Author Topic: C18 weight descrepancy  (Read 846 times)
Offline Lime green
« on: November 01, 2022, 04:26 PM »
On Festool USA website it says the c18 weighs 3.31 lbs and 3.53 with the battery.  I looked up the weight of the 4.0 amp battery and it shows 600 grams which are 1.32 pounds, so the total weight should be 4.63 lbs with the battery.  Does anyone know what the C18 weighs with battery?
Offline Chainring
Re: C18 weight descrepancy
« Reply #1 on: November 01, 2022, 09:16 PM »
4.0 Li Bluetooth battery: 625g
C 18, no chuck, with belt hook: 1011g
Offline squall_line
« Reply #2 on: November 01, 2022, 09:30 PM »
I have a 2017 vintage C18, which came with 5.2 Ah batteries.
Weighed with my kitchen scale (shh....)
Bare tool, no chuck, with belt hook: 1009g / 2lb 3.6oz
With 5.2 Ah battery: 1721g / 3lb 12.7oz
With 5.2 Ah Bluetooth battery: 1726g / 3lb 12.9oz
With 4.0 Ah Bluetooth battery: 1632g / 3lb 9.5oz
With 3.1 Ah Bluetooth battery: 1440g / 3lb 2.8oz.
With 3.1 Ah Bluetooth battery and Centrotec chuck: 1488g / 3lb 4.5oz
The 3.1 Ah battery was almost completely discharged, which slightly affects its weight, but it's still quite svelte.  Not a CXS, by any means, but still noticeably lighter than with the 5.2.
My guess is that the C18 weight on FUSA's website should read 2.31 lb, not 3.31 lb.  And that would be with the Centrotec chuck.
Offline Lime green
« Reply #3 on: November 02, 2022, 12:16 AM »
Good info.  Thanks.  This drill is lighter than I thought it would be.
« Last Edit: November 02, 2022, 12:20 AM by Lime green »
Offline Frank-Jan
« Reply #4 on: November 03, 2022, 04:57 AM »
The 3.1 Ah battery was almost completely discharged, which slightly affects its weight, ...
 [big grin] this had me a bit confused, actually looked it up... the slightly seems to be an understatement... (nano-measures teritory)
