Author Topic: Control CTL 26 E SD via power cord?  (Read 920 times)
Offline petrho
« on: July 20, 2019, 04:17 PM »
Hi I have a CTL26 with auto function (starts when power tools is started) but I want to control the CTL via the power cord (and the CTL in manual mode).
Will that damage the CTL?
Offline neeleman
Re: Control CTL 26 E SD via power cord?
« Reply #1 on: July 20, 2019, 04:27 PM »
I use my CTL 26 that way also for 8 years now.
A wireless transmitter on the hose and the receiver between the power cord and the wall outlet.
And the CTL is always on manual.
Only downside is that the vac has to be turned on with the transmitter before switching the machine to on.
These switchable wall sockets are available all over the world these days.
« Last Edit: July 20, 2019, 04:45 PM by neeleman »
Festoolian since 1998.
FESTOOL:
RTSC400Li | CTL MIDI I | SYSROCK BR10 | SYSLITE KAL II | SV-SYS D14 | DSC-AG125FH | CDD9.6 | SYSLITE DUO | DF700 | HKC55 | TXS2.6 | CTL SYS | CXS2.6 | DWC18 | CTWings | BHC18 | CS50 | CMS-OF | MFT/3 | MFT/3-VL | KS120 | TS55 R | PSC420 | PS420 | BS75 | RAS115 | RO90 | RO150 | RS400 | RTS400 | RS300 | LS130 | DX93 | ETS150/5 | ETS150/3 | OF1010 | OF1400 | OFK500 | MFK700 | T18 | EHL65 | CTL26 | CTL22 | WCR1000 | D27-AS Plug-it | D36 UNI-RS | D36x7 | D50x2.5 | FS800 | FS800/2 | FS1080/2 | FS1400/2 (2x) | FS3000/2 | FSK250 | FSK420 | Gecko Dosh | Toolie | CE-SYS-2010 | RB-SYS CART (2x) | LEV1400 | LEV350 | SYS-MFT
PROTOOL:
« Reply #2 on: July 20, 2019, 04:44 PM »
I use this with a Fein vac. I assume it will work fine with a Festool vac.
Been drilling holes in masonry in one end of the basement while the vac is in the opposite end (two long hoses away). Extremely convenient to just push a button to control the dust.
Offline Alex
« Reply #3 on: July 21, 2019, 02:05 AM »
I have looked into these but never found a set rated over 1000w, how did you solve that?
Offline neeleman
« Reply #4 on: July 21, 2019, 05:05 AM »
You're right that these are normally used for switching lamps, etc. and not machines.
But I use one which is rated 3.500W.
And is just designed for not blowing the fuses in Holland (3.680W).
It's one from a Dutch brand KlikAan|KlikUit: ACC-3500. The name says it all.
« Last Edit: July 21, 2019, 05:18 AM by neeleman »
FESTOOL:
PROTOOL:
