Author Topic: Festool Angle Grinder  (Read 4913 times)
Offline Birdhunter
« on: July 18, 2019, 03:52 PM »
I am intrigued by the new Festool angle grinder, but, other than steel work, how would one use the tool?
Birdhunter
Offline ear3
Re: Festool Angle Grinder
« Reply #1 on: July 18, 2019, 04:06 PM »
If you don't have a RAS, presumably it can be used for wood sculpting with a Kutzall disc or something similar.  I assume there's an attachment for it to mount sandpaper as well, like there is for other angle grinders?
Offline mrB
« Reply #2 on: July 18, 2019, 04:06 PM »
Variable speed and dusty protection mean it'll make a good cordless Sander for certain tasks :)
Offline threesixright
« Reply #3 on: July 18, 2019, 04:34 PM »
Cut stone ;-)
Sent from my X using Tapatalk
« Reply #4 on: July 18, 2019, 05:10 PM »
Surface concrete so it’s smooth if you want to cap it with stone.
I use my Milwaukee 18 volt with a .040” thick cut-off wheel to cut bolts and screws to unusual lengths.
Offline Birdhunter
« Reply #5 on: July 18, 2019, 06:25 PM »
I use a Dremel tool to trim bolts to length.
Birdhunter
Offline ear3
« Reply #6 on: July 18, 2019, 07:44 PM »
Curious @Cheese why you use the thicker cut off wheel for this? Does this give better control?
« Reply #7 on: July 18, 2019, 07:47 PM »
Maybe you misread? I don’t know of a thinner wheel other than some small diameter disks for Dremel.
« Reply #8 on: July 18, 2019, 07:49 PM »
Wonder if Festool is going to allow Bluetooth vac/start with this potential spark throwing tool?
Offline PaulMarcel
    • Voilà, my blog
« Reply #9 on: July 18, 2019, 08:02 PM »
Would need the spark trap for the vac; I don't think they make it anymore :/ could be wrong
Offline Peter Halle
« Reply #10 on: July 18, 2019, 08:11 PM »
The old spark trap was discontinued.
No info on a possible replacement.
Offline ear3
« Reply #11 on: July 18, 2019, 08:20 PM »
The one I normally use is 1/16
quote author=Michael Kellough link=topic=60148.msg584553#msg584553 date=1563493675]
[/quote]
Offline ear3
« Reply #12 on: July 18, 2019, 08:22 PM »
Oops, math foul. .04 <1/16
[/quote]
« Reply #13 on: July 18, 2019, 10:19 PM »
Ya, years in the past, the thinnest cutoff wheel available was .125”, then the standard became .080”, then .060” and finally .040”. If there was a thinner option available... I’d be the first adopter.
The .040” thick wheel on a 4”-5” grinder will cut through a 5/16” diameter stainless bolt within 4-5 seconds.
It just doesn’t get much better than that from a convenience stand point. Hit it with a burr trimmer and you’re good to go.
« Last Edit: July 18, 2019, 10:31 PM by Cheese »
Offline neilc
« Reply #14 on: July 18, 2019, 10:37 PM »
I use my right angle grinders with a wire brush, flap and hard sanding discs and with a cutoff disc.  I have a Makita cordless as well as a Dewalt Cordless - both 4 1/2" with 5/8" arbors.  One on my farm in Arkansas, one in Chicago - based on local battery / accessory availability in each location.
They are great tools.  I'm amazed at how much I use them.
 - awesome for metal work - knocking down welds quickly, truing up cut edges, chamfering edges before welding, cutting bolts, nails, sheet, angle iron, tubing, conduit, etc.
 - rust removal / scale removal / paint removal on steel
 - sharpening lawnmower blades, axes, etc
 - very fast wood removal with a 36 or 40 grit flap sander
Neither the Dewalt nor the Makita have a dust collection port.  I'm excited to see the Festool does.  And neither of them are variable speed like the FT.
