Author Topic: Festool Rotex 150  (Read 548 times)
Offline furd
Festool Rotex 150
« on: November 05, 2019, 01:59 PM »
Hi Festool experts,
I saw an ads for a used Festool Rotex 150 that the seller bought it in 2016.  I assume that the sander is the older model (the new model was released in 2018).  This old model will have different sanding pad (less holes on the pad).  Does the new pad that comes with the 2018 model work with this old sander?
thanks.
Offline mschmidt10k
Re: Festool Rotex 150
« Reply #1 on: November 05, 2019, 02:18 PM »
Yes, the multi-jetstream 2 pads are a direct replacement for the older pads.
Offline tewic
« Reply #2 on: November 05, 2019, 03:15 PM »
Yes - I recently bought a Rotex 150 with the older pad, and replaced it with a new multi-jetstream 2 pad. Works like a charm.
Offline Jim_in_PA
« Reply #3 on: November 06, 2019, 10:52 AM »
Not only will the current pad work on the Rotex 150 (and the 150/3 or 150/5 of the same time period) but they also add the benefits of the improved dust extraction flow...so it's an upgrade! :)
ETS 150/3, Rotex 150, OF1010, OF1400, Trion PS 300, TDK-12, CT-22, MFT 1080, TS55, Domino XL DF 700, 8' track, (2) 55" tracks
SCM MiniMax S315WS, FS350, MM16, Camaster Stinger II SR-44 CNC
