Author Topic: Festool 2200 won't start up  (Read 668 times)
Offline Drew5
« on: April 05, 2021, 11:35 AM »
I have a unused 2200 and it will not start up.  Tried different outlets.  Not plugged into vacuum.  Tried different speeds.
Offline RustE
« Reply #1 on: April 05, 2021, 11:58 AM »
Does the arbor turn by hand?
Do you have another power cord to try?
Offline Drew5
« Reply #2 on: April 05, 2021, 12:03 PM »
Arbor turns by hand and the 2200 does not have a removable cord like the 1400 and some of the other Festool tools.
« Reply #3 on: April 05, 2021, 12:19 PM »
Are you sure the house breaker has not tripped?
Offline Drew5
« Reply #4 on: April 05, 2021, 12:23 PM »
Positive.  I plugged into two different outlets on two different breaker boxes.  And checked afterwards with another tool in outlet.
Offline RustE
Re: Festool 2200 won't start up
« Reply #5 on: April 05, 2021, 12:38 PM »
How does the power switch feel?
Offline Drew5
« Reply #6 on: April 05, 2021, 12:48 PM »
I had a feeling that this problem was strictly operator error.  It was and on the highest dumb a** rating.  Oh my.  I did not press the power button hard enough.  Thanks folks.  Glad I do not have my full name on this.
Offline RustE
« Reply #7 on: April 05, 2021, 01:07 PM »
Glad that’s all it was.
My thoughts were going towards the router being a display model and the switch got damaged from people clicking it all the time.
Offline PreferrablyWood
« Reply #8 on: April 06, 2021, 01:59 AM »
The OF 2200 is a beast, be cautious with it with larger bits.
Easy enough to make a mistake with an unfamiliar tool. I had problems with the plunge lock not working after sitting in the CMS router table, somehow the problem went away with out me being able see what caused the problem and why it started working again.
TS 55 R EBQ, Vecturo OSC, BHC SDS, RO 150, 850 HL E Planer, MFS 400x2, MFS extensions MFS VB 700 x 1 MFS VB 1000 x 2 . CMS GE, OF 2200, CMS OF+ CMS TS 75 insert modules. SYS-MFT Fixing-Set,
Festool 18V HKC 55, TI 15, CXS 2.6 Ah version, RO 90 DX, PDC 18/4 plus   TS 75 EBQ, PSC 420, OF 1010, RS 300 EQ, CTL Midi, MFT 3
