Author Topic: Festool Trivia: which tool comes with a 10mm wrench?  (Read 754 times)
Offline eightball
« on: July 17, 2021, 02:04 PM »
Okay, not trivia just something that's bugging me.
I found a 10mm wrench in my domino systainer that I clearly chucked in there thinking it went there. It's identical to the other router wrenches that come with festool.
So I don't lose my mind - which tool comes with a 10mm wrench?
I figure this will be a quick answer for someone on here.
Thanks!
Offline Paul_HKI
Re: Festool Trivia: which tool comes with a 10mm wrench?
« Reply #1 on: July 17, 2021, 03:00 PM »
What's the part number on the wrench?
TSC 55, TS 55, DF 500, DF 700 (XL), OF2020EB+, OF900E, CXS, TXS, T18+3, PDC 18/4, RO 150, RAS 115.04e, RTS 400, ETS 125, ETS 150/5 EQ, CTL MIDI, FESTO SR151 E-AS, CTL-Sys, MFT/3, Sys-Roll etc.
Offline rubber_ducky
« Reply #2 on: July 17, 2021, 03:34 PM »
The domino comes with a 10mm wrench. Used to both change cutting bits and to release the body from the fence (which you do to change cutting bits)
So your wrench wasn’t far from home
Offline guybo
« Reply #3 on: July 17, 2021, 03:52 PM »
domino is 8 mm,waf8.guy
« Reply #4 on: July 17, 2021, 05:09 PM »
You’re right… my bad
Offline clark_fork
« Reply #5 on: July 18, 2021, 10:57 AM »
No matter the size, either for the 500 or 700, they are cast in disapearium, subject to immediate mislay.
I drilled out mine and attached it to a ski pass lanyard and attach it if I have a couple of sequential bit changes.  Otherwise, the wrenches go in a tool box where I keep wrenches and drivers. This after I wasted time trying to find it in the systainer.
Clark Fork
"A lot of people are afraid of heights. Not me, I'm afraid of widths."  Stephen Wright
"straight, smooth and square" Mr. Russell, first day high school shop class-1954
" What's the good of it?" My Sainted Grandmother
"You can't be too rich, too thin or have too many clamps." After my introduction to pocket joinery and now the MFT work process
"Don't make something unless it is both made necessary and useful; but if it is both necessary and useful,
don't hesitate to make it beautiful." -- Shaker dictum
