Author Topic: How many of you have Multiple Dust Extractors?  (Read 3298 times)
Offline Ross Davis
« on: June 21, 2021, 11:25 AM »
More of a how can I justify this to SWMBO question...
I'm toying with getting another dust extractor primarly for my Kapex.
It something many or any of you do?
Who is the "winner" with the most dust extractors in you shop?
rmd
« Last Edit: June 21, 2021, 12:14 PM by Ross Davis »
Offline Sparktrician
Re: How many of you have Multiple Dust Extractors?
« Reply #1 on: June 21, 2021, 11:28 AM »
@tjbnwi will most likely win THAT category, hands down!   [big grin]
- Willy -
Offline Holzhacker
    • www.aic-chicago.com
« Reply #2 on: June 21, 2021, 11:33 AM »
1 CT 22 for general job site work
1 CT 22 for Kapex
1 Fein turbo II for rough or wet work
1 Sys vac for service work
Used to also have a CT 26 but sold that
Offline tjbnwi
« Reply #3 on: June 21, 2021, 11:36 AM »
2-22
1-33
4-Midi’s
3-Mini’s
1-Sys
1-15
3-33’s
1-33 AC
Just hired 2 more people, will need 4 more CT’s, 4-CXS’s, various sanders and a Kapex.
I had 6 CT’s before I had any employees.
« Last Edit: June 21, 2021, 11:38 AM by tjbnwi »
Offline Alex
« Reply #4 on: June 21, 2021, 11:41 AM »
Just 2 for myself, a Mini and a Midi.
Thinking heavily about changing the old 2006 Mini for a 26.
Offline Bertotti
« Reply #5 on: June 21, 2021, 11:44 AM »
I have my craftsman shop vac I use for wet and for everything wood my CT26 and shop sawdust wood chip collection set up. I see things like the CT as dust extractors the rest have different roles. So, is that one or more?
I want to populate SD with trees because I miss the forests of the river bottoms.
Offline woodbutcherbower
« Reply #6 on: June 21, 2021, 11:48 AM »
CTM26 110-volt (site work)
CTL26 230-volt + CT-VA-20 (shop work)
CT-SYS (small trimming jobs involving only a few cuts)
Offline cpw
« Reply #7 on: June 21, 2021, 11:53 AM »
I have a 26 and a Midi.  The 26 with the is best for general cleanup but harder to move up and down the stairs.  The midi is a good supplement for breaking down sheet goods in the garage, etc. when the 26 is in the basement with other tools or doing something on site.
I also have a Dewalt hybrid 20V battery / 120V corded vac which is quite convenient for small cleanup.
Offline notenoughcash
« Reply #8 on: June 21, 2021, 12:51 PM »
a midi and a titan (screwfix) 40l shopvac
« Last Edit: June 21, 2021, 05:07 PM by notenoughcash »
turns out that woodworking is 1% making things you'll use, 4% making bespoke high end firewood, 15% cleaning, and 80% looking for the bl**dy thing you just put down
Offline squall_line
« Reply #9 on: June 21, 2021, 01:10 PM »
I have an OG MINI, for which I have about a dozen bags, and recently picked up a MIDI-2 from Recon and the bluetooth remote locally from Acme.  The MIDI will probably stay in the garage with the WorkCenter/Cyclone and the MINI will be the basement/indoors cleanup vac.
Offline Ross Davis
« Reply #10 on: June 21, 2021, 01:27 PM »
@tjbnwi   It appears you are in Colorado.  I knew it was busy, but wow!  Did the lumber prices slow you down at all?  New construction or remodeling? Are people starting to build east, out onto the plains?
If renovating, are you bidding on this house?   [eek]
https://www.redfin.com/CO/Colorado-Springs/4525-Churchill-Ct-80906/home/34515765?utm_medium=share&utm_source=web_share&utm_campaign=facebook_share
Offline jeffinsgf
« Reply #11 on: June 21, 2021, 02:11 PM »
CT-22 under the bench for Festool power tool jobs, Altos Attix 33 under the sliding miter saw, Shopsmith DC-3300 between my drill press and one radial arm saw, old Delta barrel collector at the other radial arm saw and old Kity 1hp single stage that rolls around the shop to everything else.
Offline Paul_HKI
« Reply #12 on: June 21, 2021, 02:20 PM »
I have a pair of second generation Midi’s for TS/Domino and sanding work and thinking of getting a CTL-Sys again for the sheer convenience when mobile.
