Author Topic: Festool of 1400 eq plus usa router metric?  (Read 664 times)
Offline zachjowi
« on: April 02, 2021, 07:35 PM »
I have a 574342 OF 1400 EQ plus usa but the scale on the router is metric.  Does this make sense?  Maybe it's just usa model because it's 120v 60hz?
Offline Peter Halle
Re: Festool of 1400 eq plus usa router metric?
« Reply #1 on: April 02, 2021, 07:49 PM »
According to the part number you have a metric model.  Use it well!
Most router techniques for depth now do not really rely on the scales.  Thickness blocks and other ways of setting depth are usually more accurate than the scales on the tools.
Offline DeformedTree
« Reply #2 on: April 02, 2021, 08:02 PM »
All Festool tools until ~2016ish had metric everything.  Then in the North American market they began only putting inch based scales on them. The router itself is still metric no matter the scales. All the internals, when you turn the knobs, it moves in metric increments.
This has nothing to do with the voltage/frequency.
Offline zachjowi
« Reply #3 on: April 02, 2021, 10:43 PM »
Are the metric versions sought after?  I got an imperial version with a collection of tools and was going to keri that and sell the metric.
« Reply #4 on: April 02, 2021, 11:11 PM »
Depends, as someone looking for a metric tool and the answer is yes, ask someone who prefers "imperial" and they will say no.
In general, when metric versions come up on sites like the festool recon site (site for reconditioned tools), metric tools disappear fast.
Right now, all festool tools are demanding a price since all the stores are out of basically everything. So you won't be able to determine if it is a metric/imperial issue.  I know on the routers, vendors sell the factor scales to replace on OF1010 and OF2200 routers to make them metric. I haven't seen anything for the OF1400, so I don't know if that has a harder conversion, if it is, then yes, it could hold more value than one in inch.
If you want an inch labeled one, I'd look to find someone looking for a metric unit and see if they want to do a swap (they get a metric unit, you get an inch unit). If you are just looking to sell, well, you are in a good time to sell no matter what.
Offline Joe Felchlin
  • Just another day in paradise - Livin’ the dream!
« Reply #5 on: April 03, 2021, 09:00 AM »
My OF1400 is METRIC.
Adjusting from IMPERIAL to METRIC took a little doing at first -
But now I prefer METRIC - It’s much easier to work with.
Even better - Like Peter - I prefer using GAUGE BLOCKS whenever possible.
They’re - SIMPLER - PRECISE - And REPEATABLE.👍
« Last Edit: April 03, 2021, 09:37 AM by Joe Felchlin »
FESTOOL: CT26, CT33 E HEPA Dust Extractors, MFT 1080, MFT-3, TS 55 REQ-F-Plus USA, TS75 EQ, Guide Rails: 1080's/1400/3000mm, LR 32-SYS/Holey Rail, Parallel Guides & Extensions, Plunge Routers: OF1400 EQ & OF1010, Sanders: RO125 FEQ Rotex, LS 130 EQ Linear Detail, DX93E Detail, Drills: PDC 18/4 Li QuaDrive Cordless Drill Set, C12 Cordless, CXS Cordless Compact Driver, SYS-Centrotec-Set, Dominos: XL DF 700 EQ Plus Tenon Joiner Set, DF 500 Tenon Joiner, VAC SYS: System Set, SE 2, Accessory Set | WOODPECKERS: DF 500 Offset Base System | BOSCH: 5412L Compound Miter Saw, 4100-09 10-Inch Table Saw | POWERMATIC: 60HH 8" Jointer, PWBS 14" Bandsaw w/Riser Block | MAKITA: 2012NB Bench Top Planer | JESSEM: Mast-R-Lift XL/Fence/Slide, Rout-R-Plate/Table Stand | RIKON: 50-120 6inX48in Belt-Disc Sander | JET: JBOS-5 Benchtop Oscillating Spindle Sander | PORTER CABLE: 7518 and 690LVRS Routers, 557 Pro Plate Joiner, 16/18/23 Gauge Nailers | LEIGH JIG: D4R 24 Pro Dovetail Jig, | LIE-NIELSEN: Almost every hand plane | DOWELMAX: 3/8" and 1/4" | KREG: K3 Master System | FEIN: Multimaster FMM 250 Q Kit | TORMEK: Super-Grind 2000 | DUST DEPUTY: Industrial (ALL) Steel Deluxe Cyclone (2)
