Author Topic: New Festool Stuff discovered !  (Read 8017 times)
Offline guybo
« on: July 09, 2021, 10:05 PM »
333408-0333410-1333412-2333414-3333416-4 [big grin]
Offline squall_line
« Reply #1 on: July 09, 2021, 10:37 PM »
That new "slotted" rail was in the background/hero shots for the new OF 1010.  Now the slot makes a lot more sense.
Offline niky1
« Reply #2 on: July 10, 2021, 06:48 AM »
MFT-HZ 80 577132..... [eek]
TS 55 EBQ, 2 x FS 1400/2, FS 800/2, PS 420 EBQ - Plus,  OF 1010 EBQ - Set + accessories, CXS Li 1,3 - Set, CXS Li 2,6 - 90 Limited Edition, DF 500 Q-Set + SORT-SYS DOMINO, set  ZOBO system, SYS 1 CE-SORT, PDC 18/4 Li 5,2 Set, SURFIX SYS3-SET, RTS 400 REQ-Plus + SYS-STF 80x133 + HSK-A 80x130, MFT 3 + SYS-MFT fixing set + FSZ 120, FSZ 300 + Veritas Parf Dogs, CMS-TS 55 R Set + all accessories, DOMINO  KV-SYS D8, KS 120 UG-Set KAPEX + all accessories, ETS EC 150/5 EQ-Plus + D27/22 x 3,5 m AS-GQ in SYS 3 T-LOC, CMS-OF, CMS-PS, OF 2200 EB-Set, LR 32-SYS, MFS 700, FS 2424/2-LR 32, MFK 700 EQ-Set, MFS-FS, MFS-VP 200, MFS-VP 400, FS 1400/2-LR 32, VECTURO OSC 18 HPC 4,0 EI-Set, AGC 18-125 Li EB, T 18+3 HPC 4,0 I-Set, Edge sander ES-ETS 125 REQ-Plus .........
Offline DynaGlide
« Reply #3 on: July 10, 2021, 07:44 AM »
If you go here and search by novelty you can see everything with descriptions
=1;]https://www.naradionline.cz/elektricke-naradi/rezani/prislusenstvi/?f[novinka]=1;
The slots on the new rails let you hang them on adhesive clips on the wall or transport over a systainer handle.
There's new self aligning guide rail connectors, a new guide rail angle attachment as well.
Instagram @matts.garage
Offline Coen
« Reply #4 on: July 10, 2021, 09:11 AM »
Ahaa. So the smaller holes for storing them and the big hole to have a Systainer handle stick through?
The FS-WA being a new version of the FS-KS? But still no locks at 30/45/60?
« Reply #5 on: July 10, 2021, 10:04 AM »
Thanks for that Matt...I saw a photo of the new rails and wondered about the slots. The new rail connector reminds me of the Mafell version.
« Reply #6 on: July 10, 2021, 10:09 AM »
Looks like those new rail connectors would do the job.
What are the green inserts for (for use in the new guide rails)?
« Reply #7 on: July 10, 2021, 10:11 AM »
Offline wpz
« Reply #8 on: July 10, 2021, 10:20 AM »
Also new:
clamping systainer
333436-0
phone charger
333438-1
333440-2
wpz
Offline guybo
« Reply #9 on: July 10, 2021, 10:24 AM »
Hi, true however the angle is set by a type of rail dog under the rail ,so 90 degrees etc. is set. guy,p.s uses same system as their pe type rail guide(TSO PE)
« Last Edit: July 10, 2021, 10:26 AM by guybo »
Offline SRSemenza
« Reply #10 on: July 10, 2021, 10:38 AM »
Nice discoveries guybo and wpz !  [thumbs up]
Offline wpz
Re: New Festool Stuff discovered !
« Reply #11 on: July 10, 2021, 10:50 AM »
I only got there because of @DynaGlide post, so credits to him.
wpz
Offline Coen
« Reply #12 on: July 10, 2021, 11:07 AM »
I don't see the new clamping Systainer there, but it looks like a variant from the previous #201311
New guiderail accesory kit with the new connectors and the FS-WA in #577157, but still the screw clamps.  [sad]
And it comes in a fatter Systainer. How much air can they possible fit in there...   [huh]
I wonder how it looks inside. Tempted to buy it, sell off the empty space waster and transfer it over to a Systainer I T-Loc if possible.
Offline Bob D.
« Reply #13 on: July 10, 2021, 11:22 AM »
Those hold down clamps are interesting.
« Reply #14 on: July 10, 2021, 12:29 PM »
(Attachment Link)
So, you don’t know either?  [huh]
Offline squall_line
« Reply #15 on: July 10, 2021, 12:44 PM »
The picture of the FS-WA appears to have detents at 30, 45, and 60.
(Attachment Link)
Not sure what you mean by that.  He posted a picture in response to the question.  The picture shows the green clips being used to hang the rails on a wall.
« Reply #16 on: July 10, 2021, 12:51 PM »
Aha!
The photo could have used a little more depth of field.
It looked to me like a sideways photo of a guide rail sitting on particle board.
Offline wpz
« Reply #17 on: July 10, 2021, 12:52 PM »
They are self stick, but I wonder if you can use them only once to temporarely fix the rail or if you can also use them to hang the rail on the wall and take it on and off.
wpz
333461-0
Offline guybo
« Reply #18 on: July 10, 2021, 01:09 PM »
fs-wa333463-0333465-1
Offline mino
« Reply #19 on: July 10, 2021, 01:37 PM »
Nice to see the TSO cooperation bear some fruit!
EDIT:
Interesting that the new self-aligning guide rail connectors are different each.
