Author Topic: CT MIDI I connecting to a Domino 500  (Read 606 times)
Offline houstonotsuoh
« on: September 01, 2021, 07:13 PM »
I have the MIDI dust ex. and just got the Domino 500 but the dust hose will not connect and not founding an adapter that makes sense.
Any advise, thanks.
Offline Chainring
Re: CT MIDI I connecting to a Domino 500
« Reply #1 on: September 01, 2021, 08:01 PM »
The hose that comes with the Midi I should have the 27mm tool end on there and that slips right onto the DF 500 dust port. If that's not working for you, something ain't quite right. Post a picture of your hose and collection point on the 500.
Offline ChuckS
« Reply #2 on: September 01, 2021, 08:08 PM »
Unless it's a defect, the CT mini or midi hose fits into the DF dust port. Does need a bit of force and try angling the hose slightly as you push it.
« Last Edit: September 01, 2021, 08:10 PM by ChuckS »
Offline squall_line
« Reply #3 on: September 01, 2021, 11:18 PM »
Literally the first time I used my Domino 500 was with a MIDI I with the stock hose, so I'm 99% certain they're compatible.  As others have said, the collection can be a pain to put on.  Page 12 of the manual that's in my Systainer has tips on how to attach the hose, but they show the old style of collection port, not the new twist-lock.
For the twist-lock, line the arrow on the hose nozzle up with the line on the collector port of the Domino.  Force it on to the port, then twist clockwise to line the arrow of the nozzle up with the arrow on the port.  To remove, reverse the steps.
Pictures below.  Hope this helps!
335107-0
335109-1
« Reply #4 on: September 02, 2021, 08:15 AM »
the midi plugs and locks into place real nicely with the track saw 75 and just dont understand why this does not happen with the domino.
Online benz240
« Reply #5 on: September 03, 2021, 08:43 AM »
Did you line up the arrows?
