What mrB said.
I’ve got all 3 FSK rails. I’ve yet to use the 670. I know I will, but the 250 is a real gem for most up to 2x6 til past 45° mitre or even 2x8 if less than 45° (Again, timber are apparently measured differently by different country’s, A 2x4” is 48x98mm here, and not true 2x4 inches - Most of us still call our timber by imperial, but measure in metric)
Try do your own calculations, or even dry test a FSK rail to measure which dimensions it will cut for you. You can draw an arch measuring 250, 420 and 670mm starting at 90° from an edge and move the arch to at least 60° - then measure what each rail will cut at your measured angles (mitre cut). The cut capacity decreases as the angle increases or decreases from 90°.
I absolutely love mine, the features, handling, cut quality, ease and weight makes it a winner. As mrB says, battery capacity is great. It may “lack” power on thick wet or very dense timber with “just” 18V, but a bit patience makes more than up for carrying something that would have been a lot heavier and bulkier with 2x18V. Let the saw do the job and don’t push too hard and you’ll be fine.
