Author Topic: How do you change bits on the MFK 700 without dinging them up?  (Read 569 times)
Offline JakobProgsch
To change bits on the MFK700 you have to remove the base. But doing so without hitting the router bit on the base just as it slides out is really difficult I find. Is there some magic technique to this?
Offline DynaGlide
Re: How do you change bits on the MFK 700 without dinging them up?
« Reply #1 on: March 20, 2019, 08:46 AM »
If it's the vertical base insert the bit into one of your MFT or other dog holes. Push down on the base and lift straight up with the motor. I haven't had an issue.
Instagram @matts.garage
