Author Topic: Domino Joiner and Obtuse Angles  (Read 694 times)
Offline WoodenGoblet
« on: March 13, 2019, 10:54 PM »
I want to join to pieces of 1 1/4" x 3 1/4" lumber that are cut at 50 degrees using my domino joiner. Do I set the angle of the joiner at 40 degrees or 50 degrees to join the two pieces?
Offline ChuckM
Re: Domino Joiner and Obtuse Angles
« Reply #1 on: March 14, 2019, 12:05 AM »
Could you show the pieces/angle in a sketch? It can be neither depending on how they are joined.
Offline Birdhunter
« Reply #2 on: March 14, 2019, 08:49 AM »
I am assuming both boards are 1 1/4" thick and 3 1/4" wide.
The way I am picturing this, I would lay the boards flat and set the fence at 90 degrees and cut one mortise parallel to the 3 1/4" side on both boards. Since the boards are over 1" thick, you could use a fairly thick tenon. You would have to be careful that the mortise does not blow out the back of the board and is centered in the middle of the boards.
Birdhunter
