I'm away from my tools at the moment so I can't verify what "neck size" my ~decade-old US-made 1/2" Milwaukee drill has. But, if I had to guess, I'd wager it's not 43mm.
I believe it's 46mm because I was also looking at using the Wabeco stand with a 1/2" Milwaukee for simple outdoor projects when you're away from the drill press.
OK, thanks so much for the info!
And, although you correctly assumed that my drill has a "neck" (I've noticed that many drills nowadays - at least those that don't have an allowance for the installation of a right angle stabilizing handle - go directly from motor housing to the spinning end of the drill, so no "neck" to speak of) I should have stated that my drill features a splined neck that is designed to accept the right-angle stabilizing handle that it originally came with. This uniform "neck" gives me some hope that I can make my corded drill work with a euro-drill stand. Now to contact Wabeco to see if they can assist in devising a workaround to my drill's non-standard neck diameter/design.
I should note that I don't have a shop (only a storage room) which is the primary reason behind my moving in the direction of a drill stand. I don't want (nor do I want or have the dedicated space for) a drill press. Plus, I'm addicted in all areas of my life to tools/devices/spaces/stuff that have multiple uses/functions - like a telephone that is also still camera, video camera, audio recorder, computer, etc., or a TS 75 which is a track saw but also the business-end of my CMS table saw (w/sliding table), the latter of which is also my router table, soon-to-be sanding table and soon-to-be jigsaw table, etc. For my various uses (and owing to the self-imposed limitations demanded by my oath to voluntary simplicity), my mantra is, "Why own a dedicated tool when I can own one that can accomplish multiple functions?" Therefore, a high quality drill stand (which I can also perhaps adapt to my Fein Mulitmaster, which, as its name implies, is also adept at accomplishing numerous tasks) is right up my alley.
