Author Topic: Dust bag for Carvex?  (Read 934 times)
Offline bidn
  • hobbyist
« on: August 05, 2022, 04:01 PM »
Hello,
Would anyone know about a (commercially available) dust bag which would fit on the dust exhaust pipe of the Carvex?
Thank you in advance
BS 75 set, HKC 55 Li EB+ SCA, TS 75 EBQ+, TSC 55 K, Erika 85 Ec + options, KS 120 EB, OF 1400 EBQ+, OF 1010 EBQ+,  Carvex  PSC 420+, ZH-SYS-PS-420, P1 cc, RO 90 DX FEQ+, RO 150 FEQ+, 2 x Deros 5650cv, Deos Delta 663CV, CTL 22 E SG, CTL 26 E, PDC 18/4 set XL, Ti 18+3, C15 Li 4,2 Set, Sys 1 CE-Sort, many Milwaukee and a few Metabo 18V.
Offline Crazyraceguy
Re: Dust bag for Carvex?
« Reply #1 on: August 05, 2022, 07:01 PM »
I doubt that anyone would bother. There is nothing to make the dust go into it?
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT26E + Workshop cleaning set
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
Shaper Origin/Workstation
MFT clamps set
Offline bidn
  • hobbyist
« Reply #2 on: August 06, 2022, 02:54 AM »
I need very fine dust (to mix up with glue and fill in place where I can't use coarser saw dust in the mixture).
 I have blades with very thin teeth (S75 / 1,4K) creating very fine dust which I would like to collect with a dust bag.
« Last Edit: August 06, 2022, 02:59 AM by bidn »
Offline Bob D.
    • My Cordless Workshop
« Reply #3 on: August 06, 2022, 06:07 AM »
A sander with dust bag and whatever grit paper you need sounds easier to me.
Offline ear3
« Reply #4 on: August 06, 2022, 07:05 AM »
I suppose you could try using a rubber band and some diy bag attached to the dustport.  But the sander would definitely be more efficient at producing the finest dust.  Even absent a dust bag, you could grab the one of your rotexes (rotices?), a bucket or a large pot, and generate more than enough sawdust in a few minutes.
Kapex KS 120 w/UG Cart and Extensions • CXS Set • T 18+3 w/Centrotec Installer's Set • PDC 18/4 • TID 18 • TS 75 • TSC 55 • HKC 55 w/250, 420 and 670 FSK rails • Carvex 420 w/Accessory Kit • Domino 500 Set • Domino 700 XL • OF 2200 w/Base Accessory Kit • OF 1400 • OF 1010 • MFK 700 EQ Set • LR 32 • MFS 400 w/2000, 1000, and 700 extensions • Rotex 90 • Rotex 150 • LS 130 • ETS-EC 150/5 • ETS-EC 150/3 • Pro 5 LTD • RTS 400 • RAS 115.04 • RS 2 • Planex Easy • HL 850 • Vecturo OS 400 • AGC 18-115 • CT 36AC w/BT module • CT Sys w/Long-Life Bag • CT-VA 20 • MFT/3 • STM 1800
Online Cheese
« Reply #5 on: August 06, 2022, 09:05 AM »
If you go the sander route (which is probably your best bet) don't use the ETS EC sanders as they do not have internal impellers just like the Carvex.
Offline c_dwyer
« Reply #6 on: August 06, 2022, 05:06 PM »
@bidn  - If you still want to go the Carvex route vs. sanding, just put a large container under whatever your carvex'ing. Even with a vac hose attached, most of the sawdust that gets created when I use mine ends up on the floor. Quite a bit of it, I might add...
« Reply #7 on: August 06, 2022, 05:59 PM »
I get pretty good dust collection with mine. You do have to move rather slowly, or even "pulse" by slowing/stopping to allow the suction to keep up, but it does work.
CSX
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
MFT clamps set
Offline Coen
« Reply #8 on: August 07, 2022, 06:06 AM »
Some sanders have a turbine inside to blow the dust into the bag. Some tools like the TS create most of their dust with speed and direction. The Carvex does neither. The bag will collect nothing, except some dust on the outside.
Offline bidn
  • hobbyist
« Reply #9 on: August 08, 2022, 09:17 AM »
Thank you for your answers.
I am not at my normal place, but at a location where I don't have my Rotex, and have to work outdoor, pieces being held by SuperJaws xxl (so container below is not easy, with a little breeze carrying away the fine dust).
In the end I managed to create the fine dust by carving with the Festool Vecturo multitool (I understand it to be actually made by the Fein company).