There’s also an old Festo SR 151e AS in my workshop which I wouldn’t like to be without.  It runs a Dust Commander cyclone on a 120L HDPE barrel with D50 hoses connected to my table saw.  A real trooper of a vac and it’s not fussy about how it’s treated.
Festool should make a general purpose wet and dry builders vac again.  Spares for the 151 are now essentially unavailable due to age and if anything other than brushes, motor or bags (also now expensive as heck) need replacing, I’ll have to buy a Kärcher or similar.  I love the CT’s but they’re a different tool for a different purpose.
TSC 55, TS 55, DF 500, DF 700 (XL), OF2020EB+, OF900E, CXS, TXS, T18+3, PDC 18/4, RO 150, RAS 115.04e, RTS 400, ETS 125, ETS 150/5 EQ, CTL MIDI, FESTO SR151 E-AS, CTL-Sys, MFT/3, Sys-Roll etc.
Offline rst
« Reply #13 on: June 21, 2021, 02:38 PM »
Midi, CT26 with WCR, CT36AC w/ CT-VA, vac sys, four Fein, Metabo ACR and 18V, Milwaukee 18v packout
Offline Birdhunter
« Reply #14 on: June 21, 2021, 03:15 PM »
I have a Mini dedicated to my Kapex connected through a short wide hose. Works great. I have a Mini dedicated to my SawStop overarm guard. I have a Mini under my work bench for general use. I have a Fein in the back of the shop for general use. I have two 2hp  cyclones for the big power tools. I have a itty bitty Festool vac in the garage for the cars and the Big Green Egg.
Birdhunter
Offline tjbnwi
« Reply #15 on: June 21, 2021, 03:17 PM »
I’m currently in Colorado Springs, got here about 3.5 years ago.
We do casework and millwork for new construction homes.
The material issue affected the brand of hardware we use due to availability, we had to order in sheet goods early so we got them when we needed them, longer solid lumber lengths were hard to come by.
The homes you linked went for over the asking of 590,000.00. It is in the Broadmoor area, at 590 it is just a shack for the area…..
The area is moving east. The home my wife and I just purchased is on the east boarder of Colorado Springs. We paid 40K over asking for the home.
Offline tjbnwi
« Reply #16 on: June 21, 2021, 03:19 PM »
I should also mention 3/4 of the CT’s have the Festool Separator on them. We have to change the bags about every 10th dump of the separator bin.
Offline kevinculle
« Reply #17 on: June 21, 2021, 03:38 PM »
CT26
Nilfisk Aero 21
Jet 600CFM collector
Jetkenstein 1200CFM collector(cobbled from Jet frame with motor and blower from somewhere else)
Offline Crazyraceguy
« Reply #18 on: June 21, 2021, 07:00 PM »
Only one, so far, at least. I've got a CT26 at the end of my assembly bench and a couple of 4" ports from the main dust collection system at the shop. One of them goes to the Dewalt Mitersaw and one for the jointer.
I have been thinking about getting a CT15 for a bit more portability. I have a pretty big workspace and I like keeping the CT26 in one place. A second extractor would be handy.
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1400
MFK700 (2)
CT26E + Workshop cleaning set
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
Offline morts10n
« Reply #19 on: June 21, 2021, 09:24 PM »
CT 22, CT 26, and CT Midi
Offline SoonerFan
« Reply #20 on: June 21, 2021, 10:30 PM »
For my Festool Kit I have a CT36 for sanding, routing, cutting, etc.  Then a CT Midi which is basically dedicated to the Kapex while in the shop and which moves with me the little I do outside the shop.
« Last Edit: June 23, 2021, 07:38 PM by SoonerFan »
Offline twistsol
    • The Sawdustzone
« Reply #21 on: June 22, 2021, 04:20 AM »
1 CT33 with a boom dedicated to the MFT/3 station where all the small tool work is done.
1 CT33 dedicated to the OF1010 for my Schmitt32 system (used to be dedicated to the Kapex)
A Jet JCDC-3 3hp Cyclone for almost everything else in the shop
A Ridgid wet/dry vac for the ShopSmith
Another old Ridgid wet/dry vac for general cleanup.
Offline Vondawg
« Reply #22 on: June 22, 2021, 06:35 AM »
CT26 under the main assembly bench, Mini for on site, and a 5 gallon FÍEN on the Kapex ran thru an IVac switch box…..and dust collector takes care of Sawstop ect.
