Author Topic: CT 36 Vac with Kreg Foreman  (Read 322 times)
Offline bohaiboy
« on: January 07, 2021, 06:07 PM »
The standard fitting from Festool does not work on the Kreg Foreman Pocket hole machine dust outlet.  Does Festool make adapters for various fittings that can be used on other brands with different size outlets?  I have a 36 CT E.   The hose on the Festool is 36 mm and the outlet on the Kreg is also 36mm.
« Last Edit: January 07, 2021, 06:15 PM by bohaiboy »
Offline Chris Perren
« Last Edit: January 07, 2021, 06:52 PM by Chris Perren »
Offline bohaiboy
Re: CT 36 Vac with Kreg Foreman
« Reply #2 on: January 07, 2021, 06:52 PM »
Chris, did you replace the Festool hose with the Rockler hose or are you just using the connectors?  TIA
« Reply #3 on: January 07, 2021, 06:56 PM »
@bohaiboy  - I just added more pictures to my first post..  I use it as a connection.  The rockler hose is connected to the Kreg foreman.
