Author Topic: Festool OF 2200 for inlay work?  (Read 1047 times)
Offline Far North
« on: April 10, 2019, 04:38 PM »
Hello all, this is my first time posting here. I've found this site VERY useful for my last couple Festool purchases and wanted to ask folks opinions on the OF 2200 router. I am not a production shop or anything, but I do sell a fair bit of product. Mostly turnings, cutting boards, benches, step stools, and small end tables/ coffee tables (and hoping to keep expanding as I get better and more experienced :-)
I have been using a small 1 1/4 hp Makita router with a plunge base to do everything. I am looking to upgrade to either the OF 1400 or the 2200 to have better all around performance (chamfering, rabbiting, dado work) and to use with free hand inlay work. Also it would be nice to use bits with a 1/2" shank for some of these tasks.
I find that when using my Makita it gets pushed around very easily when I am routing the recess for an inlay and from what Ive gathered, the extra weight of a larger router would be to my advantage. I was pretty set on the 1400, but I have noticed that others state it is difficult to see the router bit with the dust attachment on. Being able to see the bit is critical so I can meet my scoring mark precisely. I notice the 2200 has awesome dust collection and a great line of site to the bit. But I know I don't necessarily NEED that power and the 1400 would be plenty powerful for what I do. Does anyone have any thoughts on this matter? If the 1400 had a built in dust port similar to that of the 1010 or preferably the 2200, the 1400 would be my choice. And of course I like to think I would use the 2200 to its full potential, but I don't see myself doing that for quite some time.
Forgive me if this topic has already been covered or for my ignorance! I still consider myself a fledgling  :)
Offline Jim_in_PA
Re: Festool OF 2200 for inlay work?
« Reply #1 on: April 10, 2019, 06:12 PM »
One factor you have to weigh in to the decision is...weight. The OF2200 is quite a stout machine and therefore, it may or may not be comfortable for you to operate for detail work like inlays, depending on their nature, etc. The OF1400 is more agile in that respect.
ETS 150/3, Rotex 150, OF1010, OF1400, Trion PS 300, TDK-12, CT-22, MFT 1080, TS55, Domino XL DF 700, 8' track, (2) 55" tracks
SCM MiniMax S315WS, FS350, MM16, Camaster Stinger II SR-44 CNC
Offline Russty
« Reply #2 on: April 11, 2019, 06:11 AM »
Hi, i have the 2200 and it is quite heavy, but given you dont need the power it may be better to add some weight to the 1400 or even your makita. From what i gather the of2200 is geared towards being mounted in a router table and can be very cumbersome for hand work although i have got used to it. you would need to remove the bottom shroud for visibility if you are using small cutters but you should still get good extraction if you have a powerful vac.
i dont do very much detailed work especially along the lines of marquetry but i guess you need to balance somewhere between too much and little friction.
Offline Jiggy Joiner
« Reply #3 on: April 11, 2019, 06:26 AM »
The bigger routers are really a sort of final step before getting into spindle moulder territory.
The big powerful routers are usually heavy, which for me isn’t a problem, as when routing free hand etc, the weight helps with wielding. When used with a table, obviously the weight has no noticeable effect.
The 2200 is quite heavy, and very powerful and makes work with hardwoods detailed cutters a breeze.
I have a few routers, and always seem to use the smallest I can get away with for any given job, apart from my table mounted ones.
Offline nvalinski
« Reply #4 on: April 11, 2019, 08:34 AM »
Do you need a heavier router or just a larger baseplate for your current Makita? Having something like this would give you a little more control by having more of a lever arm to hold on to and maneuver the router. You can make your own with a piece of acrylic and drill it out as needed.
« Reply #5 on: April 11, 2019, 09:58 AM »
That’s a good idea, maybe even bigger and stouter and add some lead weight. And with the larger surface area you can add a very effective light.
Offline jobsworth
  • Festool Baby.....
« Reply #6 on: April 11, 2019, 11:09 AM »
yes the 2200 is heavy. But it is very and I mean very well balanced easy to use freehanded. But for inlay work, it might be a bit over kill. With that being said, I have no issue useing mine free handed even though it spends most of its time in the table
Offline Far North
« Reply #7 on: April 11, 2019, 11:44 AM »
That does look simple and pretty ideal for what I would need with the inlay work. Adding some form of dust port would be ideal, but probably not too difficult. I may give that a try before diving in, even adding a wider base to my current plunge base. Also sounds like the 1400 could easily cover my other needs that the Makita isn't quite living up to...
Offline Far North
« Reply #8 on: April 11, 2019, 11:48 AM »
Do you use yours with a CMS set up? Ive read elsewhere people like to use their 2200 free hand when they can, but being able to easily remove it from certain router tables can be too time consuming to make it worth the effort.
Offline Far North
« Reply #9 on: April 11, 2019, 11:58 AM »
Thanks everyone for the replies, right now I'm planning to play around with the makita for my inlay stuff by adding a heavier/ wider base to the plunge base. shouldn't be too difficult, just drilling out the hole pattern and I have some 1/4" stainless I could play with adding to it... Might be a bit of a Frankenstein but who cares as long as it works!
I might however look more seriously into the 1400 for the do everything router, dados and such, and perhaps later a cheaper PC or Triton router as a designated table router. For the price of the 2200 I could potentially get this combination. Does that seem like a sound decision to folks? I guess before I was thinking the 2200 would cover both of these territories (and perhaps the inlay work) but it does seem like it would definitely be overkill to do everything with.
Offline rmhinden
« Reply #10 on: April 11, 2019, 12:13 PM »
I have the PC 75182  and a router lift in my router table.   Works well and allow adjustment from the top.   I also have a Festool OF 1010 for handheld routing.
Bob
Offline Svar
« Reply #11 on: April 11, 2019, 12:40 PM »
I agree. For inlay work you need your arms to rest on the work piece/table and control the router with your wrists. As great as it is OF2200 will not help with that.