As a caution, DO NOT use one of these without a guard in place.  AND the side handle.  They WILL grab the work and kick back and could do serious damage to an arm, stomach, or leg with an exposed wheel, brush, or sander.  Unlike an orbital these bite and don't give!  Think ROTEX Mode full on!  Ideally wear a leather apron as well.  With metal they generate a lot of sparks.  Eye protection a must.
They are messy, but amazing tools for rapid stock removal.
Offline TinyShop
« Reply #15 on: July 19, 2019, 01:45 AM »
Maybe I'm missing something but where exactly is there any mention of this tool having a dust port?
ETS 150/5 EQ (DE) [po], TS 75 EQ (DE) [po], OF 1400 EQ-F (DE) [n], CXS (DE) [n], CMS-GE [DE] [po], CMS TS 75 (DE) [n], LA-CS 50/CMS (DE) [po], VB-CMS (DE) [n], MFT/3 (CZ) [n], DF 700 EQ w/Seneca Small Mortise Kit (DE) [po], FEIN Multimaster 350 QSL (DE) [n], Bosch 1274DVS w/dust collection, sanding frame,  stand & fence (CH) [n], BOSCH 1590EVS w/dust collection (CH) [n], CS Unitec CS 1445 HEPA extractor <re-branded Starmix ISP 1435 H> (DE) [n], CT SYS (DE) [po], Milwaukee 0302-20 (US) [n], Two (2) Porter Cable 862 (TW) [n], Porter Cable 447 (US) [n], Zyliss Vise (CH) [nos], Hitachi C 8FB (JP) [h], Walko 4 MKII (NL) [nos], Festool MFS 400 w/add-on 700 profiles & router slide (DE) [n], Festool RAS 115 (DE) [n]
[po] pre-owned   [n] new   [nos] new old stock   [h] heirloom   (XX) country of origin
« Reply #16 on: July 19, 2019, 01:57 AM »
Ya Neil brings up another great use...put a wire brush on for rust removal and a Pferd poly disc on for lawn mower blade and SHOVEL sharpening.
Offline Phil Beckley
« Reply #17 on: July 19, 2019, 02:12 AM »
Hi
Two 18v machines are due for release in Europe - Diamond grinder with dust port DSC AGC 125 18v. Applications such as cutting concrete , roof tiles etc
.....and AGC 125 18v standard style grinder - Applications such as re-bar, threaded rod, galvanised profiles......list is endless
Rg
Phil
Offline ggc
« Reply #18 on: July 19, 2019, 04:37 AM »
Will there be a dust port similar to the old DSG-AG 125 (making it suitable for sanding), or is the dust port for concrete cutting style of operation.
Could be a viable replacement for the RAS line of products.
« Reply #19 on: July 19, 2019, 07:19 AM »
@Cheese  said, “Hit it with a burr trimmer and you’re good to go.”
Is a burr trimmer a thing?
« Reply #20 on: July 19, 2019, 11:14 AM »
« Last Edit: July 20, 2019, 08:48 AM by Cheese »
Offline Birdhunter
« Reply #21 on: July 21, 2019, 01:38 AM »
As the OP, I fail to see any need for this tool in a Woodworking shop.
Birdhunter
Offline Jiggy Joiner
« Reply #22 on: July 21, 2019, 03:56 AM »
There probably isn't much use for it in many woodworking situations depending on what's being made. A very versatile tool in other applications though.
I think @Cheese was suggesting other uses for the machine, if they can take different type discs/blades etc? Obviously the working RPM has to be considered.
It looks a handy tool though, we have a couple of 18 v brush less Makita 125mm grinders, and like the other poster mentioned, they have a multitude of uses. I get what @Cheese is suggesting, just last week we had to cut down 200 M10 bolts, and chose a thin cutting disc and a Burr trimmer and a vice to do the job. No problem  [thumbs up]
As somebody also said, no dust port on the Makita but, we recently bought a couple of Makita dust shrouds complete with dust ports.
