Author Topic: Crystal sandpaper?  (Read 7744 times)
Offline glennwarner
Crystal sandpaper?
« on: January 25, 2007, 10:03 AM »
Anyone used this yet and is it available in the US?
Thanks,
Glenn
Offline CharlesWilson
Re: Crystal sandpaper?
« Reply #1 on: January 25, 2007, 01:35 PM »
I received 5 sheets with a new ES-125, but fortunately I have an RO-125 to use them on. I am not sure when it would make sense to use Cristal with the ES-125. Can anyone out there suggest situations where the Cristal should be used in random orbital mode?
Charles Wilson
Offline Bob Marino
« Reply #2 on: January 25, 2007, 01:40 PM »
  It is more aggressive at sanding at a given grit. This is not only to be used in the rotary mode, nor just made for the Rotex.
Hopefully, this paper should be availble soon.
Bob
Former Festool  Dealer since 2002; user well before that!
Marco F.
  • Guest
« Reply #3 on: January 26, 2007, 08:42 PM »
I just got a new rotex 150 in the mail and it came with a sampling of the cristal sandpaper. Haven't used it yet but I will give some details once I have had a chance to use it.
Offline Jerry Work
    • The Dovetail Joint
« Reply #4 on: January 28, 2007, 10:58 PM »
Crystal paper has fewer grains of whatever grit size is on the paper than others.  It is designed so it will not load up as readily but will also leave more scratch marks for a given grit size than the more common Brilliant or Rubin.  It works great for rapid carving work and for removing old finishes as long as you know that you will need to follow up with the more traditional papers to remove the scratch marks.
Jerry
The Dovetail Joint
Fine furniture designed and hand crafted by Jerry Work
in the 1907 former Masonic Temple building
in historic Kerby, OR.
26 mi SW of Grants Pass on US 199, The Redwood Highway
Visitors always welcome!
http://jerrywork.com
glwork@mac.com
Offline Bob Marino
« Reply #5 on: January 28, 2007, 11:01 PM »
Jerry
Yes, And will be available in grits from 40 - 120.
Bob
Offline Frank Pellow
  • Toronto, Ontario and Lake Pivabiska, Ontario
« Reply #6 on: January 29, 2007, 04:07 PM »
I have been using Sahpir for rapid removal a material jobs (such as all the old finish on my cedar cabin).  How does Crystal compare to Saphir?
Cheers,
               Frank (Festool connoisseur)
Offline Bob Marino
« Reply #7 on: January 29, 2007, 04:46 PM »
 Frank,
 The Saphir paper is a way heavier paper than the Cristal, with better edge retention. Actually, Saphir's backing is cloth, not paper and much sturdier when sanding material that would otherwise destroy other papers...and pads. The Cristal wiill be available for the 6", 5" and  1/4 sheest Festool sanders. Bothh are very aggressive.
Bob
« Reply #8 on: January 29, 2007, 05:39 PM »
Thanks Bob, I am happy with the Saphir but am always on the lookout for something better.  It looks like, for the type of job that I am talking about, Saphire is still superior.
Cheers,
Offline Bob Marino
« Reply #9 on: January 29, 2007, 05:46 PM »
 Absolutely.
Bob