Only one of them is self-aligning while the other one is "traditional". This matches with the observation that the "ribs" are not guaranteed to be same distance, so only one should be used for (self) alignment.
Edit:
Took some time, but looks someone finally listened - a hose guide compatible with FS/2!
FS/2-AW - part 204787:
« Last Edit: July 10, 2021, 04:24 PM by mino »
The Machine does not have a brain. Use Yours!
Protool: AGP 125, VCP 260
My Precious: 376, 376, 376 holy, 632, 1016 holy, 1400 holy, 2400, GECKO, GRS 16 PE, GRS 16 PE
Offline TinyShop
« Reply #20 on: July 10, 2021, 02:57 PM »
ETS 150/5 EQ (DE) [po], TS 75 EQ (DE) [po], OF 1400 EQ-F (DE) [n], CXS (DE) [n], CMS-GE [DE] [po], CMS TS 75 (DE) [n], LA-CS 50/CMS (DE) [po], VB-CMS (DE) [n], MFT/3 (CZ) [n], DF 700 EQ w/Seneca Small Mortise Kit (DE) [po], FEIN Multimaster 350 QSL (DE) [n], Bosch 1274DVS w/dust collection, sanding frame,  stand & fence (CH) [n], BOSCH 1590EVS w/dust collection (CH) [n], CS Unitec CS 1445 HEPA extractor <re-branded Starmix ISP 1435 H> (DE) [n], CT SYS (DE) [po], Milwaukee 0302-20 (US) [n], Two (2) Porter Cable 862 (TW) [n], Porter Cable 447 (US) [n], Zyliss Vise (CH) [nos], Hitachi C 8FB (JP) [h], Walko 4 MKII (NL) [nos], Festool MFS 400 w/add-on 700 profiles & router slide (DE) [n], Festool RAS 115 (DE) [n]
[po] pre-owned   [n] new   [nos] new old stock   [h] heirloom   (XX) country of origin
Offline TinyShop
« Reply #21 on: July 10, 2021, 03:05 PM »
The adjustable guide rail square is available in a set that includes the improved guide rail connector bars among other items:
https://www.naradionline.cz/sada-prislusenstvi-pro-vodici-listu-festool-sys3-m-137-fs/2-set.html
Offline TinyShop
« Reply #22 on: July 10, 2021, 03:14 PM »
Appears to be an extension fence for the adjustable guide rail square featuring a scale and moveable stop:
https://www.naradionline.cz/prodlouzeni-pro-uhlovy-doraz-festool-fs-pa-vl-fs-wa-vl.html
Offline wpz
« Reply #23 on: July 10, 2021, 04:16 PM »
Yes, a bit similar in idea as the TSO PGS, but unfortunately no flip stops
wpz
Offline squall_line
« Reply #24 on: July 10, 2021, 10:22 PM »
I'm unfortunately wondering how many of these items will actually make it to the US shores.  With the TSO exclusivity in the US, the Festool-branded rail square isn't over here, so I wonder if the rail guide with the TSO-esqe connector will make it or if they'll be branded and sold by TSO instead.
Is there any official word on the release of the new OF 1010?
Curious, too, if they'll discontinue the MFT/3 Set and replace the angle finder.
« Last Edit: July 11, 2021, 12:30 AM by squall_line »
Offline mino
« Reply #25 on: July 11, 2021, 07:31 AM »
The licensed Festool branded GRS 16 PE is just that. A Festool branded GRS 16 PE. Including the accessory holes for TSO accessories. It is identical to the thousandth of an inch to the TSO branded original.
There a scenario where Festool markets Globally while TSO in US /where they had presence way before/ makes complete sense for TSO and is generally acceptable for Festool.
On the other hand, the new adjustable angle accessory is apparently either a pure Festool design using the licensed TSO connection method or a joint development. There it makes little sense to complicate matters. Further, it is a pretty advanced cast-and-machined thingie which TSO has no way to manufacture at the costs comparable to Festool. A molding set for castings like these goes for some serious $$$.
I can imagine a TSO-branded-but-Festool-made version in the US. But even that would be a stretch. If there is any delay, it is likely to be production capacity related.
« Reply #26 on: July 11, 2021, 09:57 AM »
wpz
(Attachment Link)
Is there any literature accompanying these green things? It looks like it would be very difficult to lift the guide rail off once the green thing is stuck to a surface, so these are probably meant as another way to secure the rail prior to cutting when neither clamps or the Gecko can be used.
Also, there are many in a package so they seem to to be a sacrificial aid like the outboard splinter shoe.
Offline SRSemenza
« Reply #27 on: July 11, 2021, 10:04 AM »
wpz
(Attachment Link)
  I agree. To me these do not look like they are for rail storage. I think they are for mounting rails on vertical, oddball, or surfaces that can't be clamped.
   Just guessing.
Offline Jim_in_PA
« Reply #28 on: July 11, 2021, 10:43 AM »
Yes, kinda of a modern take-off on hold-fasts which I find indispensable in my work.
ETS 150/3, Rotex 150, OF1010, OF1400, Trion PS 300, TDK-12, CT-22, MFT 1080, TS55, Domino XL DF 700, 8' track, (2) 55" tracks
SCM MiniMax S315WS, FS350, MM16, Camaster Stinger II SR-44 CNC
« Reply #29 on: July 11, 2021, 11:07 AM »
I'm thinking those green oblong stickies are 1-time use only for adhering the rails to oddball surfaces like Seth mentioned. I think the OSB wall was chosen to underline how strong/aggressive the PSA is on the back of the oblong item.
