Author Topic: Festool CSC SYS 50 Tablesaw  (Read 13574 times)
Offline Hale1960
    • Mungo and Co
« on: March 12, 2023, 06:49 AM »
Hello,
I recently bought a CSC SYS 50 table saw and must say I’m really pleased. I have a slight issue with the cross cut fence, not in its quality or accuracy but the lack repeat stops. Has anyone made a modification. I am also looking for a wider kerf blade to cut kumiko strips, any thoughts?
To help with this I am making a auxiliary fence and a Fritz and Franz jig for the saw. When finished I’ll make the drawings available.
Incidentally I have been looking for a small, accurate saw to replace my old Jet saw after downsizing my workshop. I will let you know how this goes in a few months!
Regards,
Hal
Hal Eccles - Mungo and Co
Offline Peter Halle
  • Ain't so Small no More
Re: Festool CSC SYS 50 Tablesaw
« Reply #1 on: March 12, 2023, 07:11 AM »
Welcome to the FOG!
With the saw so recently introduced I would imagine that you might have to experiment some.  Looking at the miter gauge on the Festool.uk ekat website it looks like you could possibly make something that goes up and over and evenly uses the slots on the back for fastening.  That would take some thinking to get around the mounting head, but making some blocks with offsets on the work side might be an idea.
If you try, please post back with pictures!
Offline Hale1960
    • Mungo and Co
« Reply #2 on: March 12, 2023, 07:56 AM »
Thanks Peter!
Offline Bencan
« Reply #3 on: March 13, 2023, 04:28 PM »
Ya I’d be really interested in hearing more about real world usage of the saw. Congrats on the purchase and enjoy
Offline woodferret
« Reply #4 on: March 13, 2023, 05:17 PM »
I'd be interested in see the Fritz and Franz jig on such a small table when you get that worked out.  I'm leaning heavily towards getting the CSC50 myself.
Offline Hale1960
    • Mungo and Co
« Reply #5 on: March 16, 2023, 06:19 AM »
Thanks for the replies!
So far I’m very impressed with the saw, I’ve been cutting 18mm Baltic birch ply with no problem (not full sheets). I’m quite lucky that there is a good merchant near by that will cut sheet materials down for a reasonable price (much easier than breaking down with a track saw in a small space).
I was a little surprised how quickly the batteries went down from the first charge but they do recharge quite quickly, maybe battery life will improve with use.
I’m doing quite a bit of box making and the CSC is perfect for this and I think a small Fritz and Franz jig will really benefit with safe accurate cuts. Prototype one of the jig is on its way.
Like most things there are compromises with this saw, I may have a play with auxiliary fences for wider rip cuts but I think with my very limited sized shop the saw is a good (although expensive) choice. Another benefit is it’s portability.
Offline Jim_in_PA
« Reply #6 on: March 16, 2023, 10:20 AM »
While this particular tool isn't a fit for me, as a sliding table saw owner, I truly appreciate what Festool did with this great machine. It brings a lot of the "why I own a slider" to a smaller, compact form factor that will absolutely kick things up for folks who need/want the size AND the features. If I had to do a serious downsize to a tiny shop, this thing would be on my list for sure. (although I'd prefer to be able to work plugged in rather than on batteries)
ETS 150/3, ETS EC 150/5 EQ, Rotex 150, OF1010, OF1400, Trion PS 300, TDK-12, TRK-15, CXS-10 (2), CXS-18, CT-22, MFT 1080, TS55, Domino XL DF 700, 8' track, (2) 55" tracks
SCM MiniMax SC3C, FS350, MM16, Camaster Stinger II SR-44 CNC, Harvey G700, Stubby 750, TruTrak slab flattening, SM 19-38 drum sander
Offline squall_line
« Reply #7 on: March 16, 2023, 04:01 PM »
I have a feeling that, like many other things when switching from corded to cordless, there's also a workflow adjustment that helps with battery life, too (remembering to turn off the saw between cuts, etc).
