Author Topic: Converting HL-850 Planer to metric  (Read 555 times)
Offline dlu
« on: July 28, 2022, 03:57 PM »
Any idea how feasible it would be to convert the imperial version of the 850 back to metric?
Offline Jim_in_PA
Re: Converting HL-850 Planer to metric
« Reply #1 on: July 29, 2022, 02:28 PM »
I'm curious about what actually gets measured on a scale with this particular tool...
ETS 150/3, Rotex 150, OF1010, OF1400, Trion PS 300, TDK-12, CT-22, MFT 1080, TS55, Domino XL DF 700, 8' track, (2) 55" tracks
SCM MiniMax S315WS, FS350, MM16, Camaster Stinger II SR-44 CNC
« Reply #2 on: July 29, 2022, 02:55 PM »
Setting depth of cut.
Offline Birdhunter
« Reply #3 on: July 29, 2022, 03:08 PM »
I have the 850 and never paid much attention to the scale. If I am looking for a certain depth of cut, I trial and error on scrap.
Birdhunter
Offline Chris Wong
  • Festool Dealer
  • I make things that challenge me.
    • Flair Woodworks
« Reply #4 on: July 29, 2022, 08:56 PM »
Not sure, but I believe the part you need to replace is 31 on the parts diagram. If I'm right, the metric version is part number 715053, and it is described as a "Cam". This is the only part in the vicinity that has a new part number, compared to the metric version.
Hopefully you can get into that area by removing the screws in part 35, but I haven't done this.
Chris Wong, http://FlairWoodworks.com and https://www.ultimatetools.ca/
First Festool was a free pencil.
Shipping live-edge cribbage boards around the world since 2010.
Offline woodbutcherbower
« Reply #5 on: July 30, 2022, 03:46 AM »
I’m with Birdhunter on this. I’ll plane stock and check it using calipers. Same for tasks like slot routing where the depth of cut is super-critical. I make test cuts and check the depth manually, and then make whatever micro-adjustments are necessary. I think it probably all stems from tools I was using 30 years ago whose gauges were little more than guesswork.
« Last Edit: July 30, 2022, 03:50 AM by woodbutcherbower »
