The guide rail adapter isn't really designed for squaring.
@TSO_Products can probably confirm on this, but when you're running long rails, you need a
lot of surface contact area to ensure squareness, and the guide rail adapters simply don't have enough.
One of the early things I had to learn the hard way with the guide rail squares is that they need to be fully inserted into the rail in order to be square. You can partially-insert them if you're trying to stretch a rail that's just barely too short to reach the other side of your material, and they'll
look square, but if you actually measure them, you'll find they're off by a degree or two -- basically invisible to the human eye, but an error that will really add up if you're making a long cut. I would expect the guide rail adapters to be similar: if you try to use one at the end of a rail to square it with the parallel guide rail, it's probably going to look square while being slightly off. You could fix this if you have a large and accurate enough framing square to do the alignment by hand, but if you have one of those, you can just use it to align the guide rail and you don't need the parallel guide for the purpose.
My personal opinion is that if you want both squaring and paralleling, the cheapest you're going to get it (with TSO, anyway) is by getting the basic 30" TPG set ($190) and the GRS-16 ($160) for a $350 total cost. Trying to short the pieces of that set to save money is almost certainly going to cost you the accuracy that makes the pieces so expensive in the first place. And if sub-millimeter precision isn't that important to you, there are a lot cheaper solutions you can buy or build to get things "close enough".