Offline ElectricFeet
« Reply #8 on: May 21, 2023, 05:23 PM »
I’ve only owned mine for a couple of days (!), but the mitre fence is my only disappointment so far. I wish it had more clamping / stop options too. It seems like the one afterthought. I had hoped that the attachment points would accept a 2040 with a simple change of the nut, but it’s not compatible unfortunately (unless you slice a bit off the bottom of the 2040 — I’m tempted!).
In the short term, I’ll be using the the rip fence for stops. If you undo the knob, part of the fence slides forward in front of the blade (leaving space behind it) allowing you to use it as a stop, without the risk of material being trapped / getting kickback. Would that work for you? Or am I missing something in your question?
:-\ The manual seems pretty intransigent on blade dimensions — even specifying that the saw plate thickness has to be 1.2mm and the kerf has to be 1.8mm (unlike, for example, the TSC 55K, which allows 1.1-1.4mm for the plate and the HKC 55, which allows up to 2.2mm for the kerf). It doesn’t look like there’s an official solution for that.
Thanks for this [smile] The Fritz and Franz jig was news to me, as I’ve never had a sliding table before.
If I were to make one for the CSC SYS 50, I think I would make use of the clamping groove rather than use the mitre fence. It’s effectively a second slot and if both pieces of the jig use both slots — with the forward one clamped in the clamping groove* — it would be very stable and could be made to a very high level of precision/accuracy.
* maybe with a t-bolt and knob, rather than a clamp.
Offline JimH2
« Reply #9 on: May 21, 2023, 08:02 PM »
The whole saw is a compromise since the primary goal was to fit it in a systainer. Of course the fence and miter bar are going to be crappy just as they are for all small portable table saws and given it uses a battery there will be blade restrictions and limited run time. the digital height and angle setting features are very nice and the SawStop technology is a requirement if safety is paramount. There have to be big gives as you go smaller on almost anything.
« Reply #10 on: May 22, 2023, 10:24 AM »
Fitting such a small saw in a systainer is its genius. Ultimate portability.*
The fence and mitre bar are absolutely not crappy. Have you seen the saw? Touched it? In photos / videos, it looks a bit like it might have the build quality of a laserjet (which in itself would be waaay above the build quality the Proxxon FET, for example). But it’s not. The build quality is the best I have ever seen in a Festool — and I have many of the “flagship” products. This isn’t just up there with the best, it’s way better.
The mitre fence is plain and has no points of attachment. But it’s not crappy.
The rip fence is really really solid / square, with ways to attach jigs. The pull out feature is a nice addition.
The mitre locks in place and is rock solid with the slider. And the slider is amazingly solid and square. No play in it whatsoever. Super glidey. It’s a really fine piece of engineering.
Blade choice is indeed restrictive, but you can cut to a height of 50mm, which is enough for me.
I haven’t tested all-day use on the batteries, and likely never will, as I won’t be laying floors with it. But even if they don’t last a full day, just get a couple of spares. Or throw them in the charger while you have lunch. I don’t get battery “range anxiety”, but I know some feel it acutely (and I’m about to find out, because I’m selling my HKC 55 with its charger in the next few days (and it’s my only charger) and the new charger hasn’t arrived yet  [scared])
SawStop would have made it a slam dunk for many, but there just isn’t the room.** I’m sure someone somewhere is working on a smaller design, but clearly it’s not ready yet. Maybe at some point in the future. In the meantime, the riving knife and blade guard are very easy to switch in and out, which means they will get used. No screwdrivers etc needed — just an internal button that you use the allen key to push.
I’m borderline on the fold-up table. It’s a very well executed fold up table, as fold-up tables go, but perhaps the addition of an extra locking mechanism would make it even better. It has a tiny amount of play front/back (around 0.2mm — you can feel and hear it, but hardly see it), but none side/side, and no up/down where the tables join. There’s a slight amount of up/down play at the extremity, but gravity is holding it down and you’re pressing down in use. And the extremity is adjustable if it gets out of flat with the main table.
