Author Topic: Buying of1400, what accessories/fence?  (Read 734 times)
Offline Thompmd
« on: June 14, 2020, 10:34 AM »
Using for hobby, mostly cutting a profile w/bits? Any advice appreciated
Sawstop Industrial Saw, TS75,2 800,2 1400 & 2700 rails, CT36, Rotex RO 150 FEQ, CT-VA-20, Carvex PS 420 EBQ, Carvex acc. ZH-SYS-PS 400, Kapex KS 120, CT Cyclone Dust Collection Pre-Separator CT VA 20, DF 500 Q Set, Domino 1,060pc Tenon Assortment, UG-KA-SET Portable Imperial Stand & Extensions,OF1400 EQ-F-Plus, MFT/3, MFT-SP, FS-HZ 160, TSC 55, T18 E
Offline ear3
Re: Buying of1400, what accessories/fence?
« Reply #1 on: June 14, 2020, 12:59 PM »
I would definitely add on the edge guide.  To support expanded capacity routing off the edge with the fence, I also bought some extra long 8mm rods from McMaster Carr.
I find the table widener to be helpful as well, though if I were getting the router today, I would probably make my own version since I now have that capacity.  I forget, but you may have to purchase the extra large chip catcher separately that goes with the table widener.
The guide stops too if you want to do rail guided routing.
Offline Rob Z
« Reply #2 on: June 14, 2020, 01:21 PM »
I second what Edward said about the table widener.  I felt that was quite important and added to stability when I was using the 1400.  I think the chip catcher came with the TW, but I bought mine many years ago and maybe FT has changed that offering now.
Offline Thompmd
« Reply #3 on: June 14, 2020, 07:05 PM »
I would also like to ask that I read somewhere the 36mm hose does a noticeably better job with dust/chip collection?? Has this been your experience?
Offline ear3
« Reply #4 on: June 14, 2020, 08:00 PM »
@Thompmd Yes, the larger hose makes a substantial difference with this router, though I will sometimes still use the 27mm if I'm in the middle of something and too lazy to switch.
Offline Thompmd
« Reply #5 on: June 14, 2020, 09:01 PM »
As always, thank you all . For example , I keep a Short (5’)Dedicated piece of 36mm Hose hooked to my Kapex so it takes just a second to swap. Once I feel comfortable with a length/location of the Router I’ll do something similar with a dedicated 36mm hose.
Most All of these come from you guys and it’s much appreciated.
Offline CeeJay
« Reply #6 on: June 14, 2020, 09:02 PM »
I found the 36mm hose too stiff and unwieldy to use with the OF1400 and went back to the smaller hose. Assuming that for bigger cuts you are sneaking up using 2-3 smaller cuts I found the smaller hose is fine for dust extraction.
Offline Thompmd
« Reply #7 on: June 15, 2020, 06:46 AM »
Interesting point, being new how often do you make more than one pass ? I’ve only made 1 and had no trouble?
I’ve only used on hardwood so far, mostly Walnut.
I’ve used my Bosch 1617 and new 1/2” Freud bits so they’re sharp.
