I'm going to have to disagree to some extent here. I can accurately cut to fractions of a degree (1/4*) with the FSK rails.
It does take some finesse; I returned my first FSK 420 because it wasn't perfectly square. The second one wasn't either, so I filed down a bit of the nub. I did the same with my FSK 670 ( I don't own the middle one, seems superfluous to me).
It's not hard to judge position between the degree marks for the fraction.
You do need a straight edge on the wood.
It's also best for crosscutting and has obvious width limitations.
For important cuts I also mark the angle.
The FSK rails are SO much more stable on thinner pieces because you have the two nubs to brace with. Many times I don't need a clamp with them where I would if I used the FS rails.
I don't have a TS60 but I wouldn't think the plunge would be a problem, just plunge ahead of the cut.
One thing I haven't seen mentioned (in this thread); the FSK rails ONLY work with the HK saws and the TS60. They won't work with the TS55 or the TS75, if you end up getting one down the road.
I don't own an FS WA so I can't compare to that. I do know it's a lot more expensive, especially with add ons. So if you're trying to decide where to put your money it may be cheaper to measure and mark a line vs the whole FS WA setup (time/convenience vs money)
I would guess the FSK rails are better for crosscutting while the FS WA is better for longer cuts.
If I had to choose one rail type I would definitely choose the FS rails over the FSK simply because the FS rails are much more versatile in many many ways. But the FSK rails are fantastic at the specific job they do.
A bit of OT, but how practical is the HK 85 with the FSK rail ?
One hand operation feasible ? Were you not longing for a (lighter) HK(C) 55 doing that job ?
Looking for a purely subjective view.
Very practical. If all you're cutting is thin stuff the HK 55 is obviously more convenient. But if I had to choose between the HK 55 and the HK 85 I would take the HK 85 hands down. The HK 55 won't even cut 1 1/2 inches at a 45* bevel. The HK 85 will cut much thicker material. Not to mention it will cut up to a 60* bevel vs 50*? for the HK 55.
It's obviously heavier, and there is a big difference in moving the HK 55 with the FSK 420 vs the HK 85 with the FSK 670. Definitely doable though.