Throwing in a couple of zero clearance inserts would have been a nice addition. They have a complex geometry and would really need a CNC / Shaper Origin / 3D printer to make new ones.
As I say, I’ve only had it a few days and the mitre fence is the only thing I can really criticise.
Otherwise, it’s very innovative and a major achievement / milestone for Festool — a change from just trying to producing a better jigsaw / track saw etc. to rethinking the whole machine.
*  I also hope it’s the first of many in this form factor. I’m space-constrained (as are many in Europe / in cities) and could use the space. E.g. I’d sell my CMS immediately for a smaller systainer version of a router table — and this saw’s surface area with the table folded out is as already big as a CMS. Developing the idea further: they have the sliding table and a lift mechanism in the saw already. Add a small router spindle like the Shaper Origin’s and drill a couple of holes in the table for a fence and voilà [big grin]. When can I order?  [big grin] [big grin] [big grin]
** or rather, inside there is a surprising amount of room. Maybe in a future version they will use it all for something.
Offline pixelated
« Reply #11 on: May 22, 2023, 10:26 AM »
Does anyone know if the CSC Sys 50 is being shown in the "Festool Experience" road show they've been doing in the U.S?
This saw seems like it might be a good fit for my needs with the possible exception of its cutting capacity. It would be nice to be able to see one in person.
Offline timwors
« Reply #12 on: May 22, 2023, 12:51 PM »
I don’t know about the US but they did a bit of a UK tour with it earlier this year. I saw it at an Axminster store and even got to do a couple of test cuts with it. It is extremely impressive. I completely agree with ElectricFeet that it exudes build quality. The sliding table is absolutely rock solid with no play whatsoever. Amazingly quiet in operation, and excellent cut quality (one of the demonstrations was on a piece of laminated worktop). Only downside for me was the price!
The Festool reps acknowledged the size restriction but made the fair point that if you are intending to break down sheet goods, they already have other options at your disposal.
Offline woodbutcherbower
« Reply #13 on: May 22, 2023, 02:25 PM »
I've spent 34 years on the tools as a professional, and I've never owned a table saw. My (probably deeply flawed) logic was that unless it was huge and capable of breaking down 4' x 8' sheets more quickly and accurately than a TS55, then it wasn't an expense I needed to burden myself with. Then this darn thing appeared. I remember posting on here when the first 'sneak peek' cellphone video appeared, saying that "I don't need a table saw - but if I did, I'd buy this one".
I started to remember all of the times when I needed to make dozens of identically-sized strips, or similar repetitive work which needed to be super-accurate - and I also remembered a hundred other things, including the ridiculous amount of time I must have spent over the years making jigs to ensure that strips ripped on a TS55 were all the same width, just for starters. I've watched Festool's compelling (but cripplingly cheesy, monumentally awful) videos. They're a global leader, for Chrissakes. How can they endlessly, repeatedly not get this most fundamentally basic of promo stuff right? The videos on YouTube all have one thing in common - "Comments are turned off" indicating that I'm not alone in my thoughts on this topic. But hey - whatever.
It's an incredibly clever and truly innovative piece of equipment. Beautifully designed, well-built, quiet, lightweight, portable ...... the list is a long one.
I think you can see where I'm going with this ......
EDIT = and just in case you were thinking that the Festool videos were terrible because Germans allegedly have no sense of humour - just check this out. Translation = 'Das Bild haengt schief' = 'The picture wasn't level' ....
Kevin
« Last Edit: May 22, 2023, 06:05 PM by woodbutcherbower »
« Reply #14 on: May 22, 2023, 03:17 PM »
Yup. My experience too (but without the 34 years as a professional [big grin]). Right now I need to cut 6 French cleats in 19mm birch ply, from a piece that is 1300x400mm. That would be a real stretch with my TSC 55K, or my Byrnes tablesaw (no easy and consistent 45 degree option (and it’s just too small)), or the Proxxon FET that I gave away (forget using that for literally anything) or the HKC55 I’m selling. If I had space, I would have bought a SawStop ages ago, but I don’t. The CSC SYS 50 is what I’ve really needed all these years and all roads led to here. Sounds melodramatic, but I’ve been battling with this conundrum — no-space-for-consistent-rip-cuts — for years.
