Author Topic: Festool 482107 Guide Rail Connector, distance between the screws?  (Read 779 times)
Offline threesixright
Anybody that has these connectors, could measure the distance between the screws (center to center), as on the picture?
Total length would be also great.
Much obliged!
Roger
Offline GarryMartin
Re: Festool 482107 Guide Rail Connector, distance between the screws?
« Reply #1 on: February 27, 2019, 06:49 AM »
Length between the centres you've marked in red is 80mm. Between the two centre fixings is 96mm. Overall length is 315mm.
« Reply #2 on: February 27, 2019, 07:29 AM »
Sir, you're awesome. Thanks!
Offline ben_r_
« Reply #3 on: February 28, 2019, 05:29 PM »
Whatcha up to? Why were you lookin for that info?
« Reply #4 on: March 01, 2019, 04:44 AM »
Hehe, first to ask [wink]. Curiosity killed the cat!  [tongue]
J/K as side.
Was looking to create a poor men's  square.  Basically taking the rail connectors (#482107) and put a t-slot profile (400mm) perpendicular to the rail . Now the slots needs to be, according to the measurements 80mm apart. Basically needed the info to check if I could find a t-slot rail where the slots are 80 mm apart.
