Author Topic: Can the thin kerf saw blades be used on a non-F TS 55?  (Read 499 times)
Offline hdv
« on: January 20, 2023, 08:28 AM »
I was given 3 brand new saw blades for the TS 55. However, these are the thin kerf blades (1.8 mm). I own the non-F TS 55 that uses the "older" 2.2 mm thick blades. Can I safely use/adapt them, so that they will fit my TS 55? I couldn't find any information regarding this and I hesitate to "just do it" when it comes to fast spinning sharp metal objects. I would expect the thinner blade might start to excessively vibrate. But maybe something can be done about that?
Offline six-point socket II
  • formerly @the_black_tie_diyer
Re: Can the thin kerf saw blades be used on a non-F TS 55?
« Reply #1 on: January 20, 2023, 08:40 AM »
I wouldn't do it.
Question that come to mind:
1) Is it possible to tighten it enough for it to not slip?
2) Does it play well with the riving knife that is optimized for the 2.2mm blades/cut width? (And that's probably the most important question of the two I have on this.)
3) What are the underlying dangers from 1 & 2?
Festool furthermore says it's not compatible. (Scroll down to the table.)
-> https://www.festool.de/kampagnen/landingpage/kreissaegeblaetter#Säge-Anwendungen
Kind regards,
Oliver
« Last Edit: January 20, 2023, 08:43 AM by six-point socket II »
Kind regards,
Oliver
Offline pixelated
« Reply #3 on: January 20, 2023, 10:16 AM »
My saw is an HK-55, which uses the same 1.8mm blades. The blades are fine, leastwise that's been my experience. I've used the saw for everything from softwoods to Corian.
The main problem for you is the riving knife which too thick for the 1.8mm kerf. There have been some discussions in here on the possibilities of machining the riving knife, but I don't know if anyone has actually done it and wrote about it.
Offline hdv
« Reply #4 on: January 20, 2023, 10:36 AM »
@six-point socket II : thanks for that link. I didn't find that table in my search. It clarifies a lot.
It looks like I will have no use for those 3 blades then. Silently I was hoping for a trick using a filler to make up for the difference in thickness. I completely overlooked the issue with riving knive...  [scared]
Oh, well. I'll see if I can sell them on to someone else.
Offline HowardH
« Reply #5 on: January 20, 2023, 10:38 AM »
I would be very leery of the riving knife binding on the smaller kerf.
Howard H
P1cc, T15, TID-18, RO150FEQ, ETS EC 150, MT55cc, RTS400, CT22, CT36E, 800, 1080, 1400, 1400 holey, 1900 rails, OF1400, OF1010, CSX, C18, LR32, VacSys, Vecturo, Domino, Qwas dogs, Parf Dogs, Zobo's, Syslite Uni, CMS GE, PM 1500, Jet J/P, FS-WA, Shaper Origin. Felder AF-14, TSC 55 KEB, Dash-Board bench system
« Reply #7 on: January 20, 2023, 11:31 AM »
