Author Topic: CMS GE Infeed Table?  (Read 3674 times)
Offline Ironmantrev
« on: December 22, 2015, 06:48 PM »
Just picked up my new CMS GE table yesterday and have it assembled. Got to looking at the Outfeed extension wondering if it could be used for an Infeed extension. The switch currently is in the way for an Infeed, this would have to be moved, or possibly loosened off so the small bracket could fit between the frame and the body of the switch. Has anybody done this?
Also got four little metal brackets, but don't know exactly what they are for. Part # is 499320. The separate zip lock bag they came in has a label that says Winkel CS 50 / CMS. Can someone tell me what they are for?
Thanks in advance.
Offline copcarcollector
Re: CMS GE Infeed Table?
« Reply #1 on: December 22, 2015, 07:07 PM »
Yes it has been done, you need to purchase another outfeed table and use it on the infeed side. (Or just use the one you have on the other side!)
 492092   Currently $259 in the USA
Here is a topic where this is covered, and pics as well:
http://festoolownersgroup.com/festool-wish-list/vectura-first-pass/msg363981/#msg363981
Offline Ironmantrev
« Reply #2 on: December 22, 2015, 07:11 PM »
Awesome copcarcollector! Thank you very much for the link. Got some reading to do.
Clearly the OP in that thread does not have enough clamps, haha. Wowsers. Pretty impressive shop. Something to strive for most certainly.
Offline Gary Sosa
« Reply #3 on: July 03, 2016, 10:46 AM »
Did you ever figure out the 499320 brackets that came with the CMS? I came across them too...
Offline Sparktrician
« Reply #4 on: July 03, 2016, 06:00 PM »
Thanks in advance.
I use two infeed/outfeed tables as you'd like to do and had to relocate the power switch to a position above the tables and to the rear.  It was an easy thing to do.  PM me with your email address if you'd like some pictures.
- Willy -
Offline PreferrablyWood
« Reply #5 on: July 04, 2016, 03:33 PM »
I'd try a UG wing for infeed
Vecturo OSC, BHC SDS, RO 150, 850 HL E Planer rustic head standard head angle fence, MFS 400x2, MFS extensions MFS VB 700 x 1 MFS VB 1000 x 2 . CMS GE, sliding fence, VB and 2x VL extension tables, OF 2200, Accessory Set ZS OF 2200 M,36mm 5m antistatik hose, CMS OF+ CMS TS 75 insert modules. SYS-MFT Fixing-Set,  3.5m sleeved hose, Syslite duo, Sys 4 sort 3 x3, Sys Roll, Sys 1 Box x2 , classic Sys 3-Sort 4, classic Sys 3 Sort 6 x2, Sys Cart x3 Systainer 4 x2  as toolbox with selfmade inserts Systainer 5 as toolbox with insert.
Festool 18V HKC 55 Li 5.2 EB Plus FSK 420,FSK 250, Extra blade for the HKC 55 W32.TI 15, CXS 2.6 Ah version, RO 90 DX, PDC 18/4 plus DC UNI FF depth stop chuck,AD 3/8 square socket holder FF chuck, Centrotec Bits; -->Bit holder and bit selection BHS 65 CE TL 24x, ,Bradpoint DB WOOD CE SET ,Zobo (Forstner) D 15-35 CE-Zobo SET ,Masonary/stone bits DB STONE CE Set,Extender BV 150 CE, Countersink QLS D2-8 CE Hook turner HD D18, end centrotec<--.  TS 75 EBQ, PSC 420, OF 1010, RS 300 EQ, CTL Midi, MFT 3, Parf dogs x2pair +Bench dogs x2pair, FS 1080, FS 1900 .  will get Domino DF 700 XL,  CMS insert BS 120 Belt sander.
Offline ADKMedic
« Reply #6 on: August 16, 2019, 09:58 PM »
So I came across this thread in a Google search...
Does anyone know what the Winkel CS 50 / CMS part #499320 is for???
Thank you in advance.
Andy
T-15+, RO150, TS55, CT-36, Pro5, DTS400, OF1400, OF1010, PS-420-EBQ, MFK700, DF-500, VAC-SYS, MFT/3 x2, CMS-GE, LR-32, soon a KS-120REB on a date sometime between now and eternity!
Offline GarryMartin
« Reply #7 on: August 17, 2019, 04:01 AM »
There's an image in the linked thread. I'm sure @RobWoodCutter won't mind me reposting it.
Online Cheese
« Reply #8 on: August 17, 2019, 09:04 AM »
If you use the CMS GE in a leg-folded position, those brackets are used to secure the CMS to a table/platform. There's a small area on each leg where they will fit.
I threw 4 each #9 x 1 1/4" Spax screws in the "Winkel Bag" just so I have everything at hand if I need them.  [smile]
« Last Edit: August 17, 2019, 09:12 AM by Cheese »
Offline ADKMedic
« Reply #9 on: August 18, 2019, 08:51 AM »
@GarryMartin and @Cheese - thank you very much!  Wondering what those parts were was starting to drive me crazy!
Andy