I struggled with the decision — price mainly. Then I found a buyer for the HKC 55 and it became a lot easier.
Offline Packard
« Reply #15 on: May 22, 2023, 04:25 PM »
Your original post had be confused.  I am guessing that you need the wider kerf for the jigs that you will use to cut the strips.  I can’t imagine that you would cut the strips on a table saw.  I would guess that a band saw would be the saw of choice for that kind of work.
If that is the case, Whiteside (and others) make router bits for cutting slots as small as 1/8”.
https://www.whitesiderouterbits.com/collections/solid-carbide-straight-bits-two-flute
Amazon sells several in lots of 2 to 5 (breakage must be a problem).
Also Dremel makes smaller bits for their tools (I’ve never tried cutting slots with a Dremel).
« Reply #16 on: May 22, 2023, 04:51 PM »
Here’s a vid showing how it’s done on a tablesaw:
http://www.youtube.com/watch?v=kxG-NbUzMVE?t=548
« Reply #17 on: May 24, 2023, 02:20 PM »
Stop press: I’ve just noticed that that if you take off the rip fence (with a simple turn of a knob), you can use it (in the same orientation—with the tall side up) in the cross-cut fence (again, with a simple turn of a knob). This would allow you to make a flip stop (or an l-shaped block) that can run along the top slot. It’s much longer than the mitre fence (thus allowing stops quite a way out).
(It can also be attached with the tall side flat-down, but I’m not sure how this would be useful.)
Offline dunk
« Reply #18 on: June 12, 2023, 08:29 AM »
My setup.
« Last Edit: June 12, 2023, 12:47 PM by dunk »
Offline Bencan
« Reply #19 on: June 12, 2023, 06:00 PM »
My setup.
Ok that’s pretty cool. How’s the saw working out overall?
Offline dunk
« Reply #20 on: June 13, 2023, 01:09 AM »
Very good so far, battery life is good too.
Sent from my iPhone using Tapatalk Pro
Offline woodferret
« Reply #21 on: June 13, 2023, 09:07 AM »
Thanks for confirming the mini Bow feather works on there.
Offline woodferret
« Reply #22 on: July 07, 2023, 09:59 AM »
I am relative newbie to european style sliders... but one question came up for me.  How does one do a rip cut with a bevel since the blade tilts towards the fence?
« Reply #23 on: July 07, 2023, 10:11 AM »
As usual, just need to find a way to add a hold down to the fence in case the wood wants to bow up.
« Reply #24 on: July 07, 2023, 01:01 PM »
Per to the manual, you:
  • Remove the preset profile setting rail [= the mitre gauge]
  • Fit the parallel side fence [= the (removable) fence]
  • If the saw blade is inclined towards the par­allel side fence [9B] [it always is, unless you're cutting at 0 to -10°]:
    • Rotate the stop rail [9-1]  [=the alu profile attached to fence] so that the lower side faces the saw blade so that there is more space for the push stick and the saw blade does not come into contact with the stop rail [=so it's more like a backwards L, rather than a P]
    • If there is still insufficient space for the push stick between the protective cover [blade guard] and stop rail, use a push block [not supplied -- a grripper works well]
    • In order to prevent jams and workpiece kickbacks [which is what I presume @woodferret is asking about], set the stop rail so that its rear end is at the height of a 45° line leading from the centre of the saw blade
  • Set the inclination angle of the saw blade on the control module [the screen]
  • Guide the workpiece along the parallel side fence
And the relevant pic, to make it clearer:
I ripped some cleats last weekend and it worked really well, despite my misgivings about the whole setup.
