Author Topic: Cut beams lengthwise, with a15 degree angle & TS55 (safely)?  (Read 2018 times)
Offline threesixright
Beams are 45 * 70 * 2500 mm, angle is on the short side.
Any ideas how to cut this safely? Getting a strong feeling the best way is a table saw (which I don't have) and so I will not.
Unless there is a safe way of doing this? Maybe with the CARVEX (was looking for a parallel guide, but no dice)?
Thanks!
Offline Bob D.
Re: Cut beams lengthwise, with a15 degree angle & TS55 (safely)?
« Reply #1 on: April 08, 2019, 04:17 AM »
Place two or more beams of the same thickness side-by-side to form a wider, more stable base for the track to rest on. If necessary join them together on the ends to remove the chance they may separate or move during the cut.
« Reply #2 on: April 08, 2019, 04:22 AM »
Thats a good plan! Thanks.
Could have thought of that myself  [embarassed]
Offline Bohdan
« Reply #3 on: April 08, 2019, 04:25 AM »
Use a ripping (panther) blade or the motor will keep shutting off to cool down.
Offline Sanderxpander
« Reply #4 on: April 08, 2019, 07:02 AM »
Will the TS55 even cut deep enough on the rail with a 15 degree angle?
Online Bert Vanderveen
« Reply #5 on: April 08, 2019, 07:27 AM »
Cutting thru in one go is going to be hard and prob. painful. Do shallow cut first (just short of halfway thru) and finish with cutting all the way. That way you will be able to see where you need to wedge etc.
Cheers, Bert Vanderveen
TS55 · TS55R · OF1010 · DF500 Mk2 · MFT/3 + TSB1-MW 1000 + VL + CMS TS55 + CMS PS300 + LA-CS 70/CMS · CTL Midi · RTS400 EQ · 2 x CXS Li 1,5 · T15+3 Li 4,2 · TI15 Impact Li 4,2 · Centrotec Sets 2008 + 2015 · PSB300 · LR32-SYS · RO150 · Kapex KS120 · 2 x MFK700 · RO90 · OFK700 · BS75 · OFK500 · OF2200 · CMS-GE · Vecturo 18 Li · TID 18 · TKS 80 EBS-Set · … | Mirka 1230L P&C | Hammer A3 31 Silent Power · Hammer N4400 · Hammer HS950 | TaigaTools VacPods Pro Set
Wishlist: ETS EC 125 w 150 pad, DTS
Offline Svar
« Reply #6 on: April 08, 2019, 01:42 PM »
Yes, it will. With TS55 you can cut up to 48 mm thick at 15 degree.
« Last Edit: April 08, 2019, 01:45 PM by Svar »
Offline Svar
« Reply #7 on: April 08, 2019, 01:45 PM »
If they are smooth and straight you can use double sided tape to join them to each other or to the cutting table/surface.
Offline Untidy Shop
« Reply #8 on: April 08, 2019, 01:58 PM »
And use the Panther blade which is for ripping.
https://www.festoolusa.com/accessory/500463---160x1,8x20-pw12-usa
« Last Edit: April 08, 2019, 02:00 PM by Untidy Shop »
« Reply #9 on: April 08, 2019, 03:00 PM »
Not on the rail I think. But I suppose this is better done with a parallel guide anyway.
Offline Svar
« Reply #10 on: April 08, 2019, 03:18 PM »
On the rail. Off the rail it'll cut 53 mm at 15 degree.
Good point about parallel guide if you wand a consistent width. A narrow 2.5 m long beam is unlikely to be as straight as the rail.
Offline jobsworth
  • Festool Baby.....
« Reply #11 on: April 08, 2019, 05:06 PM »
+1 for the panther blade
Offline harry_
« Reply #12 on: April 08, 2019, 05:15 PM »
It will be when he's done! :P
Offline Bob D.
« Reply #13 on: April 09, 2019, 04:33 AM »
"It will be when he's done! :P "
exactly.
« Reply #14 on: April 09, 2019, 11:59 AM »
Is there a table of some sort of these values? My math may be completely wrong but I figure if it cuts 55mm at 90 degrees and 43mm at 45 degrees (12mm diff over 45 degrees) that's 4mm per 15 degrees so 51mm at 15 degrees off the rail. I always forget how much the rail is - 5mm?
Offline greg mann
« Reply #15 on: April 09, 2019, 08:18 PM »
15cos x 55 = 53.12
.9659 x 55 = 53.1259
Greg Mann
Oakland, Michigan
« Reply #16 on: April 10, 2019, 04:57 AM »
15cos x 55 = 53.12
Are you sure?
I think (been a while  [tongue] ) its: 55 / cos(15) = ~ 56.95
« Last Edit: April 10, 2019, 05:14 AM by threesixright »
« Reply #17 on: April 10, 2019, 08:38 AM »
Haha, well sorry to confuse the matter.
« Reply #18 on: April 11, 2019, 05:44 AM »
15cos x 55 = 53.12
Are you sure?
It would be cool if it could cut deeper at 15 degrees than straight.
« Last Edit: April 11, 2019, 10:10 AM by Sanderxpander »
