Author Topic: Festool 36mm(straight) braided hose  (Read 4735 times)
Re: Festool 36mm(straight) braided hose
« Reply #30 on: May 11, 2021, 01:42 PM »
I'm going to attach this previous thread because there was some discussion about the new 36 mm hose and the new Festool/Wessel turbo floor tool.
https://www.festoolownersgroup.com/festool-tools-accessories/what-festool-did-you-buy-today/msg639850/#msg639850
Offline FestitaMakool
« Reply #31 on: May 11, 2021, 05:28 PM »
Rick Herrick;
- I have a completely different experience with the plastic wands.. they stick well together, and are by far the best quality and most rigid wands I’ve ever used.
I do actually prefer the plastic ones as they don’t mar things and are super light.
Though, I’d like a one-piece rigid plastic wand to go with the 3 piece set which can be put away for more mobile use.
I’m on the lookout for a compatible telescopic metal (preferably aluminium) wand that will stay in the shop.
Festool has a full length wand in metal for the 50mm hose; tempting..
Offline Coen
« Reply #32 on: May 11, 2021, 05:43 PM »
Does the 50mm one-lenght one have a bleeder valve? I was tempted by it too because of rigidity.
I think the telescopic part won't work that well with the kind of dust the CTL's are used for...
Offline Rick Herrick
« Reply #33 on: May 11, 2021, 06:34 PM »
Rick Herrick;
Thats interesting.  When I am on concrete, it did ok but I have a few small rugs in the garage to clean feet before going in the house and when I used it there, it took lots of patience to not have to start to bend and separate.  I did not know about a 1 piece wand.  I think I would really like that better anyway.  I will check that out.  Thanks @FestitaMakool
« Reply #34 on: May 11, 2021, 07:16 PM »
Your welcome, Rick. It may have to do with very fine concrete dust getting in between, have you tried cleaning inside/outside where the ends meet? I do very rarely do concrete dust, so..
I have to pull hard to separate the tubes.
And no, I don’t think the 50mm wand has a bleed valve, but I have not seen it in person.
So far I have seen some wands that has 34mm outside diameter from other manufacturers of telescopic or full length wands. I suspect Nilfisk does the same - I actually have two floor nozzles on the way that is Festool compatible (one is identical to the 300mm parquet nozzle but for Nilfisk)
Offline Chainring
« Reply #35 on: May 11, 2021, 08:12 PM »
Does anyone have a part number for the Workshop kit referenced in post # 23? I looked all around on Festool US and didn't find it. I did find the metal vac head though.
« Reply #36 on: May 11, 2021, 08:22 PM »
I am hoping its this one.
Festool Workshop Cleaning Set with Sleeved Hose (576838)
Offline Coen
« Reply #37 on: May 12, 2021, 12:22 PM »
In some photo's there is some black ring around it;
« Reply #38 on: May 12, 2021, 12:26 PM »
@FestitaMakool Do you have a number for this wand?  I could not find it.  I wonder if its one of those NAINA..
« Reply #39 on: May 12, 2021, 12:32 PM »
Festool part number 447599...$150
« Last Edit: May 12, 2021, 01:21 PM by Cheese »
Offline Coen
« Reply #40 on: May 12, 2021, 01:01 PM »
I see <100 € including shipping.
Yes, it's an expensive piece of pipe....
« Reply #41 on: May 12, 2021, 01:11 PM »
But that is pieces/sections.  I was looking for a 1-piece wand.  Maybe I misunderstood.  I don't need it break down and fit into a systainer.  I should check the local vacuum store, maybe I could get lucky there.
Offline Coen
« Reply #42 on: May 12, 2021, 01:53 PM »
Huh no. 447599 is one piece. According to the catalog... 1100mm long.
« Reply #43 on: May 12, 2021, 01:57 PM »
Cheese and Coen to the rescue..
Yes, it’s expensive, local to USD is $172.
It is made of aluminium, anodised.
« Reply #44 on: May 12, 2021, 02:20 PM »
I guess this picture is misleading a bit.  It does say 1100mm but that picture doesn't really look like that.
Offline Coen
« Reply #45 on: May 12, 2021, 02:24 PM »
Yeah that pic seems to be #440412
« Reply #46 on: May 12, 2021, 02:34 PM »
Those are in plastic and are 970mm combined.
Offline Coen
« Reply #47 on: May 12, 2021, 02:42 PM »
Yeah, and there is no plastic curved part in D50 to go with those.
For household use I have a 3-part telescopic Miele tube. Really nice. 1157 fully extended, just the telescopic tube. 568mm at the shortest. Compared to the 2-part one... at full length 13 cm longer... at shortest 4 cm shorter.
But they don't longer sell it... so hoping it will last...
When they bring in the news that 'long people get higher pay'.... that is all lost on things like longer vacuum cleaner tubes, longer mattress, bigger bicycle...
« Last Edit: May 12, 2021, 02:54 PM by Coen »
« Reply #49 on: May 12, 2021, 04:14 PM »
Exactly, and it’s why I too want one of those longer telescopic wands.. Once experienced that there is actually long enough wands that allows me to stand upright there’s an instant relief  [smile]
I too forgot to mention not seeing a curved 50mm part, not even in the 50mm hose and attachments set. I find it oddly, as I purchased a CT 26 lightly used a while back, with a lot of accessories in the hose and attachment department - and in this systainer where all the loose  parts were I found a curved 50mm plastic piece. There’s no stamp or print on it, but it fits perfect to Festool’s 50mm inside and outside (depending on which way you use it) I am pretty sure it’s a Festool item, but later I have never found one.
Offline Coen
« Reply #50 on: May 13, 2021, 10:11 AM »
Maybe dig through ekat?
I can't remeber a curved 50mm part and I've a pretty good knowledge of the Festool catalog since about 2003
Although I recently put most of the paper catalogs in de paper bin  [sad]
Offline guybo
« Reply #51 on: May 13, 2021, 11:06 AM »
Hi, bought this in 2009,all accessories for 27,36 and 50 listed.guy
« Reply #52 on: May 13, 2021, 06:47 PM »
Guys, I was wrong - I did find a part no’ - It’s a Bosch part:
Beware: It is the narrow end that fits inside the vac side of the hose - as I do only have a couple of 50mm hoses, I haven’t had the opportunity to try it on the wands. That said, there’s a chance it won’t fit the wand (without heating or sanding)
It has the same appearance as Festool’s and Nilfisk..
« Last Edit: May 13, 2021, 06:50 PM by FestitaMakool »
Offline SRSemenza
« Reply #53 on: May 15, 2021, 09:55 AM »
This  CRAFTSMAN CMXZVBE38639 (or clone) bent tube fits the D50 hose end.  On my D50 hose it is a bit loose, but a couple wraps of electrical tape around the D50 connector (to fatin' it up) should do the trick. Mine is plenty tight with one wrap. Not AS. It does have a suction reducer.
Pull the tape tight. Keep it back from the end so that it doesn't catch. Trim off any wrinkled ends.
« Last Edit: May 15, 2021, 11:44 AM by SRSemenza »
Offline rst
« Reply #54 on: May 15, 2021, 10:00 AM »
I use Rocklers bent attachment with a handle and old CraCraftsman tubes with my Fein and Festool 58mm hoses
Offline jarbroen
« Reply #55 on: May 18, 2021, 11:40 AM »
Didn’t see your question earlier.  The part number I ordered for that kit is 576838.