Side note: I wish Festool had used industry standard terminology when translating this manual into English, rather than making up their own. I found myself constantly having to look at the pics to figure out what they were talking about. "Spacer wedge"? -- what's wrong with riving knife or splitter? And -- splutter --  "preset profile setting rail" for mitre gauge? C'mon ::)
(Though I should say that they deserve credit for having written a slightly better and more instructive manual than usual in this case -- terminology excepted.)
Offline woodferret
« Reply #25 on: July 07, 2023, 01:47 PM »
Thank you ElectricFeet.  I forgot the low fence could be pushed forward too.
« Last Edit: July 07, 2023, 01:50 PM by woodferret »
« Reply #26 on: July 18, 2023, 01:27 PM »
My setup.
I'm trying to understand the flat blade cover in @dunk 's picture. Festool show how to create one in their quick guide video:
As a newbie table saw user, I cannot figure out when I would want use it.
  • If I'm doing a wide rip cut or a cross cut, then -- at least from Festool's point of view -- the supplied blade guard should do the job, shouldn't it? (I know that a lot of woodworkers never use the supplied blade guard, for various reasons.)
  • If I'm doing a thin rip cut, then I don't want a blade cover or blade guard at all, as I will generally want to use a push stick or push block, at least at the end -- and this flat cover or the supplied blade guard would interfere with that (and also may interfere with the fence).
  • Festool's video says: "For special work (e.g. groove cuts) you have to cover the saw blade. In this video we show you how to make such a cover quickly and easily.". But why would you want to cover the blade for a groove cut? Aren't you using a push block in this scenario?
So why does Festool show us how to build one of these?  The phrase "For special work (e.g. groove cuts) you have to cover the saw blade" sounds like they are citing a legal requirement, but if so, why isn't the cover included with the saw?
Under what circumstances would I want to use this? @dunk 's example -- for partial thin rip cuts -- seems like a situation in which I might want a flat cover, but it's not what Festool is saying.
And a secondary question: Does it help with dust collection in some scenarios?
I'm an experienced track saw user, but I'm new to table saws with the CSC SYS 50. So still finding my way.
Offline woodferret
« Reply #27 on: July 18, 2023, 02:08 PM »
There's a joke I heard from a German carpenter that they went into building kid's tree houses because they finally get to work with wood.
The CSC50 is targeted for those engineered materials so one assumes it's relatively flat/stable and can thus run a groove without a over blade pushblock like the Grr-riper or shoe.
The picture IF it was intact stock, would have been considered lazy and one should have switched to the full guard for a through cut.  But, the notches in the pictured stock make it 50-50 on whether the guard and paws would catch - so this is one of those special situations I guess you're talking about.
Offline dunk
« Reply #28 on: July 18, 2023, 03:56 PM »
My setup.
I personally use it for small rebate cuts, I also like to see what I’m doing and use it instead of the crown guard. I think for me it’s just a personal preference.
I’m not a lover of using a table saw without a crown guard for safety reasons and as I said earlier it gives me a little bit more visibility.
« Reply #29 on: July 21, 2023, 03:38 PM »
Thanks to both. And thanks also to @dunk for showing the bow featherboard fp5 (portable saw version) in the pic. I picked one up and it's way better than my old ones and works with the saw really well.
Offline unknown user
« Reply #30 on: July 27, 2023, 09:19 AM »
Is it possible to use a CT 26 for dust extraction?
Offline squall_line
« Reply #31 on: July 27, 2023, 10:26 AM »
I'm confused by this question, given that the CT 26 is a dust extractor.
Offline guybo
« Reply #32 on: July 27, 2023, 10:58 AM »
@unknown user, if you mean via bluetooth yes, via 202097. Btw welcome to the fog
« Last Edit: July 27, 2023, 11:01 AM by guybo »
Offline whk
« Reply #33 on: September 02, 2023, 07:53 PM »
As far as missing repeat stops go, you might try this.  Remove both the cross-cut guide and the ripping guide.  The ripping guide can be attached to the miter gauge; it slides on and fits perfectly.  When you do this you'll see there's an accessible t-slot.
