Author Topic: CT Midi hose  (Read 770 times)
Offline mike9
CT Midi hose
« on: November 19, 2020, 06:04 PM »
I need to purchase a new hose for my CT Midi but I am not sure what model to order. My vac has the 90 degree connector going into the vacuum itself. I looked at one hose but it said it would fit 2019 and newer but have no idea when I bought my vacuum or where I can find a date on the unit. Thanks for looking.
Offline woodferret
Re: CT Midi hose
« Reply #1 on: November 19, 2020, 06:18 PM »
The 2019 MIDI moved the port forward closer to the front, but still in the garage.  It also got recessed deeper into the body, hence they now use a straight connector and just bend the hose.
Regardless, your serial placard on the back will have:
Voltage | Amps
Total amps | IP X4 | weight | date mfg
T-Nr | S-Nr
Offline SRSemenza
Re: CT Midi hose
« Reply #2 on: November 19, 2020, 10:57 PM »
   D32/27 hose with right angle connector 500680.
   Or if you want a straight D27 hose the one for the CT-SYS (201665) has a right angle connector but it is also about 1 1/2' shorter.
« Last Edit: November 19, 2020, 11:00 PM by SRSemenza »
Offline mike9
Re: CT Midi hose
« Reply #3 on: November 21, 2020, 01:37 PM »
Thanks for the help, ordered one Friday.