Offline Bert Vanderveen
« Reply #23 on: June 22, 2021, 08:49 AM »
Festool CTL Midi (original with updated top) + CT-VA — for TKS tablesaw, sanding, sawing and domino-ing on and around MFT/3
Festool CTL-SYS — for incidental jobs away from the shop
Mirka 1230 L (OEM Nilifisk Attix 33) — with cyclone + barrel for Kapex 120 & when needed with router table
And a Felder AF14 — for planer/thicknesser, bandsaw and HS950 sander
Cheers, Bert Vanderveen
TS55 · TS55R · OF1010 · DF500 · MFT/3 + TSB1-MW 1000 + VL + CMS TS55 + CMS PS300 + LA-CS 70/CMS · CTL Midi · RTS400 · 2 x CXS Li 1,5 · T15+3 Li 4,2 · TI15 Impact Li 4,2 · Centrotec Sets 2008 + 2015 · PSB300 · LR32-SYS · RO150 · KS120 · 2 x MFK700 · RO90 · OFK700 · BS75 · OFK500 · OF2200 · CMS-GE · Vecturo 18 Li · TID 18 · TKS 80 EBS-Set · DTS 400 · ETS EC 125 w 150 pad · Surfix Set · CTL SYS · CT-VA-20 · … | Mirka 1230L P&C | Hammer: A3 31 Silent Power · N4400 · HS950 | TaigaTools: VacPods Pro Set
On order: … [ ! ]
Offline Claimdude
« Reply #24 on: June 22, 2021, 09:13 AM »
CT22
Fein Turbo I
Jet 1 1/2hp w/cone
Shopsmith 1 1/2hp DC6000
Jack
Offline KG6
« Reply #25 on: June 22, 2021, 11:03 AM »
I recently got my first, a Midi.  For use with my TS, Sander, Router, and Miter Saw.  I have a Rigid Shop Vac to clean up the work space and floor.
My miter saw is on a mobile cart, so the dust extractor works for it right now.  But for those with more dedicated miter saw stations, is a dedicated dust extractor better for you than running a line to the dust collector?  I see it often when looking through youtube videos of peoples shops.
Offline Erich
« Reply #26 on: June 23, 2021, 12:09 AM »
We have a CT36E for the sanders, ETS's, RO's, RTS.  We use a Fein Turbo II for the OF's, DF's, TS's, Planers and the Kapex.  We have a circa 1998 stainless steel Shop Vac on the overarm guard on the Table Saw.
We use an Oneida Dust Gorilla Portable for the Table Saw, J/P, Band Saw, Router Table, and Drum Sander.
We have a Flex VCE44AC for general cleanup and an Atrix Lil' Red for small jobsite work. All are HEPA rated filtration and disposable bags, even the Oneida uses drum liners for ease of Cleanup.
Offline online421
« Reply #27 on: June 23, 2021, 03:57 AM »
CT36 and Starmix 1635. 1 man shop
Griggio Unica400
Felder AD951
Masterwood OMB1V
Omga T55-300
SCM 5 RCS1100
SCM TI145EP
Comatic DC40
Chicago Pneumatics CPRS10500
Ceccato CDX 12
Holytek DC006
Festool DF700XL, LEX3, OF1010, OF2200, CT36, VAC SYS
Starmix 1635
Danfoss VLT 2880
Sicar TOP6
Offline Ross Davis
« Reply #28 on: June 23, 2021, 11:45 AM »
@tjbnwi
I realize now that the sale listing I linked had changed after it was first brought to my attention.  It sounded like the house from heck with every surface damaged or spray painted - even the bathroom sink and tub.  And the unplugged freezer full of meat...  The person who told me of this listing said it would go for far more than the listed price even in that distressed shape.
I guess a complete rip out would let a person have the home the way they like it...  I wonder what it would cost to just get it back to new walls alone..
What employment in the area is supporting homes in the heated market?   Or are there a lot of speculative investors messing with the market?
Offline Imemiter
« Reply #29 on: June 23, 2021, 12:02 PM »
My Makita 410 sounds like it's on its last legs, but what a workhorse that thing has been! I also got a good fifteen years out of a Turbo II before the auto-switch gave out. I keep meaning to fix it and sell or use it to death on some jobsite, but the Midi replaced it for the smaller jobs I do. The CT Sys seemed like it'd be perfect for those kinds of jobs, but "the button" swayed me away and now the Sys stays home a lot.
CSX T18+3 TID18 HKC55 OSC18 OS400 OF1010 LR32 DF700 RAS115 DTS400 ETC125 CTSys CTMidi CT-VA
Offline tjbnwi
« Reply #30 on: June 23, 2021, 01:26 PM »
@tjbnwi
@Ross Davis
The area has 6 military bases and a lot of government contractors. These 2 things drive the market.
