stable to use. I use the 1010 for the lr32 and odd trim jobs. 1400 comes out when I do multiple ops or just want to change it up. Overall I use them all interchangeably.
OF1010 EQ Router | MFT/3 | DF500Q | Mafell P1CC | ETS EC 150/3 | CT 36 Auto Clean | TSC55 | LR32 | OF1400 EQ Router | ZOBO Metric Set | CXS Li 2.6 - 90 Limited Edition | Universal Cleaning Set | HKC55 | Centrotec CE-SORT | RO150 FEQ | DTS 400 | RO90 DX | CTSYS | C18 Drill | SysLite KALII | Syslite STL 450 | RAS 115 E | OF2200 EB | OSC 18 Vectoro
Offline blaszcsj
« Reply #33 on: May 17, 2020, 09:58 AM »
Also I have the micro fence and adapters for all the routers. Best investment ever. Love the fence and circle jig.
« Reply #34 on: May 17, 2020, 10:10 AM »
I echo the Micro Fence recommend, that system is very slick. Adjuster backlash is in the .001" area. They also offer a metric adjuster as well. I have the adapters to use the Micro Fence on my Festool 1010, 1400 & 700. I'd suggest anyone new to router use, take a close look at the Micro Fence before you purchase the normal router accessories and then move on to the Micro Fence system anyways...money saved.
I've also always had a few Milwaukee routers laying around. I still like them because they're bullet proof. However, as good as their routers are, the available Milwaukee plunge bases have always been horrific. The plunging action is sticky, the internal spring/springs are too stiff and they make a horrible thunk when they hit the upper stop.  [mad]
I'd suggest trying the Milwaukee plunge base in person before you take the leap.
I'm also thinking about the new Milwaukee M18 router...it seems really nice.  [smile]
Offline Imemiter
« Reply #35 on: May 17, 2020, 11:39 AM »
I've also got a beautiful old Stanley. My mentor talked me into buying it. I actually still use it sometimes. Spins like a top. No photos to upload but here's a link:
https://i.imgur.com/uDcnMwV.jpg
My most used are two Bosch, a 1613 and a 1617. Then the two Makitas, an offset trimmer and the 18v cordless. I've also got another short, sturdy Porter Cable trimmer that hasn't seen a lot of use. I was surprised to find so few routers putting together inventory recently. In the past two years I've sold two PCs and a Ryobi. I love routers, but I've never had a Festool. I'll have to remedy that someday.
Offline Thistleman
« Reply #36 on: May 17, 2020, 04:40 PM »
To answer the question what do I use my routers for is simple cutting lots of different profiles an having set fences etc not having to adjust these if I want to use a different cutter
Festool. OF2200, 0F1400X2, OF1010, MFK700
Elu. MOF99E
Makita. DRT50 18V X2
Bosch. GKF 12V
Draper. For use in router table
AUKTools V3 for use in router table
Festool, Mafell and Felder
« Reply #37 on: May 17, 2020, 06:18 PM »
I strikes me, as my very old Makita router has slightly better plunge action than my newest routers. To me it seems strange that the industry seems to rely on the same mechanics/glide bushings since, well... a very long time ago. I know that the progress of gliding bearings and bushings have come a long way since - a long time ago  [huh]
« Reply #38 on: May 17, 2020, 07:05 PM »
They also now have separate kits that come with the different bases, (offset and/or plunge).
I see another tool order coming in my future...
Offline jjowen
« Reply #39 on: May 17, 2020, 09:55 PM »
Asked me three days ago and I would have given a different answer; A pin on the plug-it connector on my OF 1010 broke! I got the OF 1400 out of the CMS and started using it the right way up for the first time! She looked brand new once I vacuumed all the dust out. I love the extra weight and power.
Anyway, I took the 1010 to get repaired and purchased the replacement part 574351 while I was there.
Disclaimer: All posts after 12:00pm on Fridays (GMT+10) should be independently verified for relevance and veracity.
Offline Cochese
    • The 144 Workshop
« Reply #40 on: May 18, 2020, 11:41 AM »
OF 1400 - LR 32 use, other main non-router table tasks
OF 1010 - mainly for flush trimming hardwood banding, but I should figure out ways to use it more
Dewalt 611PK - my main small router, recently upgraded with a Festool plug-it conversion. A small detail router needs a light.
Ryobi 18v trim router - haven't really used since I got my DeWalt, but I should throw it in my away kit.
(2) Triton TRA001 - router table use. One chuck is crossthreaded, thus the need for a second one. Once the parts factory comes back on line and I can replace the chuck I'll figure out a use for the second one.
No plans for any additional.
Offline Kevin C.
« Reply #41 on: May 20, 2020, 11:12 PM »
 At last count I had 14 routers. Mostly Dewalt 616/618s. A couple Dewalt 621s in tables. A 611 in the cnc and a few Bosch colts that never have the bits swapped out.  The most common bits (champfers and 1/8 roundover) just stay in a couple routers. One table is dedicated to a 3/16 flush bit to cut the skins off cnc cut parts.
 I haven't gotten a Festool router yet, but a 1010 is on my list. The dust collection being integrated on a festool vs the Oneida attachments I currently use is what may push me over the edge to buy one.
Offline GilbertV
« Reply #42 on: May 20, 2020, 11:27 PM »
I have a total of 15 routers.  I have 3 Porter Cable 7518 3 1/4 hp each on a dedicated Jessem Mast- R-Lift that I use a stile bit, a coping bit and a table edge bit that are set up for doing cabinet doors.  I have a PC 690 router on a plunge base, 5 Porter  Cable 2-1/4 on either a fixed or plunge base plus a 6th one on a Jessem router plate.  Two Dewalt 611 routers on a fixed and plunge base set up with round over  bits. Also a Dewalt 610 router set up for my Leigh dovetail jig.
I have a Bosch Colt that rarely used and will probably go to a nephew just starting to do Woodworking.   Lastly I have Dewalt 618 router with both a fixed and plunge base.
« Reply #43 on: May 21, 2020, 12:13 AM »
@GilbertV   seems like I might have a few more routers than you but your fleet definitely outweighs mine.  [big grin]
