Author Topic: TS 75 Imperial depth gauge?  (Read 6080 times)
Offline wfeffer
« on: June 25, 2014, 11:15 PM »
I just purchased a TS 75 and while flipping through the manual out falls a 2" marked sticker.  It looks at first like it would be the imperial depth gauge, except the TS 75 does 3.75" and the sticker doesn't even begin to fit  in the depth gauge area.  Can anyone tell me what this is for?
As you can see in the picture it's nearly half an inch too short, marked upside down, not curved and FAR too wide to be the depth gauge.
« Last Edit: June 26, 2014, 09:39 AM by wfeffer »
Offline wow
  • Inactive Member
Re: TS 75 Imperial depth gauge?
« Reply #1 on: June 25, 2014, 11:44 PM »
Can you post a picture?
Offline copcarcollector
« Reply #2 on: June 25, 2014, 11:54 PM »
My guess is its the depth gauge sticker now included with the TS55.
Offline wfeffer
« Reply #3 on: June 26, 2014, 09:39 AM »
I added a picture to the original post.
Offline wow
  • Inactive Member
« Reply #4 on: June 26, 2014, 10:27 AM »
That's not for the TS75.
Looks like it's for the TS55 as copcarcollector said. Here's a picture of being applied to a TS55:
108706-0
Offline jobsworth
  • Festool Baby.....
« Reply #5 on: June 26, 2014, 11:28 AM »
Im gonna have to check my owners manual  [thumbs up]
Offline wfeffer
« Reply #6 on: June 26, 2014, 03:00 PM »
So basically somebody at the factory put the sticker in the wrong box huh?
Offline Paul G
« Reply #7 on: June 26, 2014, 08:20 PM »
Yup. Wish there was one for the 75 though
+1
Offline Wooden Skye
« Reply #8 on: June 26, 2014, 08:32 PM »
Awhile back, a forum member made imperial depth scales for the TS 55 and the OF1400, which are great.  Maybe he did one for the TS 75, or could make.
Bryan
TS 55, (2) 1400 Guide Rails, 1900 Guide Rail, MFT/3, Domino ETS 150/3, RO 90, CT 26, OF1400, RO 150. RTS 400, LR 32 set, PS300 jigsaw, 3 abrasive systainers, (2) sys toolbox, (2) sys mini, clamps and other accesories
Offline rrmccabe
« Reply #9 on: June 27, 2014, 08:36 AM »
I have not been successful at making one for the TS75 yet and not looking likely.
But have sold many TS55 labels :)
Replacement Imperial labels.  www.iowawebhosting.com/festool
Offline wfeffer
« Reply #10 on: June 27, 2014, 09:50 AM »
I wonder why they didn't make one for the TS 75... oh well. Anybody want this for their TS 55?  PM me your address and I'll drop it in the mail.
Offline wow
  • Inactive Member
« Reply #11 on: June 27, 2014, 11:36 AM »
I emailed rrmccabe about this, and he told me that because the TS75 scale is not linear (the TS55 is) he could not print it and have it look good. I was kinda bummed and am still looking for a solution as well.
Online Samo
« Reply #12 on: June 27, 2014, 02:19 PM »
This is the one you want.
108830-0
108832-1
Not sure if the member is still active?  I never installed mine as I just use a couple of tic marks on my 75.
It's The FOG!  Just rotate the screen.
Offline MDUDLEY
« Reply #13 on: June 22, 2021, 04:01 PM »
This might not be the correct location for this post, but..... I purchased a used TS75 (Imperial) and have noticed that the depth setting is not correct.  For example, when cutting 3/4" MDF I must set it to 7/8" to just get through the MDF.  I was cutting Deck boards at 1 and 1/8" thick and I had to set it to 1 and 3/8" to get through the cut.  The TS75 did not have the owners manual with it, but I assume I am simply missing an adjustment on the saw itself, right?  Does any one know how I can adjust this.  Thanks for the assistance in advance.
Offline Peter_C
« Reply #14 on: June 22, 2021, 04:36 PM »
Is it possible the saw blade is not 210mm? There are also two sides to the pointer. One side is for when on the rail and other side for when it is off the rail. Check to see if it starts at zero while on the rail on a solid surface like your work bench.
Offline woodbutcherbower
« Reply #15 on: June 22, 2021, 08:10 PM »
[quote I was kinda bummed and am still looking for a solution as well.
[/quote]
Maybe broaden your horizons and change to metric? Just like the rest of the world?
There's no such thing as a job which is almost perfect. It either is perfect - or it isn't.
