Author Topic: Corner connectors  (Read 707 times)
Offline mat
Corner connectors
« on: January 22, 2019, 09:22 PM »
I am in the process of making a bed frame and considering the joints.
The question going through my mind is are two domino corner connectors stronger than one connector and one wood domino not glued in place?
Mat
Offline Birdhunter
Re: Corner connectors
« Reply #1 on: January 23, 2019, 06:16 AM »
I made a king size bed frame and chose the combination of a solid tenon and a connector. Two years later, it’s still rock solid.
I chose the solid tenon and connector because the solid tenon eliminates any twisting of the joint. I found I had to be extremely precise in cutting the mortises and even practiced using scrap of the same dimensions as the bed frame.
I assume you are using the 700 connectors and not the 500 connectors.
Birdhunter
