Author Topic: Festool CT MINI I vs MIDI I: is the only difference the base?  (Read 667 times)
Offline Josh2
I made the big mistake of purchasing the CT mini several months ago. Great vac but it’s just too small for me. Now I am wondering whether the only difference between the two vac is the base? Aside from a higher base, I can’t recognize a difference in the pictures and specs. So my questions are: a) Is the base exchangeable so that in theory it is possible to convert a Mini to a Midi and the other way around? B) if that is the case, does Festool sell the vacuum base as spare parts?
Thanks!
Offline Alex
Re: Festool CT MINI I vs MIDI I: is the only difference the base?
« Reply #1 on: October 13, 2020, 08:34 AM »
Yes on all parts.
Mini & Midi are the same and the base is interchangeable and sold seperately.
You can order the part through a dealer or, if you're in the USA, through Festool directly.
Offline Josh2
« Reply #2 on: October 13, 2020, 09:21 AM »
Thanks! That is awesome. So the only part I need to order is 203730, which is the container and includes the wheels and all the others part of the base?
Where exactly can I order the part in the USA? Sorry, the festool website is not very helpful.
Thanks!
Yes on all parts.
(Attachment Link)
Offline FestitaMakool
« Reply #3 on: October 13, 2020, 10:18 AM »
As Alex said, they are identical apart from the bin height.
I ordered the complete (as your part no’ 203730) MIDI bin for my MINI, it came complete with locks, roll stop, casters and wheels readily assembled. All you have to do is lift the top over to the other bin. You can swap bins in a heartbeat if you need a lower dc.
For the price, there’s a lot of parts, and some good value in it in just the parts.
Edit: I have the optional handle mounted on the MIDI bin, as the handle is only mounted to the bin I can swap to the MINI bin and suddenly have a very compact dc to go.  [big grin]
« Last Edit: October 13, 2020, 10:22 AM by FestitaMakool »
Offline TinyShop
« Reply #4 on: October 13, 2020, 10:21 AM »
@Josh2  - call Festool USA and order the part over the phone. Very easy process.
ETS 150/5 EQ (DE) [po], TS 75 EQ (DE) [po], OF 1400 EQ-F (DE) [n], CXS (DE) [n], CMS-GE [DE] [po], CMS TS 75 (DE) [n], LA-CS 50/CMS (DE) [po], VB-CMS (DE) [n], MFT/3 (CZ) [n], DF 700 EQ w/Seneca Small Mortise Kit (DE) [po], FEIN Multimaster 350 QSL (DE) [n], Bosch 1274DVS w/dust collection, sanding frame,  stand & fence (CH) [n], BOSCH 1590EVS w/dust collection (CH) [n], CS Unitec CS 1445 HEPA extractor <re-branded Starmix ISP 1435 H> (DE) [n], CT SYS (DE) [po], Milwaukee 0302-20 (US) [n], Two (2) Porter Cable 862 (TW) [n], Porter Cable 447 (US) [n], Zyliss Vise (CH) [nos], Hitachi C 8FB (JP) [h], Walko 4 MKII (NL) [nos], Festool MFS 400 w/add-on 700 profiles & router slide (DE) [n], Festool RAS 115 (DE) [n]
[po] pre-owned   [n] new   [nos] new old stock   [h] heirloom   (XX) country of origin
Offline Coen
« Reply #5 on: October 13, 2020, 11:00 AM »
Look at the price of the part. Might be better off just selling your MINI and buying a new MIDI.
Offline Pizza Steve
« Reply #6 on: October 13, 2020, 11:31 AM »
Adding an Ultimate Dust Deputy to your CT Mini will also increase your volume!
