Author Topic: Ks120 eb ug stand  (Read 426 times)
Ks120 eb ug stand
« on: September 23, 2022, 11:13 AM »
Hello guys just need some advice I’m about to purchase a ug kapex stand for the ks120 eb 110v mitresaw is it worth getting
Offline Zubo
Re: Ks120 eb ug stand
« Reply #1 on: September 23, 2022, 11:54 AM »
yes. no doubt.
Expecially if you work in site. buy also both extensions, you can use on your mft3 table.
if you use the kapex only in your shop built a cabinet to fit in all you systainer.
or if you want third part take a look at this:
https://www.performancetoolcenter.com/fastcap-best-fence-pro-4/
Practice makes perfect. Don't be afraid to fail, be afraid not to try.
Offline twistsol1
    • Sawdustzone
« Reply #2 on: September 23, 2022, 12:59 PM »
I've had my UG cart and extensions for about eight years and it is awesome for onsite work. I'd definitely buy it again. Once the scales on the extensions are calibrated, you can remove and replace them without recalibration. It's easy to transport, fast to set up and stable. I don't use the stand in the shop and have my Kapex mounted in the middle of a 24' run of cabinets instead.
In both cases I have a dedicated CT15 with a short 36mm hose. Contrary to marketing, there is still a lot of sawdust to clean up.
A shop full of tools and no talent
