Author Topic: CSC SYS 50 production line  (Read 3201 times)
Offline ElectricFeet
« on: May 21, 2023, 04:03 PM »
I missed this video a few months ago on the Festool Italia YouTube channel. It’s in English with Italian subtitles. Shows the new factory and the CSC SYS 50 production line.
Offline Coen
Re: CSC SYS 50 production line
« Reply #1 on: May 21, 2023, 04:27 PM »
Nice
Funny how the scematic view in Google Maps shows their whole factory rotated a bit across the streetplan  [tongue]
Offline darita
« Reply #2 on: June 01, 2023, 03:54 PM »
Kinda makes me wanna get one, even though I already have a JS Pro and a SS Compact Saw.  Hmmm...maybe next year...
« Reply #3 on: June 01, 2023, 04:55 PM »
If I had a sawstop compact, I don’t think I would get the CSC SYS (which I have). The sliding table is really nice, and the electronics are really cool, but the sawstop technology in a small package would be more important for me (we don’t have that in Europe (yet—to my knowledge—apologies if I’m wrong)).
Offline woodferret
« Reply #4 on: June 01, 2023, 07:37 PM »
TKS 80.  Has aux sliding table, but it's far from the blade - like in a different postal code far.
« Reply #5 on: June 02, 2023, 05:55 AM »
Unfortunately, the TKS 80 is too big / poorly-portable for me, hence my getting the CSC SYS 50. But if I had been able to get a compact sawstop here in Europe, I think I would probably have got that instead, despite the great tech on the CSC.
Offline woodferret
« Reply #6 on: June 02, 2023, 08:54 AM »
I hear you.  I've been flip flopping between the CSC and the Sawstop CTS.  The main thing stopping me is that there's only about 250mm infeed support on the CTS.  What's the comfortable range for the slider on the CSC?
Offline darita
« Reply #7 on: June 02, 2023, 10:34 AM »
Don't mean to steal the thread, but ya, I do like the Compact very much.  It's a solid, accurate little saw and I use it more than the JSPro.  I got rid of my cabinet saw and thought I'd miss it, but the Compact does everything I did with the cabinet saw, so I never looked back.
« Reply #8 on: June 02, 2023, 11:02 AM »
Ouch. 250 isn’t much. Though you can build a jig for ripping:
http://www.youtube.com/watch?t=93&v=Wkhstmsc61E
or for slightly wider cuts:
With the slider pulled fully towards you, there’s about 420mm infeed on the CSC.
357849-0
That’s with the fence just on the very front edge of the slider, which is the point at which there is no play and I’d feel comfortable using it. I suspect Festool would say a number lower than that and might want more of the mitre gauge on the slider. But IMO it’s really solid at that point.
357851-1
There’s also the option to lock the slider in place while it’s pulled fully towards you (the saw-blade changing position). This would give some more infeed support for wide panels against the fence. But then your waste side would have no support. This could be fixed with a strategically-placed block, taped down with double-sided tape beneath the slider (on the circled area in the photo*).
357853-2
But it’s really sketchy IMO as someone not (yet) experienced with using a tablesaw. Personally I’d get my track saw out at that point — much easier. The manual describes the forward position only for changing the saw blade.
* Note that the slider doesn’t slide directly on this area— there’s a ~3mm gap. So using a very light double-sided tape to stick down a block is doable, though there’s obviously a risk of crud buildup over time, which then could interfere with the slider moving above it.
Just speculating what could be done to increase infeed depth here, and not making any recommendations. Personally I wouldn’t use the sliding table locked in the forward position for cutting.
« Last Edit: June 02, 2023, 11:05 AM by ElectricFeet »
Offline Gregor
« Reply #9 on: June 03, 2023, 04:09 AM »
Would have been nice if the Kapex extensions could connect to it, to use as in/outfeed for rips.
