Author Topic: Festoon CMS-VL and Jessem Clear Cut Stock Guides  (Read 9203 times)
Offline jlcichocki
« on: December 20, 2015, 06:50 PM »
I'm about to purchase the CMS.  Can the Jessem Clear Cut Stock Guides be used on the fence of the CMS?  I like the look very much.
Online Birdhunter
Re: Festoon CMS-VL and Jessem Clear Cut Stock Guides
« Reply #1 on: December 20, 2015, 07:47 PM »
My Clear Cut Guides fit into a T-slot on my router table fence. I don't believe the CMS fence has T-slots. Perhaps, an auxiliary fence with a T-slot could be rigged up?
Birdhunter
Offline jlcichocki
« Reply #2 on: December 20, 2015, 08:27 PM »
There looks like there is slot on the CMS fence.  Is this not a T-slot?  I guess I should have paid more attention while I was drool on it in the store :)
Thanks, Jeff
Online Bohdan
« Reply #3 on: December 20, 2015, 08:40 PM »
There is a T slot in the CMS fence.
When I use the CMS fence I sometimes use the Festool supplied hold down to guide the stock but most of the time I use a power feed.
I find that the CMS fence is a PITA as it has no fine adjustment and the fence sometimes slips in position because the hold down screws are flimsy. I prefer to use my Incra fence which sits on dogs on the adjacent MFT.
Offline bkharman
« Reply #4 on: December 20, 2015, 10:12 PM »
I have them and they work fine in the CMS fence. They work even better in the Incra LS fence. Most folks here know that I am a big fan of the MFT + CMS-VL + Incra LS positioner + Precision Plate. Make a great setup and drastically more repeatable than the Fessy fence. Not for the feint of wallet though...
Cheers. Bryan.
People, I just want to say, you know, can we all get along? Can we get along?
Offline jlcichocki
« Reply #5 on: December 20, 2015, 10:39 PM »
Cheers. Bryan.
I have seen your posts and I love your set up.  I'll be working my way in that direction, just need to stay on the good side of the "boss".  If I purchase things for a specific purpose, I get a little less hassle.
Offline jobsworth
  • Festool Baby.....
« Reply #6 on: December 21, 2015, 03:11 AM »
I have them and they work.
Offline GarryMartin
« Reply #7 on: December 21, 2015, 04:24 AM »
They work very well with the CMS OF fence.
Offline jlcichocki
« Reply #8 on: December 21, 2015, 12:23 PM »
Thanks for the pics!!
Offline jobsworth
  • Festool Baby.....
« Reply #9 on: December 21, 2015, 02:27 PM »
I got mines because of Garry brought his set to my get together a couple of years ago.
Offline richk
« Reply #10 on: December 21, 2015, 02:34 PM »
How is the dust extraction with this setup?
Offline GarryMartin
« Reply #11 on: December 21, 2015, 02:53 PM »
Doesn't really affect dust extraction.
Offline ChipMonk
« Reply #12 on: September 12, 2017, 11:11 PM »
I am now wondering if my CMS OF has a different fence profile than you guys.
Here are some pictures of the slot included in my fence.
Photo of the slot profile in my fence (left) and a standard T-Slot track (right)
CMS OF fence slot with with the standard T-Slot screw head inserted.
Slot in the fence is too loose allowing the screw to turn inside.
Close up of the same screw head inside a standard T-Slot.
Perfect fit prevents the screw from turning while the clamping knob is being tightened.
Offline GarryMartin
« Reply #13 on: September 13, 2017, 05:35 PM »
Looks like the same profile as mine but I have no problems tightening the thumbscrew - the head doesn't rotate in the slot despite it being smaller than the profile.
« Last Edit: September 13, 2017, 05:38 PM by GarryMartin »
Offline jobsworth
  • Festool Baby.....
« Reply #14 on: September 14, 2017, 10:33 PM »
@GarryMartin
Is that what you look like behind those shades????
Offline GarryMartin
« Reply #15 on: September 15, 2017, 05:17 AM »
@jobsworth Ah, the new profile pic? Yes, that's me...  [embarassed]
Offline jobsworth
  • Festool Baby.....
« Reply #16 on: September 15, 2017, 10:25 AM »
@GarryMartin what they dont have bags in England  [big grin]
Offline WilliamT
« Reply #17 on: July 02, 2019, 04:36 PM »
Hello FOG,
O.k., it is an old thread, I know.
I did a lot of routing last two weeks, was not really pleased with the OEM fence.
So this is what I did. Only the featherboards need some small modifications, M6 50mm screws and four sliding nuts. Already had the crown stops in shop ;-)
The Jessem rollers came with t-slot bolts, ordered here in Germany https://www.feinewerkzeuge.de/
Greetings from Germany,
William T.
Offline lightwriter
« Reply #18 on: July 11, 2019, 12:49 PM »
Thanks for the pics.  I'll be doing the same tonight!
Offline PreferrablyWood
« Reply #19 on: January 17, 2020, 11:13 PM »
I'm using my CMS with router setup this week, I'll be following this example in the near future as well. Old thread and I hear the CMS setup has been discontinued. I think I'll snap up the VL, and Jigsaw module and the Belt sander modules an additional CMS table as back up. Being space limited and having three or for work places means it's really a great plus a mobile setup. It still looks modern and up to date too.
TS 55 R EBQ, Vecturo OSC, BHC SDS, RO 150, 850 HL E Planer, MFS 400x2, MFS extensions MFS VB 700 x 1 MFS VB 1000 x 2 . CMS GE, OF 2200, CMS OF+ CMS TS 75 insert modules. SYS-MFT Fixing-Set,
Festool 18V HKC 55, TI 15, CXS 2.6 Ah version, RO 90 DX, PDC 18/4 plus   TS 75 EBQ, PSC 420, OF 1010, RS 300 EQ, CTL Midi, MFT 3
Offline jlcichocki
« Reply #20 on: February 02, 2020, 11:48 AM »
Thank you for reviving the topic and posting pics of your upgrade.  I'm loving it!!
Jeff
Offline Stan Tillinghast
« Reply #21 on: November 15, 2021, 08:10 PM »
Thanks for all the info! I'm getting my CMS-GE in  couple of days; I already have a pair of Jessem Clear Cut Guides, and I like the featherboard arrangement so much I just ordered a pair of Festool Crown Stops from Shane. Add a pair of Jessem featherboards, and I'm set to go. That definitely looks preferable to the OEM arrangement.
Will I need to change the bolts on the Clear Cut Guides to fit the Festool fence T-track? Specific recommendations?
Für uns...ist das Beste gerade gut genug!
Offline jobsworth
  • Festool Baby.....
« Reply #22 on: November 15, 2021, 09:15 PM »
I swapped to T bolts
Offline Luis (ridgenj)
« Reply #23 on: December 29, 2021, 09:50 AM »
Cheers. Bryan.
Dear Bryan, interesting setup and thanks for sharing. Could you possibly post a picture for noobie's like myself.
Cheers
Luis