Now go dig around in your rail guide accessories till you find a flip down stop that fits into your rail guide.  That stop fits neatly into the exposed t-slot.  The flip down piece doesn't perfectly fit this set up, but it will work.  And till you get your Fritz and Franz jig set up, you can use a Festool hold down clamp to keep smaller workpieces attached the sliding table.
Offline JimH2
« Reply #34 on: September 14, 2023, 10:54 AM »
@Bencan I noticed your miter fence is black with graduations on it. Did that come with your saw? Mine has a plain silver fence.
« Reply #35 on: September 14, 2023, 11:21 AM »
That’s @dunk ‘s fence. He explained it here: https://www.festoolownersgroup.com/festool-tools-accessories/csc-sys50/msg695278/#msg695278
Offline squall_line
« Reply #36 on: September 14, 2023, 11:23 AM »
That's a Benchdogs fence (logo in the lower right corner)
Offline JimH2
« Reply #37 on: September 14, 2023, 11:32 AM »
Thanks and available in Imperial. Probably can order it to size to avoid the cut. Now off to making the blade cover.
Offline pixelated
« Reply #38 on: September 14, 2023, 01:59 PM »
They make a right-side support fence, which looks to be ideal, and is 13 inches long. https://benchdogs.co.uk/collections/fence-systems-1/products/dual-scale-right-hand-side-support-fence-only (available in imperial, metric, and dual-scale)
in @dunk 's photos it looks to have bar of the bottom milled off, I wonder if he can confirm?
Offline JimH2
« Reply #39 on: September 14, 2023, 03:35 PM »
Just contacted Benchdog and they are going to make a fence for the CSC. He said check Instagram to see when it is ready.
Offline Frodebro
« Reply #40 on: September 17, 2023, 10:35 AM »
Hey, is there an adjustment for leveling the sliding table?  On mine, the table slopes downward, with the outside edge sitting approximately 1mm lower than the level of the fixed table.  This results in mitered cuts being not quite square if the workpiece is sitting flat on the sliding table.
Offline pixelated
« Reply #41 on: September 17, 2023, 04:05 PM »
There is a procedure in the manual for adjusting the sliding table. I've only skimmed that part, since mine seems to be ok.
« Reply #42 on: September 17, 2023, 05:05 PM »
There are two procedures. One covers horizontal alignment with the blade; the other covers height. The don’t cover sloping down from the blade.
Maybe you could do up/down and add a shim on the far side.
I’m interested in the, because mine slopes slightly too. Not as much as @Frodebro ’s, though.
Does anyone else have this?
Offline woodferret
« Reply #43 on: September 17, 2023, 10:27 PM »
* Don't have the CSC yet
but it's probably the 25-5 screw they adamantly tell you not to touch ;)  It's kinda in the right place next to the eccentric.
There are also two screws that attach the two rails to the guide base... but my bet is 25-5.
Offline InspektorGadget
« Reply #44 on: September 18, 2023, 10:20 AM »
I'm looking at replacing my large table saw with this Festool saw due to shop size constraints.  I'm pretty invested in the Festool ecosystem, so my question is what is the height of the table saw when it's set on the stand?  I am assuming that I could use my MFT as additional outfeed support and that the heights would match, but for some reason I'm having a hard time finding the dimensions.
In my world, It would sit folded on the cart tucked away, so if I pull the cart out and set it up next to my MFT I'm hopeful they ensured they line up perfectly and any insight would be appreciated.
Thanks!
Offline pixelated
« Reply #45 on: September 18, 2023, 10:43 AM »
Thanks!
Yes, the saw surface height on the stand is the same as an MFT. The foot of the stand can also be used for support
The whole stand is about 4 feet long when set up. So, while the saw is compact the whole rig isn't much smaller than a jobsite saw. But you get a lot more flexibility. For example by rotating the saw 90 degrees, the foot can be used to support long cross-cuts.
Overall, I find it pretty small-space friendly.
Offline Frodebro
« Reply #46 on: September 18, 2023, 11:39 AM »
I guess I’ll either have to dig into it a little bit, or else come up with an alternative solution.
