Author Topic: Connect the DeWalt Planner 735 to the 576760 Dust Extractor CLEANTEC CT 36 E AC  (Read 1321 times)
Offline Don H
I am new to the Festool world.  Been looking at them for months.  As I am not familiar with all the hose adapters yet and I don't want to do a trial and error adapter purchase.  I have a 27 MM hose and trying to connect it to the Dewalt 735 Planner.  What hose adapters do I need?  Does anyone have experience with this?  Would appreciate any help.
Offline ChuckS
If your plan is to thickness plane boards like what most planer owners do, the CT or shopvac is not good for it because the chips will fill up the bag in no time.
I have to agree with Chuck, 15 minutes with the DW 735 will fill that CT 36 bag, and 15 minutes later another bag will be filled...and so it goes. My 735 is connected to a Jet cyclone which has a 40+ gallon capacity. Some folks plumb the 735 into a garbage can while others plumb it into a bag which they spread on their garden. A large container is definitely your friend.  [big grin]
Offline Aux2496
Toolcurve has an adapter for the 734 planer:
Festool Hose Adapter for Dewalt 734 Planer
Though, I have no idea if it will fit the 735.  It is possible that the inner port on the 735 dust output will match the diameter.  Though, you are better off getting a full size dust collector with 4" hose.  Grizzle has them starting at $290.  (though they have a nice 1-1/2 HP on sale now for $525).
« Last Edit: May 07, 2022, 01:04 PM by Aux2496 »
Offline Joebuck
Don. Even with light use, the Dewalt will fill your CT36 up very quickly. You’d be better off directing a 4” flexible hose into a large garbage can fitted with an adaptor lid. The 735 has a built in blower that is very effective at moving the chips through the hose. As chuck and cheese pointed out, a dust collection system, even a lower cost one is much more appropriate for your application. I have a small laguna that is four times the capacity of my CT26, and even that fills up quicker than I’d like. The issue with relying only on the internal blower of the 735 is that chips tend to collect on the feed table, adding suction from a dust collector greatly reduces this. Sorry to not answer your initial question, but I think any adapter for a 27mm hose to the jointer would be largely futile.
Offline jobsworth
  • Festool Baby.....
I tried it with my makita planer, the extractor wont keep up with the chips. If I remember correctly the Dewalt ejects chips. So maybe you can attach a bag to the ejection port just make sure it dont get clogged to.
Or
You can do what i did. I bought a cheap wall hung dust collect (shop fox) that hangs on the wall out of the way.  I use that for planing and joining.  It still isnt perfect, the bag fills up quickly so I have to keep a eye on it.
Harbor frieght has one for $159. Ya I know HF. But hey if all yer using it for is your planer it will work fine
Offline Crazyraceguy
I'm thinking that the 27mm hose is a problem, either way.
"Even if" you decide to go with the CT plan, go with either of the bigger hoses 36mm or better yet 50mm.
That said, same as the others, I would go with one of the smaller collectors that uses a 4" hose.
At bare minimum using one of the trashcan-lid type separators with a 4" hose to the Planer and your CT  on the other end. Those Dewalt 735s do have a fan to help with the chip/airflow
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT26E + Workshop cleaning set
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
Shaper Origin/Workstation
MFT clamps set
Offline kevinculle
I have a DW-735 serviced by an 1100CFM collector with a 40 gallon Thein baffle can in between...so it's sort of like a CT-150 if Festool made one.   When I'm in a serious project I can fill that can in a week, under normal circumstances it takes maybe 3-4 weeks.  A shop vac, even a Festool shop vac is no match for a planer.
Offline ChuckS
A lawn waste bag filled up with walnut chips from the dust collector:
That probably would fill up 2 or 3 CT bags.
Offline Steve1
I agree with the others who said your bag will fill up in no time.
See also this thread:
https://www.festoolownersgroup.com/other-tools-accessories/dw735-planer-setup/msg667292/#msg667292
Offline TomK_2
I use a 5 gallon bucket with a dust deputy hooked to my midi. It works fine but it does fill up fast. I have the smaller lunch box dewalt without the blower. A trash can or bin is not a bad idea especially with the blower on that thing.
Offline SRSemenza
Don H,
         What they said ^^^
    D27 hose is not going to work.
    Bag will fill super fast.
    If you don't mind emptying the container frequently,  ....................  a CT VA 20 Separator with a larger hose might do it. But no guarantees.
Offline Paul_HKI
I run a Metabo 260 combo planer thicknesser using a 200L barrel, Dust Commander DLX, a pair of D50 hoses (2 meters long each) and a CT26.
Works perfectly.  No blockages, good filtration, pretty much everything goes into the barrel and doesn't leave it.
I wasn't 100% on it working in the first place, but I tried it and have since put about 10 barrel loads into recycling and the CT bag hasn't been changed yet.
I also have the CT-VA-20.  It works, but it will drive you up the walls if you try using it on the lunchbox planer.  I'd gladly recommend the barrel and cyclone combo, but not without the 50mm hoses.  That's the key, IMHO.  My planer is set up with 10" straight knives also, before someone asks.
« Last Edit: May 09, 2022, 10:46 AM by Paul_HKI »
TKS 80 EBS-SET, KS 60 E-Set, TSC 55 REBI, TS 75, HKC 55,
DF 500 & DF 700, OF2020, OF1010 REBQ, OF1010 EBQ, OFK 500,
T18+3, C18, PDC 18/4, TID 18,
RO 150, RO 90, RAS 115, RTS 400, ETS 125, ETS 150/5,
EHL 65, HL 850 EB,
CTL 26 E, CTL MIDI I, CTL-SYS, CT-VA-20
VAC SYS w/ SE1 & SE2, MFT/3, SYS PowerHub, DUO SYSLITE, & KAL.
Offline ChuckS
Someone came up with this solution, without the use of any dust extraction:
https://www.timberthingswoodwork.com/post/diy-dust-collection-for-dewalt-735-planer
It seems some people are pretty happy with the built-in fan of the machine.
« Last Edit: May 09, 2022, 10:56 AM by ChuckS »
The internal blower in the DW 735 is so powerful that I don't even turn on the Jet DC, the Dewalt blower just pumps all of the chips through 10 feet of flex hose directly into the Jet DC.
Offline ChuckS
Cheese -- That strong?
Mine is a Ridgid, and I don't know if its blower is as strong, because since day 1, I've used the planer with a dust collector. I should try it out next time with using the blower alone, and compare. If it's as good as or close to using the d.c., it'll save me from the hassle of using an auto switch and making the mobile d.c close to the planer every time I thickness plane. I may even be able to set it up such that the chips go direct into the lawn waste bag placed inside the compost cart!
« Last Edit: May 09, 2022, 03:06 PM by ChuckS »
Ya Chuck...that strong.  [smile]
I happened upon it by chance, I misplaced the remote for the DC and turned on the planer before the DC. While looking for the remote I noticed the clear plastic bag on the Jet was fully expanded and had to feel the Jet for vibration to verify it was not on. So I ran some boards through and it was settled. One less machine tool making noise while the planer is on.  [smile]
Offline Frodebro
I don't run a dust collector with my 735 at all, just a four foot length of 4" flex tubing with a bag on the end (the bag is for Rockler wall mount collectors, I just run the 4" pipe into it and secure it with a hose clamp).
