Author Topic: Cross Stop with 4mm Dominos  (Read 696 times)
Offline Dusty.Tools
    • Dusty.Tools
« on: September 09, 2023, 05:49 PM »
Am I correct in saying the pin in the cross stop doesn’t fit into a 4mm domino hole?
@dusty.tools
Offline hdv
Re: Cross Stop with 4mm Dominos
« Reply #1 on: September 09, 2023, 06:23 PM »
Yes, but it is quite easy to adapt them to the use for 4 mm domino's. As a matter of fact I have a second cross-stop exactly for that.
Offline Dusty.Tools
    • Dusty.Tools
« Reply #2 on: September 09, 2023, 06:31 PM »
How did you adapter it? Buying a second set makes a bunch of sense!
@dusty.tools
Offline ChuckS
« Reply #3 on: September 09, 2023, 06:40 PM »
Offline hdv
« Reply #4 on: September 10, 2023, 08:07 AM »
I just removed the pin from the stop and sanded it down to a diameter of 4 mm (using a caliper to regularly check how much material was removed). I did this using the fixture for the pig tail mandrel on my linnisher (adapted it with a small jeweller's clamp), but I think a pillar drill would be just as good for this.
Maybe buying a new cross-stop just for this is a bit overkill, but the smaller pins have do have some impact on the offset. For most applications this might not be of any significance at all. In that case it might not be needed to buy a second cross-stop.
