Like mentioned above the Festool FS-WA/90° 205229 is the same as a GRS-16 PE Parallel Edge Guide Rail Square 61-230-R A, it even says TSO on the metal clip.
I was in the same boat and end up ordering from TSO for my Festool rails:
- TPG-30-50 Set: Includes Two 30" T-Tracks + Two 50" T-Tracks (its good to have both lengths for mobility on very small to full sheet cuts so it doesn't feel clumsy)
- TPG Adapter (Drop-On) for TPG Parallel Guide System 61-388 (fits Festool rails only, it effortless clicks in and out so its easy to move away and stand aside the guide rail from a sheet after a cut)
- Angle Accessory 61-246 A (nice if you want to cut rounded edge sheets)
I also had the Festool FS-WA 577040, and FS-WA-VL 577041, these are not compatible with the TSO products. I ended up selling these again because I couldn't get exact straight cuts from it, not sure why. The TSO is more straight forward, very precise and ease of use.
