Author Topic: cms router table  (Read 1115 times)
Offline harryjoiner
cms router table
« on: May 28, 2014, 09:35 AM »
Hi Guys
I'm thinking about buying the 2200 router and the CMS-OF to go with it. I don't plan on buying the CMS basic unit at least not right now and I was hoping to build a table to mount the CMS-OF to.
I use my current router mostly for kitchen worktops, I want an upgrade and I thought the 2200 would be a good choice. I also need a router table, I have some raised panel doors to build an I hoped to cut them using the CMS-OF however the router bit I will be using is a 90mm.
So my questions are;
                                 can I use a 90mm raised panel bit with the CMS-OF?
                                 can I mount the 2200 to another table/make a table?
                                 has anyone mounted the CMS-OF to a homemade table or is that a bad idea?
Many thanks
Harry
