Dear Mr. Rowan Wood,
First of all I want to apologize for the long handling time in that case.
Unfortunately I have no contact data than your e-mail address.
Otherwise I would have contacted you personally.
We know that this is an unsatisfactory situation for you.
I think that we had a communication problem and misunderstood each other.
We did an analysis to understand your problem with the CS 70 here in our factory where we produce the saws.
Probably your machine is affected with an machining error, which causes your mentioned gaps.
However to be sure it is necessary to have the affected CS 70 incl. fence in our workshop. In order to keep you workable quick we created the following offer.
Our proposal 1:
We will send you a brand new CS 70, which is checked by the quality department in detail, so you can go on with your working.
However you will receive an invoice for the new CS 70.
Afterwards it would be great, if you will send the affected CS 70 incl. fence to my hands for further analysis.
After receiving the affected CS 70 you will get credit advice, so there is no disadvantage for you.
Proposal 2:
You will send the affected CS 70 incl. fence to my hands.
After receiving the affected CS 70, we will send you a brand new CS 70, which is checked by the quality department in detail, so you can go on with your working.
After checking the affected machine, we will appreciate your effort in that case (sending the machine to Germany) e.g. with consumable material.
Probably it is also possible to handle the transportation with our DHL-account. I will check this tomorrow.
Did you already register your affected machine?
If yes, we will organize the re-registration to your new CS 70, so you will have no other problems with that.
I hope that my clarification above helps you to understand, that your concern is very important to us and we are willing to help you.
If you have any questions do not hesitate to contact me.
Kind regards
David Kiel