Offline JimH2
« Reply #47 on: September 18, 2023, 01:46 PM »
Thanks!
Give that some serious thought. The CSC is not a replacement for a full size tablesaw. I have an ICS and now the CSC and the latter is for site work and small pieces.
« Reply #48 on: September 18, 2023, 04:09 PM »
Thanks!
If you’re seriously space constrained, then it’s an idea, but as @JimH2 says, it’s not a replacement for a full-sized saw. Infeed / outfeed support is not as good as having infeed / outfeed on the saw itself.
It depends on the quality / size of your current saw, of course, and the type of work you will be doing.
However, I’d also think hard about whether the Festool table is right for you. It uses a lot of space when open. It’s also a pain to continually get out and put away if you’re in a workshop (great if you’re mobile, of course). You might be better off building your own cart to the right height.
See Peter Millard’s video in which he built a small cart for his. He is in a very constrained space:
Offline JimH2
« Reply #49 on: September 19, 2023, 11:02 AM »
You certainly could make nice side and out feed supports, but a front support might be harder given you need to get to the controls. Rip capacity is going to be restricted the existing table size unless someone gets creative and makes an extension table for the right side but that would be very hard to pull off I think.
Offline slomustang
« Reply #50 on: September 19, 2023, 05:35 PM »
Izzy Swan developed an infeed saddle for a few tablesaws. I wonder if that same idea could be applied here.
Izzy Swan Infeed Saddle
Offline pixelated
« Reply #51 on: September 22, 2023, 09:13 PM »
They announced the CSC Sys 50 fence today, it's available to preorder and shipping in October.
Offline dgcope
  • Festool Dealer
« Reply #52 on: September 23, 2023, 01:31 AM »
A friend and I have developed a flag style flip stop that works with the stock fence (rip fence switched to miter gauge position). The stop will work with the fence in either position. I should have some ready to ship first week of October. Will keep you posted.
Offline Xere
« Reply #53 on: September 24, 2023, 01:54 PM »
 Thanks for your post, I just purchased a Bow accessories to complete my new setup. I took the one with 2 Knob, this is fitting perfectly with CSC SYS... I love this saw.
[embarassed]
My setup.
Offline JimH2
« Reply #54 on: September 24, 2023, 05:16 PM »
Does the Bow Featherboard fit right out of the box? I did not measure but the miter bar looks to have a non-standard width.
« Reply #55 on: September 25, 2023, 10:56 AM »
I can’t speak for the two-knob ordinary-sized featherboard.
However, the portable saw version featherboard — model fp5; single knob — fits great in the clamping t-slot, right out of the box.
Offline Xere
« Reply #56 on: September 25, 2023, 12:09 PM »
Yes it does
Offline Xere
« Reply #57 on: September 25, 2023, 03:29 PM »
Does anyone have the same issue with non alignement between sliding table and saw table ?
I have 0.3° difference. Should I consider as normal? Any adjustment?
IMG-2551-1" border="0
IMG-2553-1" border="0
IMG-2555-1" border="0
IMG-2556-1" border="0
IMG-2557-1" border="0
« Reply #58 on: September 25, 2023, 04:08 PM »
Yes, mine’s the same. (Or rather it’s ~0.35 or ~0.25 (can’t remember) and ~0.3 is the nearest 1/10th)
No, I don’t think it should be like this.
Since I noticed, I’m setting the saw angle accordingly, depending on whether I’m using the fence or the table.
Offline Xere
« Reply #59 on: September 25, 2023, 04:37 PM »
I checked all manuals and tried to adjust with the eccentric screws but nothing. I guess the only way would be to add a wedge under the aluminium rail but sounds not easy..
Offline pixelated
« Reply #60 on: September 25, 2023, 05:06 PM »
I suppose I should go check mine.
But it might be best to send it in on warranty.
Offline Xere
« Reply #61 on: September 25, 2023, 05:17 PM »
Let us know the result.