I think they were £60 each, and they have transformed the little grinders. I'm amazed at how well the dust is collected. We chase walls, cut through render with them, tiles, just about everything. Like a lot of tools of this design, the closer the tool is to the work surface, the better the dust extraction.
As much as I'm happy with what we've got, I will look at the Festool version with interest, as it looks a lot less bulky than counterparts.
Offline rvieceli
« Reply #23 on: July 21, 2019, 07:50 AM »
@Birdhunter quite a few folks out there carve wood as part of their process. Put one of the many power carving wheels on an angle grinder and you have an excellent tool. Cordless is a big bonus. Rather than turn bowls on a lathe there are those that use the carving wheels to hollow out irregular shaped bowls.
Here are a couple of great examples of these applications. They may not be your cup of tea but they are outstanding craftsmen.
http://www.nugeandwood.com/
https://cbmdesigngroup.com/
Ron
Ron
Offline Birdhunter
« Reply #24 on: July 21, 2019, 09:11 AM »
I guess my vision of woodworking was way too narrow. Thanks for the comment.
Birdhunter
Offline rvieceli
« Reply #25 on: July 21, 2019, 09:27 AM »
in an application that a bit closer to regular woodworking, many people use a cutting wheel on an angle grinder to rough out those fancy sculpted seat bottoms for chairs and benches.
Ron
« Reply #26 on: July 21, 2019, 10:50 AM »
If you want to stay strictly within the woodworking vernacular, you can put different wire wheels on the grinder and distress wood for that "old used for years" look.  [smile]
« Last Edit: July 21, 2019, 11:03 AM by Cheese »
Offline ach_78
« Reply #27 on: October 20, 2020, 09:03 AM »
I was wondering if anyone has an issue of « excessive » battery usage on the Festool angle grinder ?
I know it’s a powerful tool but on brand new 5.2Ah batteries the time it gets for me to sharpen an axe (Max power), half of the charge is gone. Interestingly the tool goes not get really hot. So basically one charge only provides enough for really quick jobs (no more than maybe 10 mins)
Is this typical of this grinder or is something wrong with mine ?
Offline aloysius
« Reply #28 on: October 20, 2020, 06:58 PM »
Angle grinders are extremely useful & versatile tools.  I use mine for sharpening, sanding, carving, flooring, derusting, paint stripping, stonework, masonry, polishing, cutting & on occasion, actual grinding.
Battery grinders are useful for small jobs, but tend to be a bit gutless & have only limited charge life.  Given that Festool's battery system is now almost 10 years behind most professional competitors in terms of technology & capacity, it's not really a viable option for many (most?) tasks.
The best battery grinders these days are from the Bosch range, with excellent power, versatility & runtimes.  Grinders from the Cordless Alliance vendors are probably the second best alternative these days, having additional power available & close to double the charge runtime of the Protool/Festool together with the obvious benefits of a universal battery system with capacities varying between 2.0-10.0 AH and high-current capacities.
Corded grinders are nevertheless my preferred option, having increased stamina & unlimited runtime.  Metabo's range is currently the "state of the art", with a choice of well over 100 tools available for just about every single conceivable task to which one would apply such a tool.  My preferred model is the WEV 17-125 Quick Inox, which has an extra slow speed for sanding/polishing a reasonable top speed (especially when fitted with 6"/150mm wheels & guard) for more "normal" grinding duties, plus rather extraordinary reserves of power & torque for truly heavy duty tasks.
FOG-wit since '95:  Some say since birth...
Offline mkasdin
« Reply #29 on: October 24, 2020, 01:24 AM »
I have a Bosch angle grinder. Bosch makes a shroud attachment for dust collection. I’ve used the grinder for trimming granite, and level concrete, very good for the edges and corners  the Bosch has a variable speed. They make two models one with an on/off switch and another with a paddle switch.  Hooks straight onto a Festool dust extractor.
