Author Topic: HL850 vs Nail  (Read 2107 times)
Offline Birdhunter
HL850 vs Nail
« on: April 25, 2021, 05:17 PM »
I was reworking a piece of furniture for a friend. I had to cut the top off a TV credenza and trim the top. I was using my HL850 and heard a screeching sound. There was only about an inch of the blade engaged in the wood. The edge on that inch was dull as a butter knife. I had planed the top off a hidden nail.
Fortunately, I had a back up insert. I don’t think the inserts can be sharpened so $44 down the drain.I never thought to check for a hidden nail.
Birdhunter
Offline afish
Re: HL850 vs Nail
« Reply #1 on: April 25, 2021, 05:22 PM »
no good deed goes unpunished
Re: HL850 vs Nail
« Reply #2 on: April 25, 2021, 06:10 PM »
I'm surprised that with the insert being solid carbide, it didn't crack and fracture instead of just becoming dull.
Offline Birdhunter
Re: HL850 vs Nail
« Reply #3 on: April 25, 2021, 09:00 PM »
I guess I was lucky it didn’t shatter.
Birdhunter
Offline Svar
Re: HL850 vs Nail
« Reply #4 on: April 25, 2021, 09:36 PM »
Eat my dust, Festool! Yes, true helical cutter head.
« Last Edit: April 25, 2021, 11:00 PM by Svar »
Offline Lincoln
Re: HL850 vs Nail
« Reply #5 on: April 26, 2021, 12:01 AM »
They're only available for Makita planers, right @Svar?
Offline Svar
Re: HL850 vs Nail
« Reply #6 on: April 26, 2021, 12:48 AM »
Yes, several Makita models as far as I know. A company called Sheartak. No affiliation.
P.S. Just checked their site. They've added quite a few other brands of planners.
« Last Edit: April 26, 2021, 12:54 AM by Svar »
Offline Birdhunter
Re: HL850 vs Nail
« Reply #7 on: April 26, 2021, 06:12 AM »
Just checked their site and didn’t see Festool listed. I have helical heads on Powermatic planer and jointer. Definitely a great cutter design.
Birdhunter
Re: HL850 vs Nail
« Reply #8 on: April 26, 2021, 10:38 AM »
I also took a look at their site and came away with a mixed impression.
https://www.sheartak.com/common-home
First off, for a DW735 planer they are $60-$70 more expensive than a Byrd Shelix conversion.  [blink]
They offer heads for Bosch, Hitachi, Makita and Milwaukee hand held planers which makes sense, however they also offer $193 heads for Ryobi & Wen planers which cost only $40-$50.  [jawdrop]
Offline jobsworth
  • Festool Baby.....
Re: HL850 vs Nail
« Reply #9 on: April 26, 2021, 10:51 AM »
Good thing about FT planers is their knives dont need adjusting basically remove and replace.
Is you buddy gonna reimburse you for the cost of the blade?
Offline Birdhunter
Re: HL850 vs Nail
« Reply #10 on: April 26, 2021, 01:28 PM »
Not going to spoil the pleasure of doing something nice for a friend. I always enjoy testing my skill with a new project.
I did need to align the insert to the outside edge of the cutter head. Not hard. No other adjustments needed.
I seldo use the 850, but, when needed, it’s a great tool.
Birdhunter
Offline mino
Re: HL850 vs Nail
« Reply #11 on: April 26, 2021, 01:46 PM »
Where there is a market ... shame Festool does not make one or subcontract one as an optional upgrade.
I can see a contractor going through a couple planers while just transferring the head.
The Machine does not have a brain. Use Yours!
Protool: AGP 125, VCP 260
My Precious: 376, 376, 376 holy, 632, 1016 holy, 1400 holy, 2520, GECKO, GRS 16 PE, GRS 16 PE
Offline Birdhunter
Re: HL850 vs Nail
« Reply #12 on: April 26, 2021, 03:15 PM »
My guess is that the HL850 market is microscopic compared to the big box store brands.
Birdhunter
Re: HL850 vs Nail
« Reply #13 on: April 26, 2021, 06:03 PM »
Might need to let the cutter project a little beyond the head. It should be even with the shoe on the rabbet side. Easy way is to lay the planer on it’s side on a smooth flat surface and slide the blade to the surface before tightening.
« Last Edit: April 26, 2021, 06:05 PM by Michael Kellough »
Offline Birdhunter
Re: HL850 vs Nail
« Reply #14 on: April 26, 2021, 07:13 PM »
I put a 6” steel ruler alongside the “shoe” and slid the insert up against the ruler. The insert should be aligned correctly.
I saw a YouTube video by New Brit Workshop where he modified the 850 fence to provide improved registration. I made a very crude copy and it helped to plane a right angle surface. His version was very elegant. My version was quick to make.
« Last Edit: April 26, 2021, 07:17 PM by Birdhunter »
Birdhunter
Offline Svar
Re: HL850 vs Nail
« Reply #15 on: April 26, 2021, 08:11 PM »
Old Porter Cable 126 had a single spiral knife. Virutex CE223X has one too. It's a bit outdated approach. One of the benefits of segmented helical cutters is high level of standardization, where only couple of knife types can be fitted onto cutter heads of all lengths, diameters and brands.
« Last Edit: April 26, 2021, 08:29 PM by Svar »
Re: HL850 vs Nail
« Reply #16 on: April 26, 2021, 09:29 PM »
Not even the HL850 can leave as smooth a finish as a fresh blade did on that venerable old planer produced. Good luck trying to sharpen the PC cutter though. That really separated the men from the boys.
Offline Svar
Re: HL850 vs Nail
« Reply #17 on: April 26, 2021, 10:42 PM »
Although I brought it up myself, but to be fair PC 126 wasn't a regular planer. I.e. you can't flatten a table top with it. It's more of an edge router.
Re: HL850 vs Nail
« Reply #18 on: April 26, 2021, 11:05 PM »
If I remember correctly, it was specifically used for sizing doors to their jambs.
Offline mino
Re: HL850 vs Nail
« Reply #19 on: April 27, 2021, 06:56 AM »
IMO the big benefit is "smoothness" of operation and hence stability. Clean cuts are just a result of that.
With a full-width cutter the cutter hits the material all at the same time, this can cause the cutter to be slowed down more easily when the momentum of the cutter head is not enough to make the cut. I see this all the time when there is some major imperfection in the wood which is way-harder than normal softwood the cutter may have a difficulty to cut it and the planer jumps if not held firm-enough.
