Author Topic: Connecting the Kapex MFT to the MFT 3 table  (Read 682 times)
Offline mnwitt
« on: October 23, 2020, 08:43 PM »
Has anyone connected the Kapex MTF to an MFT 3? As far as I can tell there are no Festool products to accomplish this. I am using the Kapex on a Kapex table between two MFT 3s. I want to be able to clamp stops on to the adjacent MFT 3s to make accurate repetitive cuts. I can probably create a fixture to connect tables together but was curious what other owners have done. Thanks in advance.
Offline johnsayen
Re: Connecting the Kapex MFT to the MFT 3 table
« Reply #1 on: October 24, 2020, 07:50 PM »
Take a look in the supplemental manual here, they show you a couple options with festool products. One is clamps, the other a screw/nut combo.
https://service.festoolusa.com/media/pdf/Kapex-KS120-Supplemental-Manual.pdf
Offline jobsworth
  • Festool Baby.....
« Reply #2 on: October 24, 2020, 09:26 PM »
@mnwitt
easy when you set the MFT3 next to the Kapex MFT use the fence from the MFT3 along with the compass assy and the flag stops that come with the MFT3 buy more flag stops if necessary. you dont need the MFT3 fence to be prefect aligned with the Kapex. If you need longer fence make one and make a stop for it.
Offline Ajax
« Reply #3 on: February 27, 2021, 10:44 PM »
Is there a way to connect the Kapex MFT to the MFT 3?
There are connectors for connecting 2x MFT 3's together.
Kapex KS120, 2 x MFT/3, TS55 REQ, TS75, LS130, RTS400, RO90 DX FEQ, D90 Assortment, RO150 REQ, ETS 150/3, PRO5, D150 Assortment, DF 500, Domino 4/5/8/10 Assortment, DF700 XL, Domino 12/14 Assortment,  CT Midi, MFT/3, Kapex MFT, 2 x SysRoll