Offline PaulMarcel
    • Voilà, my blog
« Reply #31 on: June 24, 2021, 04:38 AM »
I hesitated on another CT-22 for the Kapex and it sold hours later. I have a bunch of bags for the 22 since getting a long-life bag for it so it would have worked out fantastic. Ended up modding a Steel City mini-inline DC with a chunk of D36 hose to deal with the Kapex. That DC was gold; I dunno why they discontinued it.
Offline Thompmd
« Reply #32 on: June 25, 2021, 07:32 AM »
Just 2
CT 36 and recently added a CT-15 dedicated to my Kapex.
I will add having one dedicated to the Kapex was a good choice, I didn’t realize how often I was changing but some units you can add an additional outlet but I never really looked into that as an option
Sawstop Industrial Saw, TS75,2 800,2 1400 & 2700 rails, CT36, Rotex RO 150 FEQ, CT-VA-20, Carvex PS 420 EBQ, Carvex acc. ZH-SYS-PS 400, Kapex KS 120, CT Cyclone Dust Collection Pre-Separator CT VA 20, DF 500 Q Set, Domino 1,060pc Tenon Assortment, UG-KA-SET Portable Imperial Stand & Extensions,OF1400 EQ-F-Plus, MFT/3, MFT-SP, FS-HZ 160, TSC 55, T18 E
Offline frahengeo
« Reply #33 on: July 09, 2021, 10:51 AM »
CT33/boom arm for use with MFT/3, and a Midi 1 for 'On the go'.
Offline JonathanJung
  • www.timberlightdesigns.com
    • Timberlight Designs
« Reply #34 on: July 09, 2021, 11:04 AM »
A Midi dedicated to the miter saw
A Midi with Oneida cyclone for bench work and cleanup
Everything else gets attached to the dust collector. In a 1200sqft shop with one person, this is doable. Sometimes I wish I had more, but that just takes up space.
Do have a M18 vac that sits in the trailer for site work, but I rarely use it. Mostly just gets used to cleanup after emptying cat litter trays...
Offline live4ever
« Reply #35 on: July 09, 2021, 12:28 PM »
2 older style Fein Turbo I’s (variable speed) with the blue Rockler cyclone buckets.  Not the most space-saving setups but work nicely in the shop or on site.
A CT-sys with CT cyclone.  I feel kinda meh about it.  The systainer integration is nice.  And a M18 vac which is handy on-site or in places I don’t want to lug the bigger vacs.  Did some nasty crawl space cleanup recently with it.
Been wanting to add a CT AC that’s better suited for drywall work at some point but the Feins are doing...fine.
Offline c_dwyer
« Reply #36 on: July 09, 2021, 07:20 PM »
Four:
1. Midi usually set up under and dedicated to the miter saw;
2. CT 26 with a Dust Deputy and homemade platform for attachments and small tools, this one roams the basement shop;
3. Oneida 1.5 HP Mini Gorilla on rollers near the heavy sawdust makers (planer, table saw, lathe); and,
4. Milwaukee 18-Volt Cordless Wet/Dry Vacuum for the garage.
Offline ScotF
« Reply #37 on: July 10, 2021, 02:11 AM »
CT 22 and CT 26 for me. Would love to have a Mini or Midi to move around the house, but would be overkill. Also a Felder AF22 for big machines.
Offline RogerF
« Reply #38 on: July 14, 2021, 01:52 AM »
CT 26 that replaced a dead CT33. Mostly stays in the shop but gets to visit job sites sometimes. Love love love the Bluetooth!
Midi. Shop, job sites and sometimes comes home.
CTL-Sys job sites
I just got a compact DeWalt 20V vac. It’s the quicker picker upper and is proving very useful and is always in my truck.
And if we’re talking dust collectors in general then my Oneida V system 3000 cyclone takes care of the big stationary tools.
Offline jeffinsgf
« Reply #39 on: July 14, 2021, 04:37 PM »
Do you have trouble with your foam and paper filter loading quickly and causing the alarm to flash? I loved mine for about a week, and now every time I turn it on, I have to clean the filter.
Offline c_dwyer
« Reply #40 on: July 14, 2021, 05:12 PM »
@jeffinsgf - so far (9 mo, occasional use), so good.
Offline Blues
« Reply #41 on: July 19, 2021, 09:35 PM »
I had a Midi (older model), that I was very happy with until it was repurposed for generic household chores (including vacuuming cars) since it gets the job done in a jiffy. So, for the shop I had to get the CT36AC with Bluetooth. Now all my workflow is centered around the CT36, and the midi at times does double duty with odd jobs.
