Author Topic: CMS HOSE KIT  (Read 4109 times)
Offline #3H
CMS HOSE KIT
« on: March 07, 2015, 07:43 AM »
I was looking at this hose kit that  the CMS uses for their router table.   I'm looking to hook it up with a Kapex and another Festool unit. Question is has anyone come up with a blast gate to shut off either hose without disconnecting one and put a cap on it. Would be nice with just a slide of a gate to choose which device to use.
Hope there is a off the shelf answer.
Ralph
a fair line always supersedes a given measurement.
Online neeleman
Re: CMS HOSE KIT
« Reply #1 on: March 07, 2015, 07:54 AM »
I use 2 of these (497926) on my Protool VCP 260 together with the Y-adapter.
They are actually meant for the Autoclean CT's but also work as blast gates on 2 hoses.
Although I'm not a fan of the Y-adapter.
Simultaneously use of 2 hoses is not working, there is to much loss of pressure
« Last Edit: March 07, 2015, 07:56 AM by neeleman »
Festoolian since 1998.
FESTOOL:
RTSC400Li | CTL MIDI I | SYSROCK BR10 | SYSLITE KAL II | SV-SYS D14 | DSC-AG125FH | CDD9.6 | SYSLITE DUO | DF700 | HKC55 | TXS2.6 | CTL SYS | CXS2.6 | DWC18 | CTWings | BHC18 | CS50 | CMS-OF | MFT/3 | MFT/3-VL | KS120 | TS55 R | PSC420 | PS420 | BS75 | RAS115 | RO90 | RO150 | RS400 | RTS400 | RS300 | LS130 | DX93 | ETS150/5 | ETS150/3 | OF1010 | OF1400 | OFK500 | MFK700 | T18 | EHL65 | CTL26 | CTL22 | WCR1000 | D27-AS Plug-it | D36 UNI-RS | D36x7 | D50x2.5 | FS800 | FS800/2 | FS1080/2 | FS1400/2 (2x) | FS3000/2 | FSK250 | FSK420 | Gecko Dosh | Toolie | CE-SYS-2010 | RB-SYS CART (2x) | LEV1400 | LEV350 | SYS-MFT
PROTOOL:
Offline #3H
Re: CMS HOSE KIT
« Reply #2 on: March 07, 2015, 08:56 AM »
Great to see a solution other then a shop made blast gate.   Now to check the price.....! I assume, Festool frowns on the use of a multi outlet fearing an overload.
Thanks,
Ralph
Offline Greg Powers
  • Metric convert
    • Stargate Unofficiial
Re: CMS HOSE KIT
« Reply #3 on: March 07, 2015, 01:23 PM »
The Festool option will set you back 140 dollars plus for the Y connector and two blast gates. I found these, see photo below. They were not anti-static, so I add the foil tape. They are color coded to make it easy to tell which hose iis on which blast gate.
Greg Powers
Offline #3H
Re: CMS HOSE KIT
« Reply #4 on: March 07, 2015, 07:14 PM »
I did see the price - is it worth not swapping hoses?  What I liked was the CMS hose kit that gave you the "Y" and also the 37mm shorter hose.   I do have the longer 37mm  but thought the Kapex would be better with a shorter hose.
Will give it a little more thought about making life easier.....
Ralph
Offline Jaybolishes
Re: CMS HOSE KIT
« Reply #5 on: March 07, 2015, 07:32 PM »
Greg who makes the orange blast gates?
Offline Greg Powers
  • Metric convert
Re: CMS HOSE KIT
« Reply #6 on: March 08, 2015, 07:57 PM »
@Jaybolishes the company is Shop-Vac They come in a kit:
http://www.shopvacstore.com/product/sawdust-collection-kit
But I was able to buy just two a spare parts.
A google search found this link. The Vacuum gates are $5.99. You just need to know that shop-vac calls them Vacuum Gates not Blast Gates.
http://www.shopvac.com/shopvac-accessories/Products/Vacuum-Gate-for-Sawdust-Coll-Kit__919-36-00.aspx
I had to add a set screws to tighten up the one connection. It was snug but kept working loose.
« Last Edit: March 08, 2015, 08:01 PM by GPowers »
Greg Powers
Offline Jaybolishes
Re: CMS HOSE KIT
« Reply #7 on: March 08, 2015, 08:04 PM »
That's great, many thanks!
Offline rst
Re: CMS HOSE KIT
« Reply #8 on: March 08, 2015, 08:16 PM »
Hey, thanks for the link, I only live 35 minutes from ShopVac and I pass their factory regularly.  I will stop by tomorrow as I have to pass there on the way to job.  I love serendipity.   ;D
Offline #3H
Re: CMS HOSE KIT
« Reply #9 on: March 11, 2015, 12:34 AM »
Yes, thanks for the link - looks like it works perfect with the 27mm & 36 id/od of festool!
